Tacoma Lean - Does weight distribution work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tehkoema, Sep 7, 2019.
  1. Sep 7, 2019 at 12:52 PM
    Tehkoema
    Tehkoema [OP] Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    Have about a 1 inch driver's side lean (depending on fuel level) with the stock suspension. It's not really noticeable from the front but can be somewhat noticeable for a Tacoma owner from the back. I've noticed similar leaning on some other 3rd gens I've stopped behind in traffic or in parking lots.
    Obviously this isn't a big deal or enough of a pain to got out and get spacers and stuff but I'm wondering if an easy fix would be to put something reasonably heavy (a cinderblock just for example) in the passenger side backseat for a few weeks and if that would help permanently settle the suspension? Or would the suspension go uneven again as soon as the heavy weight is removed?
    edit: sorry, wrong forum but i'm sure 2nd gen owners can chime in since this particular issue affects both gens.
  2. Sep 7, 2019 at 1:15 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    A cinderblock in the backseat isn't going to do anything for it.
    2015WhiteOR likes this.
  3. Sep 7, 2019 at 2:40 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Of all the common issues on the Tacoma, this is the least one deserving of any attention.
  4. Sep 7, 2019 at 6:21 PM
    Walksinsolitude
    Walksinsolitude Well-Known Member
    2011 reg cab
    Toytec 3” bilsteins on 4 corners rear aal. 285/70/17 nitto trail grappler on venom Rex 17x9 -12 offset
    1/2 “ spacer.
  5. Sep 7, 2019 at 6:52 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It's something I consider when doing mods. I put my oba tank and compressor in the bedwall in front of the RR tire and if the battery ever gets moved it would be to the passenger side but between you, the battery, and the fuel tank there's 300-400lbs more on the drivers side so it's not a minor correction to even it out solely with weight. I use my truck for work which helps me balance it better.
