tacoma lean?
Discussion in 'Suspension' started by jermoids, Oct 5, 2012.
  1. Oct 5, 2012 at 11:34 AM
    jermoids
    jermoids [OP] Well-Known Member
    jeremy
    Moose Jaw Saskatchewan
    2016 TRD Sport
    nothing yet
    so with so many people on here talking about this "tacoma lean", i went out and had a look at my truck. 2012 trd sport. im not a mechanic, but to me it looks kind of like there is some sort of shim in there from the factory.
    is this possible?
    is there a difference between the drivers side and passenger side, maybe length or anything else?
    the first pic is the passenger side and the second the drivers side
  2. Oct 5, 2012 at 11:39 AM
    Large
    Large Red
    Interesting. Hard to tell on my phone but they don't look alike.
  3. Oct 5, 2012 at 11:48 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    They are the same, you are just looking at the rubber piece in between the coil and spring plate.
    The rubber piece squishes out a little from the where it makes contact with the end of the coil spring. Hope that makes sense. The spring is situated so that you can see the end in the second picture (drivers side in your case) and the rubber squishing a little.
    You would see the same on the passenger side, it just so happens the end of the spring is not visible in the pic.
  4. Oct 5, 2012 at 11:53 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    makes sense, thanks, i was thinking that the spring could have just been sitting different.
  5. Oct 5, 2012 at 12:32 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Like stated your looking at where the coil overlaps on the driver side.
    Stock coils are slightly longer on the driver side.
    OME replacement coils have what they call a trim packer that is placed on the driver side coil to make it a little longer.
  6. Oct 5, 2012 at 12:41 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Just to clarify , the OME trim packer installs on the shock , below the coil and only works with OME shocks
  7. Oct 5, 2012 at 1:03 PM
    jsmarine
    Jeff
    Dallas, TX
    Just to clarify again for the OP, since the abbreviations look similiar, OME is Old Man Emu Suspension, and not OEM (Original Equipment Manufacturer)
  8. Oct 5, 2012 at 2:19 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks guys! and im slowly starting to figure out all the acronyms with all the time im spending on here!
    im waiting for my 5100's to show up, im assuming fountain tire will be aware of the differences between the passenger side and drivers side, or is this something just with toyota?
    i would put them on myself but really don't have the tools to do it. plus im throwing on some new tires anyway so might as well do it all at once.
  9. Oct 5, 2012 at 7:03 PM
    OZ-T
    Peter North
    British Columbia
    I wouldn't assume that
  10. Oct 5, 2012 at 7:30 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    i will definately mention something about it, to see if they know what im talking about before i tell them to go ahead with it. i would like to think they know what they're doing but it's probaby best i make sure or i'll end up with some serious lean.
  11. Oct 8, 2012 at 7:30 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    The rubber piece is called a spring insulator...Check out my build thread and you will see what spacers look like installed above the top strut plate. I installed spacers to level the front end of my truck since I have no intention of lifting it and driving 30,000 miles per year with compromised COG (center of gravity).
  12. Oct 8, 2012 at 7:41 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    Do the spacers still compress the coils/springs but keep the uca's in the stock positions? Would it be the Sam as the 5100's but from the top?
  13. Oct 8, 2012 at 7:51 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    No. Spacers relocate the entire spring/shock to give you lift. This causes problems if you bottom out. It will bottom out the shock.
    No. 5100s preload the spring to give you lift. No issues with bottoming out the shock.
  14. Oct 8, 2012 at 7:52 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    Thanks!!
  15. Oct 8, 2012 at 7:55 AM
    GP3
    California
    4X4 TRD Off Road
    I edited my post and gave you a better answer. "No" and "No" I thought was a little vague. :)
  16. Oct 8, 2012 at 7:57 AM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    Saw that, no worries, thanks for the quick reply.
