Tacoma lean? (UPDATED)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tehkoema, Jan 5, 2021.
  1. Jan 5, 2021 at 4:46 PM
    Tehkoema
    Tehkoema [OP] Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    My 2017 is stock, but lately the 1.5 inch difference in the rear is really starting to bug me. I don't notice the lean in the front so much but the back is pretty noticeable. None of the 3rd gens I spot around my area have anything like what I've got.
    Making an appointment with my dealer but I want get some data from the community on how bad the lean is for you guys.
  2. Jan 5, 2021 at 4:56 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    taco lean refers more to a side to side lean due to the gas tank, driver, and battery all being situated on the driver's side of the truck.
    what you're referring to is spring sag, or in some people's cases, the carolina squat. fixed by an AAL or a full leaf pack replacement.
    Do you carry around a lot of weight in the bed normally? that could be contributing to it.
    Jukeboxx13, rosswood, Skydvrr and 2 others like this.
  3. Jan 5, 2021 at 4:59 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    not really. Does what you're describing usually get covered on factory warranty?
  4. Jan 5, 2021 at 5:01 PM
    TacoTyusday
    Zac
    San Diego
    as far as I know and have seen, it's not since it's normal wear and tear on the leaf springs, and they're notorious for sagging quickly
    another option would be to get them re-sprung (?) though I would imagine that would cost much more than an AAL, and probably about the same as a replacement leaf pack that would have more capability.
  5. Jan 5, 2021 at 5:03 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    oh wow, that sucks. So the dealer might be a waste of time. Is there any point in changing the leafs with OEM parts if they're that crappy?
    Also would I have to change out both sides or just the squatting side?
  6. Jan 5, 2021 at 5:06 PM
    TacoTyusday
    Zac
    San Diego
    well from how it sounds, you would need to change out both? unless by your thread title you meant only the driver's rear is sagging 2in vs the drivers front 1in. Gonna need to clarify on that. But if both passenger and driver's side are sagging, 100% both.
    That being said, I would upgrade/swap out both sides in the rear (AAL into stock pack or replace with full leaf pack), then adjust your front preload if possible which should level things out. I say swap/upgrade both at the same time because I'm a big fan of consistency and it would bug me knowing one side still needs to be upgraded.
  7. Jan 5, 2021 at 5:08 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    So by 2 inches I mean the ground to the arch of the rear wheel well is 2 inches lower on the drivers side compared to the passenger side and 1 inch lower on the front drivers side than the front passenger side. This is why I was thinking it is lean but it is not an even lean front to back.
  8. Jan 5, 2021 at 5:21 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I've only had an 1\8th to 1\4 diff side to side on any suspension I either took off or put on my truck.
  9. Jan 5, 2021 at 5:25 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    yeah, I have seen pictures of Tacoma lean and mine seems more like a sag of some kind.
  10. Jan 5, 2021 at 5:27 PM
    TacoTyusday
    Zac
    San Diego
    hm interesting lol. sounds like it could be a combo of taco lean and sagging rear springs, as the taco squat (rear end lower than front) is also common due to our notoriously short-lasting leaf springs.
    to fix the taco lean, free option is adjusting preload, cheapest option would be a top plate spacer in the driver's side coilover. to fix the rear end sag, cheapest method would be to find OEM leaf packs for sale in better condition, or do an AAL to slip into the current leaf pack you have
    disclaimer: the 4 leaf TSB pack is a thing on the 2nd gens, not sure if that 3rd gens came stock with the inferior 3 leaf.
    Side note: it's also possible that, if you didn't buy the truck new, the front is raised higher because they adjusted preload. which I would imagine could contribute to rear being even lower on the leaning side. But i'm not 100% versed in suspension geometry so verify lol
    NuckTrutz likes this.
  11. Jan 5, 2021 at 5:30 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    yeah, the Taco lean itself wouldn't bother me so much but the rear sag is annoying. Truck only has 28,000kms so for the leafs to sag this early is kind of BS. Will try with the dealer and see what they say. I just don't want to pay out of pocket on a really expensive upgrade especially since I don't own any tools really so I'd have to get it installed too.
  12. Jan 5, 2021 at 5:36 PM
    TacoTyusday
    Zac
    San Diego
    yeah definitely understandable. Can't hurt to try and take it to the dealership, it could very well be that 3rd gens were released with the weaker 3 leaf pack, and if that's the case, they should do a free replacement with the 4 leaf as there's a TSB out on those weaker ones. I simply don't know cuz I'm a 2nd genner haha
  13. Jan 5, 2021 at 5:40 PM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    Worst case if the dealer tells me to kick rocks could I just but 1 AAL for the left side and get a shop to install them? Or would that likely cause a lean the other way?
  14. Jan 5, 2021 at 6:20 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    This is why I keep my toolbox on the passenger's side. Not that it's enough of balance out the battery, fuel tank and me, but it helps a bit. I also try to situate any heavy items that I may haul in the back on the passenger's side.
    14 years on my '06 and it has no noticeable lean.
    CaptainBart45 likes this.
  15. Jan 5, 2021 at 6:22 PM
    CT Yankee
    CT
    Seems to me there was a TSB on the Gen 2s - my springs were replaced when the frame was replaced in 2015.
    Kolohe07 likes this.
  16. Jan 9, 2021 at 9:57 AM
    Tehkoema
    Ottawa, ON
    2024 TRD Sport 6MT
    Dealer told me with a straight face that they measured and my truck was "bang on" level.
    Sanity check? still unsure if this is regular Taco lean or a part failure somewhere. just want to get this fixed and move on.
  17. Jan 9, 2021 at 12:39 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Wow, thats crazy the way that leans over. Totally different from looking at mine. That truck has the appearance of a broken leaf.
  18. Jan 9, 2021 at 12:49 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I'd go out in the parking lot with the service guy and a tape measure, go from center of hub up to fender to eliminate any tire differences, and measure it with him. A 1/2 inch is usually the difference between the front suspension for lean, most use a 1/4 inch spacer on top of the coilover to correct it.
    A 2 inch difference in the rear is weird. whats your center of hub to the fender on your drivers side rear ? should be around 22 inches.
  19. Jan 9, 2021 at 1:09 PM
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    That's BS what they told you. You can tell just by looking at it that it's not level.
  20. Jan 9, 2021 at 2:01 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    gotta get one of these
