Tacoma LED Under hood light upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CDNTacoma2019, Jun 22, 2021.
  1. Jun 22, 2021 at 9:27 PM
    CDNTacoma2019
    CDNTacoma2019 [OP] Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    I picked up a universal kit from Ebay drop shipped from China for $12. Just got it and installed it earlier today. I used some 1/4" loom to protect the wire. Install was maybe 30 minutes. Tested it out tonight....will never have trouble seeing under the hood at night now!
  2. Jun 23, 2021 at 5:10 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Nice. I was about to ask how they were switched on but I saw the pin switch at the right side.
    How are the lights mounted? Double sided tape?
  3. Jun 23, 2021 at 5:44 AM
    TX_Taco88
    TX_Taco88 IG: 4lo_taco
    Jeremy
    WA
    '18 4x4 TRD-OR DCLB
    KINGS, Bruteforce armor, Falcon wheels
    got a link ?
  4. Jun 23, 2021 at 9:39 AM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    They use a switch. I mounted mine over by the headlight. It would be easy to use a toggle switch instead or hook then up to a controller if you wanted. It uses the 3M type adhesive to attach the LED to the hood. I ran the wires down through the hood....wasnt bad. I used some loom to protect the wires and give it a more OEM look.
  5. Jun 23, 2021 at 9:40 AM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    https://www.ebay.ca/itm/143918227875
    That is the kit I went with....had the 1/4" loom already but it isnt included. I would recommend using it to protect the wiring.
    TX_Taco88[QUOTED] likes this.
  6. Jul 1, 2021 at 5:58 PM
    jt13077
    jt13077 Well-Known Member
    CNY
    2021 Black DCSB TRD OR
    Did you use the existing hole or drill another for this kit?
  7. Mar 5, 2022 at 9:51 AM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Today went to add washer fluid....light isnt working. Looks like the first Canadian winter messed up the hood switch. Anybody have suggestions on a good replacement?
    Edit:
    Nevermind.....fuse holder had moisture in it and was corroded too. Pulled it all out and threw it in the trash. Chinese junk. Least not too much money wasted and took 2 minutes to remove it.
  8. Mar 5, 2022 at 11:11 AM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Just saw this older post but I used an existing hole up near the drivers headlight for the switch. No need to drill.
    Devious6 likes this.
  9. Mar 5, 2022 at 12:07 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    When I saw Ebay, China and $12, I was thinking this ^^. The pictures, when new, were impressive.
    Chew likes this.
  10. Mar 5, 2022 at 12:12 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Recently added a new one when switching to skewpt hood. The one on plain hood wasn't doin too good any more. Used existing connection and switch pin...20220217_154758.jpg
  11. Mar 5, 2022 at 12:20 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    This hole? It worked great for my set-up.
  12. Mar 5, 2022 at 12:27 PM
    Rackumrack
    Rackumrack Well-Known Member
    South Carolina
    2022 SUPER WHITE DCSB SPORT 4WD 6MT
    Its a Tacoma…. you will never need to look under the hood
  13. Mar 5, 2022 at 1:01 PM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Yes true....thats why I tossed it out. If I had a Ford I probably would but another in... Haha
    jmneill and Rackumrack[QUOTED] like this.
  14. Mar 5, 2022 at 1:02 PM
    CDNTacoma2019
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Yeah that was the same place I put mine. Your switch looks better sealed than mine was....it was already corroding.
  15. Mar 5, 2022 at 1:04 PM
    markturbo
    markturbo Well-Known Member
    Mark
    Saint John, NB Canada
    09 Tacoma
    That's awesome, nice and bright, I'll have to do the same.
  16. Jun 13, 2022 at 6:19 PM
    ViktorBreezeway
    ViktorBreezeway Brown Coat
    2017 Quicksand TRD OR DCSB
    Do you have a link to the switch you used? Looking to do this with some lights from MattGecko
    Devious6[QUOTED] likes this.
  17. Jun 13, 2022 at 6:56 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Im running the Gecko version and it’s legit. Never use it except to show off!
  18. Jun 14, 2022 at 4:37 AM
    Devious6
    Mark
    I used the switch that comes with the Matt Gecko set.
  19. Jun 14, 2022 at 8:55 AM
    ViktorBreezeway
    Thanks for the quick reply. Guess that means I don't need to buy anything else then.
    skeletron and Devious6[QUOTED] like this.
  20. Jun 14, 2022 at 9:30 AM
    Devious6
    Mark
    Correct. I mounted the switch on the battery side of the truck on the frame - there's a perfect hole. The only downside is that you have to physically turn it on/off by pushing instead of using a pressure activated switch.
