Tacoma Keys Stolen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by empty_space, May 18, 2021.
  1. May 18, 2021 at 12:54 AM
    empty_space
    empty_space [OP] Well-Known Member
    Hey guys, I can probably search this but I'm looking for a quick answer.
    I just got back from vacation and my place as broken into (broke a window and then entered through there). And both of my Taco keys were stolen :( I still have that one physical key that opens the driver door, but doesn't start the truck. Therefore, I can't drive it anywhere.
    Can I call a local locksmith that deals with cars to get a new key reprogrammed? Or does it have to go through the dealer since I don't have a working key.
    It's 2AM at the time of this post, so this is just one of the things I need to sort out. Already did a police report. Not sure why they didn't take the Taco, but I'm happy they didn't, the garage door was partially open too.
    When I googled stuff earlier, all I saw was that you needed a working key to make a copy.
    I'm in Westminster, CO if anyone knows anybody we deals with this.
    Thanks!
  2. May 18, 2021 at 2:48 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    I'd call your insurance and see what they can do for you. The burglar POS will most likely be back to take the vehicle at a later time so I'd ask about getting it rekeyed along with getting the new remotes. I know with an ids you can or could remove all the previous keys from the vehicle so they are no longer usable with the vehicle so I'd look into seeing if Toyota can do that for you. Sorry your place was broken into, call your local PD and file a report also.
  3. May 18, 2021 at 4:01 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Disable the truck ASAP. Remove the coil wire. Disconnect the battery.
    Then work on the getting it re-keyed.
    massac78, ugawino, Qwack and 5 others like this.
  4. May 18, 2021 at 4:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    They knew you were gone, so they are capable of 'watching' you.
    Its easier to follow you and lift the truck mid day from a HD or grocery parking lot rather than risk noise of door opening and driving off in the wee hours in case you have early rising or light sleeping neighbors.
    Or they could plan on selling the keys to a more professional heister.
    Sorry for your troubles.
    Agree with @CT Yankee that you should disable, but you need your insurance (homeowners likely) to guide you here. You do not want a 'replacement' setup that would allow the old keys/fobs to work, you need a fresh set up. Which won't be cheap, but that's why you have good insurance, right?
  5. May 18, 2021 at 8:16 AM
    empty_space
    Good call. I was thinking about them coming back for it
    Right, I was about to call them just now. I'll see what they say
    Thanks for the tips!
  6. May 18, 2021 at 8:19 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Wonder why they didn't take the truck when they took the keys at the time of the crime...
    Perhaps you got back as they were in the midst and in that case things could have gone very wrong.
    I concur with others to disable it while getting it sorted out, or get the cops to install a tracker on it and
    let nature take its course...
  7. May 18, 2021 at 8:22 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    yeah, I would pull the battery out right now and then deal with getting replacement keys.
    PS: this is why I keep all my spare car keys in a locked gun safe.
  8. May 18, 2021 at 8:23 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I’d call insurance, tow it to the dealer. Have the dealer wipe out the previously programmed keys so the thieves can’t uses the fob to unlock the vehicle or start it. Unfortunately they will be able to use the metal key to get in the door if they are smart enough to realize that. Have a new key or keys programmed. If you really are worried you could have the door locks rekeyed or changed too. It’s not gonna be cheap. That’s why you should get insurance involved
    shakerhood likes this.
  9. May 18, 2021 at 10:09 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I have done security ECU reset (with a good key) to utilize 'used' keys with the truck (3rd gen) using Techstream and seed/passcode. But I THINK this is significantly harder (without a good key)...
    Assuming 2018+ is same
    MC-10143927-9999.pdf (nhtsa.gov)
    Its possible the same weboctopus/seed/passcode method works for a reset (without a key) as it does with a key, but I would assume it doesnt...
  10. May 18, 2021 at 10:54 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    another tip for the future, rent a cheap 5x5 storage unit in the middle of nowhere (should be about $20 a month)
    store the spare keys there and make sure you don't have any document that can lead to your home address. Rarely do burglars go rob storage unit, and even if they do there's nothing too valuable.
  11. May 18, 2021 at 11:04 AM
    Uthmoelleri
    Uthmoelleri Think for yourself, question authority.
    2019 QS DCSB 4WD
    Sorry to hear about the theft, I can't help unfortunately. However rather than start a new thread, hope you don't mind I post my question here... I bought a 2019 and even though it was cpo I only got 1 key that has the lock/unlock as part of the key. What do I need to do to get another key? I asked the service tech when I got fuel pump recall done but he or the guy next to him couldn't give me a straight answer or was just too lazy to look it up...
  12. May 18, 2021 at 11:04 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    they robbed yer fobz?!! Another electronic improvement. "fobz"... Sorry to hear that you been heisted. Probably some meddling kidz.
  13. May 18, 2021 at 12:03 PM
    empty_space
    Thanks for the tips everyone! Lessons were learned
    The Toyota dealership I called didn't have availability until June... So I called another and they referred me to a local guy.
    Cost would be $295 per fob and then $120 to re-key the cylinder lock and they would come out to me. Based on what the dealership told me, this was much cheaper than the dealership.
    Waiting to hear back form the claims adjuster to see if this would be covered under auto or renters for the parts/labor for this.
    Taco_mike73 likes this.
  14. May 18, 2021 at 12:03 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Thieves probably took your FOBs cause they were only given 1 when they bought their 21.
    But for real, sorry to hear about your situation. People suck
  15. May 18, 2021 at 12:50 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    That will be far cheaper than the dealer, but they will probably not be Toyota fob and keys, just clones, if that matters at all to you.
  16. May 18, 2021 at 1:03 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    A) Maybe the perpetrator was acting alone and his vehicle was parked nearby.
    B) Maybe the OP's vehicle is a stick and the perpetrator is incapable of driving it.
  17. May 18, 2021 at 1:06 PM
    mr.rick
    mr.rick Well-Known Member
    Rick
    2021 Voodoo Blue TRDOR
    Believe it or not there is a Toyota smart key shortage right now. most people who bought a car after march of 2021 are only getting one smart key with a promise from toyota that they will eventually get a second remote when they become available. As a result fobs are pulling a premium right now being sold used, quick easy money and no way to tell what vehicle is was programmed to. Steal the keys and even if you dont take the truck you could make a quick couple hundred dollars selling them.
  18. May 18, 2021 at 1:07 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Have the dealer do it. Insurance can pay for a rental while waiting. Have all the key cylinders replaced(ignition and any doors) then program. This way all the compromised parts are new.
  19. May 18, 2021 at 2:48 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    So now I have to lock my spare keys in a gun safe? At this rate, I'll have to buy another safe just for keys.
  20. May 18, 2021 at 2:57 PM
    JTB Tacoma
    JTB Tacoma Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    Do NOT go this route. Even if you get it back, it could very well get damaged; depending on the thief, they're not usually known for their tenderness on vehicles they steal.
    HisDad likes this.
