tacoma lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dlalien, May 9, 2011.
  1. May 11, 2011 at 7:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The OEM springs are side specific to account for the extra weight on the driver side. If you have a lean, and the TSB was performed, chances are, they swaped the front springs to the different sides.
  2. May 11, 2011 at 7:50 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I had a lean before and after the TSB- and confirmed with the dealer that springs were in the correct location
  3. May 11, 2011 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Then that may just mean you have a spring thats sagging too much.
  4. May 11, 2011 at 8:11 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Yep my truck has it too, and it has OME all around. It makes me feel like a fat ass. :)
  5. May 11, 2011 at 8:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Aftermarket springs are not side specific. You have to add a 1/4 spacer, or trim packer to the driver side for it to sit level.
  6. May 11, 2011 at 9:33 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    If this is true then I have to say it must be a FRONT suspension issue right? I wonder if the driver side front spring is dipping-which would cause the passenger side rear side to lift, making the driver side rear appear to drop when it really is normal? Is there lean in your driverside front too?
  7. May 11, 2011 at 10:00 AM
    ink junky
    TACO LOVER
    TEXAS
    Yea I know, I'm just phucking lazy. :eek:
  8. May 11, 2011 at 10:11 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    I have air lift bags on my truck and it sits very level with about 2 - 3 PSI more in the driver side.
    Here's my measurements (Ground to Fender, I used this to install my WD hitch and needed these measurements).
    Front Driver: 35"
    Rear Driver: 36.5" (13 PSI in bags)
    Front Passenger: 35"
    Rear Passenger: 36.5" (10 PSI in bags)
  9. May 11, 2011 at 10:11 AM
    grivera
    Hanover, MD
    That's not very encouraging considering the issue was present from day one. I had my TSB done within two months of owning the truck
  10. May 11, 2011 at 12:22 PM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    anyone know where to get the spacer/leveling shim?
    I am rubbing like crazy on my inner fender right now, just on the driver side cause of the lean. If I cut out any more plastic I wont have an inner fender....
  11. May 11, 2011 at 4:52 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yes. It is called a "Top Load Spacer". Wheelers calls theirs the "Lift Enhancement Kit".
    10MM Lift Enhancer Kit: $56.00 for the kit. For additional 1/2"-5/8" approx lift. Installs on top of the upper strut plate, doesn't effect ride. Kit includes two chrome plated steel spacers and an extended stud kit.
    I believe it fits stock setups? Best to call Wheelers and confirm.
  12. May 11, 2011 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct, but that 10mm gives almost an inch on our trucks. If you have 1/2" lean, get a 1/4" spacer. if you have more than that, try swaping sides with the shocks.
  13. May 11, 2011 at 5:51 PM
    mountainwolfpup
    Vancouver, WA
    Or put a lot of weight on the passenger side to compensate for the lean. My top 5 ideas:
    1. Make friends with a guy who weighs three times what you do and offer him rides everywhere you go.
    2. Put QTY 6-8 80lb concrete bags in the bed along the passenger side.
    3. Remove the passenger seat and replace with a gun safe of 300lbs or more
    4. Use about QTY 50 tie downs to pull the passenger side suspension down a bit
    5. Just accept it and get a bumper sticker that says, "Fat Ass On Board", or "If you think this Truck is leaning now wait til after I eat lunch".
  14. May 11, 2011 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl:
  15. May 11, 2011 at 8:00 PM
    #35
    fajitas21
    Lee
    Collierville, TN
    4Runnerzzz
    I have done most of these things, I'm concerned what that says about me :(
  16. May 11, 2011 at 8:14 PM
    #36
    beckleyota
    beckleyota Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    ive got 5100 upfront and roughcountry addalef in reas with massive drivers rear lean (close to 2in) and about 1 1/2 upfront....... makes me eat moor subway everytime i look at it
  17. May 11, 2011 at 8:19 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    swap the front springs from side to side.
  18. May 11, 2011 at 8:23 PM
    #38
    beckleyota
    wv
    o7 taco
    the rear is what kills me its like the leaf is broke or something but when u look at them the driverside is flat. the adaleaf looks fine its the stock part of the leaf pack thats sagging
  19. May 13, 2011 at 2:38 PM
    #39
    dlalien
    dlalien [OP] Well-Known Member
    Jose
    North Hollywood CA
    08 TRD Sport DCLB 4WD, Tow package
    The result from taking it to the dealer was that the new springs have to settle in before they can do anything and to take it back in a month and if the proplem still exist then it could be defective springs and they will have to change them. If the lean is within a 1/4 that its fine its just the weight of the gas tank and battery. but if its stays at 1"1/4 they will figure out what can be done. So now I have to wait a month from now.
  20. May 13, 2011 at 4:20 PM
    #40
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    thanks. i was thinking that would work
