Tacoma Lift ECGS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardshelltaco7, May 18, 2021.
  1. May 18, 2021 at 9:10 AM
    hardshelltaco7
    hardshelltaco7 [OP] Member
    2007 Toyota Tacoma 4L V6
    Bilstein 5100’s all around OME 885 Coils Add a leaf ARB Full Skid Plate BFG K02’s
    Just installed a 2” Bilstein 5100 & 885 with AAL in the back in my 07 DoubleCab Sport Tacoma.
    After install I noticed the infamous “vibrations” at low speed that could be caused due to the needle bearing needing to be swapped with the aftermarket part from ECGS.
    However I hopped into my truck this morning and it is running smooth as stock again and did all the way to work. My question is, is the bearing worth replacing and are there any consequences of running it stock if the vibrations are at bay?
    Thanks in advance
  2. May 18, 2021 at 9:30 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    It's worth swapping just because it will probably give you trouble at some point in the future and it's a pretty easy job. I doubt you're doing damage running the stock bearing if it's smooth, though
  3. May 18, 2021 at 10:03 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I'd do it sooner to avoid causing serious, not-so-easy to repair damage down the road. It's a cheap and easy fix
  4. May 18, 2021 at 2:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Likely caused by difference in temps of fluids / housing etc when you felt it and didnt.
    That stated, when it does do it, flip it to 4wd (as long as you are going straight) if it goes away, ECGS n done.
    Realistically though, just do the ECGS bushing n call it good.
  5. May 18, 2021 at 4:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    nd4spdbh likes this.
  6. May 19, 2021 at 4:50 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    don't chance it. replace the needle bearing.
  7. May 23, 2021 at 1:05 PM
    Marvet85
    Marvet85 Well-Known Member
    2021 Tacoma TRD Off-road
    Just starting.
    Just swapped mine out this morning with @a2lowvw and holy shit, it feels factory again. Hope it works out.
    a2lowvw likes this.
  8. May 28, 2021 at 5:27 PM
    hardshelltaco7
    Thanks everyone, replaced it for the ECGS and new seal and it runs like factory again
    hoffengineering and ardrummer292 like this.
