Tacoma Key
Discussion in '3rd Gen. Tacomas (2016-2023)' started by UYough, Apr 26, 2022.
  1. Apr 26, 2022 at 9:05 AM
    UYough
    UYough [OP] Member
    2018 tacoma Access cab V6
    none yet
    I have an extra key hidden on the truck. I used the key last week, it didn't work, the engine just cranked but didn't turn over. I find out the chip in the spare key went bad and must be re-programmed. I got to the toyota dealership, they say I need a new key at $300 plus. BSBSBSBSBSBSBS. Is there any alternative to the toyota key from the dealership. Whatever happened to simple keys?
    JJ Diablo likes this.
  2. Apr 26, 2022 at 9:12 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Many locksmiths are equipped to reprogram the fobs for far less than the dealership. Also in my area there is almost always an ad on Craigslist about this and I saw a sign at my local ACE hardware store advertising replacement fobs, might check those options out.
  3. Apr 26, 2022 at 9:15 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Which key?
    Or
    Makes no sense to me that a bad key could even crank the engine. I thought a bad key kills the starter, not the spark. :notsure:
    betrayus likes this.
  4. Apr 26, 2022 at 9:21 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    As noted a lot of locksmiths can do this. Plus there are mobile outfits that will come to your house and make a new key. If you already have a key, they might be willing to program it for you. If you do a search for "mobile key replacement", you should see a listing for shops in your area.
    After I had my remote start installed, I went to a locksmith near me. He cut and programmed to "H" keys for me. I think it cost $135.00 for both keys.
  5. Apr 26, 2022 at 9:33 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Toyota OEM keys each have their own coding. What the dealership does is program the truck's ECU to recognize the key. (There's a limited number of keys that the ECU can recognize. I think it's something like 6 or 8.)
    What a locksmith does is clone a key (aftermarket) to match one of your existing keys. This is not as good a solution as what the dealership does. I've had terrible luck with locksmiths duplicating keys.
  6. Jun 29, 2022 at 5:40 AM
    capequahog
    capequahog Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    what's a dealer charge to replace a fob key for a tacoma ?
    ps they don't work after in the washing machine, duh
  7. Jun 29, 2022 at 5:42 AM
    mhornco
    mhornco Well-Known Member
    Either that or download a copy of techstream and do it yourself.
  8. Jun 29, 2022 at 6:57 AM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    I accidentally bent my spare key (M/T) so it only works in mechanical door locks and tail gate and will not start the truck. I had a lock smith make me a second key for $105cad that has no remote buttons but will open door locks and will start the truck.
  9. Jun 29, 2022 at 7:04 AM
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    On my old Fords I recall if you had 2 working keys you can program a 3rd yourself so technically if you just buy a chip key and have it cut at like Home Depot or someplace then you can get the ECU to recognize it with a weird Contra style up up down down kind of thing. Does Toyota have that?
    Think I bought one off eBay for like 30 bucks and had it cut for 5.
    Found this video - I'm sure you can find the one for a match for your key type
    https://www.youtube.com/watch?v=0Mbu_YDHGqc&ab_channel=FixItYourself
  10. Jun 29, 2022 at 11:18 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    My truck does not have a FOB. No remote door locks, no remote start, no push-button start.
    I need only one key to turn the tumblers in the door, tailgate, & ignition switch and it does have an embedded chip. It starts the truck.
    I had another spare key cut to work the tumblers; but there is not any chip - thus the ignition will not fire when the starter motor turns over with that key. But it will turn over.
    The dealer charged $4 to sell & cut the non-chip key. They want $300 to sell, cut, & program a key with a chip.
    cammerv8 likes this.
  11. Jun 29, 2022 at 12:15 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Most coded keys in my experience shut of the fuel injectors. When I worked at an autowrecker, if we didn't have the key, we would pipe propane into the intake to run the engines to assess them for resale.
    HisDad likes this.
  12. Jun 29, 2022 at 1:29 PM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    yeah the $4 key is the one the Keyless entry people get to open doors and tailgate. just a key with no Chip.
    like everyone said. local locksmith will make you a copy and program it for cheaper than a dealer. usually give a set.
    right now i have a1 original keyless, the dummy non chip key and a aftermarket Keyless start key that i paid 95dollar to my locksmith. it work great 99% of the time, the 1% it fails and have to press a button to wake the key up
  13. Jun 29, 2022 at 1:44 PM
    TommyBoy51
    TommyBoy51 Well-Known Member
    Tom
    2022 Tacoma SR SX Access Cab Longbed 4x4
    I got a key cut and chipped for my 2008 camry at a toyota dealership for $70.
    He quoted me $450 to reprogram the key for all the doors.
    I said I only need it for starting the car and manually unlocking the doors.
