Tacoma leans to driver side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crzymad, Mar 9, 2019.
  1. Mar 9, 2019 at 6:43 AM
    Crzymad
    Crzymad [OP] New Member
    Ron
    2017 white Tacoma Ted 4x4 off-road
    None yet
    2017 TRD 4x4 off-road drivers side is 3/4 of an inch lower is this normal?
  2. Mar 9, 2019 at 6:45 AM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    Yes. Any search of “Tacoma lean” or “taco lean” would return with hundreds of results. Gas tank is on the driver side. As well as human when it’s in motion. Battery too.
  3. Mar 9, 2019 at 6:47 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Good looking girl on passenger side helps.
    Probably designed with that in mind.
  4. Mar 9, 2019 at 7:01 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    :worthless:
    b3itz likes this.
  5. Mar 9, 2019 at 7:04 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Will need to weigh as much as you + full gas tank and 50 lb battery.
    Hopefully you're a smaller guy. :D
  6. Mar 9, 2019 at 7:10 AM
    Crzymad
    Ron
    None yet
  7. Mar 9, 2019 at 7:11 AM
    Crzymad
    Ron
    None yet
    Thanks for the info.
  8. Mar 9, 2019 at 7:26 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Unless he likes them on the larger side...
  9. Mar 9, 2019 at 7:27 AM
    InSight Retrofits
    InSight Retrofits Closed
    Good looking girl on passenger side helps but doesn't correct the issue. Lol
  10. Mar 9, 2019 at 7:28 AM
    jmneill
    SE
    We've all known someone..
    Junkhead and hiPSI[QUOTED] like this.
  11. Mar 9, 2019 at 7:48 AM
    Amchuge
    Amchuge Well-Known Member
    2018 Tacoma trd pro
    The most common emojis on this website....
  12. Mar 9, 2019 at 8:10 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I’m still rearearching the real taco lean.
    A lot of people say it’s due to weight because of the battery, driver, and gas tank.
    But when those are empty it still appears to lean. Even with new upgraded suspensions there is this lean.
    According to my truck the driver side is lower by 3/4” but when I run a level down the centerline of the truck it’s perfectly level.
    My next test is the frame. I think it’s due to frame twist.
  13. Mar 9, 2019 at 10:09 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Unless they made one fender taller tan the other you're parked on a slope. Oem springs are supposed to be side specific. Maybe they ran short on the stiffer driver's side sets.
    Shellshock likes this.
  14. Mar 9, 2019 at 11:06 AM
    JoeCOVA
    Joe
    Colorado Springs
    It my case the ground and body are the exact same, perfectly level.
  15. Mar 9, 2019 at 11:26 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    1/4 shim fix mine when the off road shop did my lift.
  16. Mar 9, 2019 at 3:00 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Interesting conundrum.
  17. Aug 14, 2020 at 5:40 AM
    Bigfro45
    Bigfro45 Member
    Denver
    2013 Tacoma trd sport Double cab
    Toytec alumaseries 2.0 front / rear. Rear OME mediums
    So... people have always blamed the driver side fuel tank and battery as the cause of taco lean. While this proposal is logical, I do not believe it is accurate. The lean is (on my truck) 1/2” with new springs all around, empty tank, battery removed.
    So I dug a bit further,
    I first validated I had a perfectly level surface, then grabbed 4 six ton jack stands and set them all to the exact same height.
    I then jacked up the front of the truck and set 2 stands at the exact position on the frame side to side (just behind the suspension on the frame).
    Then I jacked up the rear of the truck and put two stands in the exact same position as far back on the frame as possible (just in front of the leafs)
    It struck me immediately.
    The passenger rear of the frame was not making contact with the jack stand.
    This means that the frame has a slight twist. Specifically I measured just about 1/2”
    My truck hasn’t been wrecked, or thrashed, but does have about 125k miles.
    The way the frame is twisted would cause the lighter half of the vehicle, (without anti sway) (rear) to show the twist through the suspension.
    So.. I adjusted my driver side coil over to raise just about 1/2” which pushed the passenger rear down about 1/4”
    Front remained level side to side (anti-sway).
    I firmly believe it’s a manufacturing design to offset engine torque/traction levels, to supplement torque transfer / twist.
    I’m no expert, but I do not think the weight is the cause. ( at least in my case )
    Thoughts? Try it yourself, make sure your wheels are not touching the ground.
    Amchuge, Junkhead, GSDLVR123 and 3 others like this.
  18. Aug 14, 2020 at 5:53 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    @JoeCOVA thought the post above might interest you . Did you check yours ? Nice test @Bigfro45 .
    JoeCOVA[QUOTED] and Bigfro45 like this.
  19. Aug 14, 2020 at 6:09 AM
    JoeCOVA
    Joe
    Colorado Springs
    I was too lazy to bother with the frame after taking measurements but the test above is pretty good. Nice write up and confirms my suspicion as well. I recall reading somewhere that the Tundra also has some frame twist from the factory so it def seems deliberate.
  20. Aug 14, 2020 at 6:22 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    You know, i did the same with 4 jack stands and i was only sitting on 3. I freaked out thinking i had the truck unlevel, but my driveway is pretty damn flat. Weird...
    I'm also running dual batteries which wont help lol
