Tacoma Lift Dilema
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco-mia, Nov 14, 2009.
  1. Nov 14, 2009 at 10:40 PM
    taco-mia
    taco-mia [OP] Well-Known Member
    Maria
    Las Vegas, NV
    Tacoma 4x4 Sport
    Procomp suspension lift, tires,
    I have spent a lot of time looking for the perfect suspension lift kit for my 06 Tacoma. I am running into a couple problems but the biggest one is about how high I should go. I want to get a 4" or 6"... I have climbed into a taco w/ a 6" but never a 4". I can't make this decision without sitting in one first. So, if anyone happens to live near Santa Maria, CA, I would love the opportunity to check your 2nd gen out. I want to get this done by Christmas as a reward for returning from my recent deployment. :infantry:
    Also, if anyone wants to chime in on what kind of lift they have and the pros/cons that would be greatly appreciated. I am looking to get something that won't impair my need for moving my crap wherever the military throws me and something that allows for some decent off-roading experiences.
    You wisdom and experience is requested!:bowdown:
  2. Nov 14, 2009 at 10:52 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    also look into rcd 4in lift. imo 6in lift on a taco that i drove(fabtech with 35's drove like $&%#) i personally would stick to around 3inch coil over
    lift.
  3. Nov 14, 2009 at 10:54 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    so this is as far as my knowledge goes, but if you want to get a 4-5 inch lift out of your truck your two options are either a total chaos longtravel kit http://www.chaosfab.com/86000.html, or a suspension lift from RCD. http://www.racecardynamics.com/prod...ta/tacoma 10-47405/specsheet/tacoma5spec.html. out of those two the most practicle and least expensive would be the rcd lift
    for 6 inch lifts you have a varity of choices, the most popular being pro comp and fabtec. the problem with both the 4 inch and 6 inch lift besides the lt kit, is that you will have to cut your cross member, so you may want to consider a 3 inch lift so you do not have to do that and your lift can be easily reversable, in case you sell the truck.
    either way comfortable with out much modification you will only be able to run 33s with out much rubbing, and you could clear those tires with the three inch as well. so with that in mind if you are not planning on doing any modification to the frame mounts to clear 35 inch tires(without major rubbing) you will still have the same amount of ground clearence.
    with all of these lifts however, you can improve your ride quality by upgrading/ getting shocks
  4. Nov 15, 2009 at 1:12 PM
    taco-mia
    Maria
    Las Vegas, NV
    Tacoma 4x4 Sport
    I like the RCD kit. I don't want to go with a 3" because it doesn't seem like enough of a change to me.
  5. Nov 15, 2009 at 1:27 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    are u 4x4 or prerunner??? makes a difference in that u can get 4" spindles for the prerunner
  6. Nov 15, 2009 at 1:34 PM
    timofthehill
    timofthehill Timmy
    Timmy
    Caledon Ontario
    06 Prerunner SR5 TRD Debadged
    7" Suspension Lift, 3" Body Lift, 33's on 17's, K&N Intake, Magnaflow Cat-Back Exhaust
    I have the 6" fabtech, performance lift and I really enjoy it.. My g/f drives it. Nothing but thumbs up from other Tacoma drivers that go by. I wouldn't get 35's unless you are going to change the Diff. gearing.
  7. Nov 15, 2009 at 1:37 PM
    taco-mia
    Maria
    Las Vegas, NV
    Tacoma 4x4 Sport
    4x4
  8. Nov 15, 2009 at 1:39 PM
    jhodge83
    SC
    17 XLT Sport
    ahhh....ok....like others have said, RCD 4.5" or fabtech 6"
  9. Nov 15, 2009 at 1:47 PM
    ktmrider
    Junk
    Not big into procomp?
  10. Nov 15, 2009 at 1:51 PM
    jhodge83
    SC
    17 XLT Sport
    always heard too much crap about procomp from tires to shocks, etc
  11. Nov 15, 2009 at 1:54 PM
    ktmrider
    Junk
    i heard their tires were the shits, but i learned somehting new about their shocks now:)
