Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Jan 25, 2013 at 12:08 PM
    #401
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Best I got after 2.5" lift on a DCLB 4WD with stock UCAs was 1.3* of caster. Barely "in spec" and drove like ass.
    Maybe with a spindle lift?
  2. Jan 25, 2013 at 12:15 PM
    #402
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I have a full 3" OME lift with stock UCAs. Caster is just out of spec but it drives fine.
    It depends on how much you lift it.
  3. Jan 25, 2013 at 10:21 PM
    #403
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    I've heard that anything over 2.4 is good. I could be wrong, but that should be feasible with stock uca's
  4. Jan 26, 2013 at 9:53 AM
    #404
    JonnyBb
    Arkansas
    ^^^this
  5. Jan 28, 2013 at 5:36 AM
    #405
    ToyTacosRule
    ToyTacosRule Well-Known Member
    Dane
    Texas
    4x4
    I have been looking around on the web and cant seem to find too many sites that sell the Eibach springs, any suggetions on which site has them for the best price? Prob going to be Toytec but figured I would ask. Also I saw a thread that said in like October of last year these springs were on backorder, are they still on backorder?
  6. Jan 28, 2013 at 7:36 AM
    #406
    Shipwreck
    Shipwreck Well-Known Member
    Johan
    Centennial CO
    2016 TRD Off Road Tacoma
    Stock
    This is really good info, thank you guys. I do have a question or two...
    1) I am thinking about installing the Bilstein 5100 Racing series shocks front and rear including a 1" or 1.5" spacer in the back and setting the fronts to maybe 1.75" or 2.5". Will I need anything else with this set up to avoid coil bucket contact or would I need the diff drop spacers like in the 1st gen tundras?
    2) Would I need to replace the coil springs too?
  7. Jan 30, 2013 at 10:49 AM
    #407
    banditstpk
    banditstpk Pabst knows best
    patrick
    buckeye arizona
    00 3.4L PreRunner TRD SR5 Xtracab
    deck plate, led lights interior, center hubs painted black,
    quick question.. only because i havent seen anyone talk about it. when you lift your truck i would assume you would have to lengthen the part that attaches to the steering linkage is this true? just makes sense to me.. if not then im over thinking some things..
  8. Feb 2, 2013 at 1:21 PM
    #408
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Will someone please spare me 21 pages of reading and help me out?
    My mechanical skills/knowledge are maxed out at oil changes. I could probably get my brother to do the labor if this isn't extremely complicated.
    That said, I have an '08 DC TRD OR and I want to get a 3" lift. Les Schwab offers a lift kit from Tuff Country(I think) for $621 total. I think it's this...
    http://www.suspensionconnection.com/cgi-bin/suscon/52907.html
    Does anyone here recommend Tuff Country or should I avoid this kit?
    Also, it seems the majority here prefer Bilstein 5100's. Am I correct in thinking this involves replacing only shocks on the front then adding an AAL for the back...or is it more complicated than that?
    I admit I am ignorant on these things, so I appreciate any help I can get. Thanks in advance.
  9. Feb 2, 2013 at 1:29 PM
    #409
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    To my knowledge toytec is the only authorized dealer of eibachs. They were the only place I was able to order mine.
  10. Feb 2, 2013 at 1:39 PM
    #410
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    2) Would I need to replace the coil springs too?[/QUOTE]
    1) Don't bother with the diff drop!
    2) Coils will improve ride but isn't necessary
    3) you shouldn't have any issue with coil bucket contact
    4) setting 5100's at 1.75 w/tsb pack will put you at a level stance so its up to you if you want to add lift to the rear (if you want rake then I recommend it)
  11. Feb 4, 2013 at 12:20 AM
    #411
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
  12. Feb 7, 2013 at 1:35 PM
    #412
    phatso
    Eastern Washington
    2017 Cement Pro
    Let me try this again...I need help...please...
    I have an '08 TRD OR DC and I want a 3" lift.
    Am I right in thinking this kit would be all I need?
    Also, what do you guys recommend for the rear option?
    Rear Options: Choose below
    TAC-AL Toytec standard 2" lift add-a-leafs with anti friction pads
    TAC-AL-TSB Toytec TSB 1.5" add-a-leafs for use with 4 leaf rear springs
    1 1/2" blocks with U-bolts
    1" blocks with U-bolts
    C476 rear Bilstein 5100 shocks
    Thanks in advance
  13. Feb 7, 2013 at 2:34 PM
    #413
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    The kit will be fine. It's pretty much what I'm running. Don't put the diff drop in it will do nothing for you, and I'd go with the aal. The 2" aal is for non tsb springs; the 1.5 aal is for the tsb springs.
  14. Feb 7, 2013 at 5:35 PM
    #414
    phatso
    Eastern Washington
    2017 Cement Pro
    I was wondering about the diff drop, thanks.
  15. Feb 8, 2013 at 2:12 PM
    #415
    Caveman75
    Caveman75 New Member
    Trevor
    North Carolina
    00 Tacoma
    I've been seeing some people say use the diff drop and some saying not needed. I am putting a 3" suspension lift on my 00 Taco, should I use the diff drop or or is it a waiste of time to install it.
  16. Feb 8, 2013 at 5:21 PM
    #416
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Do it on a first gen. Second gens are basically pointless do do a diff drop, but you should on a 1 gen
  17. Feb 8, 2013 at 6:02 PM
    #417
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Don't quote me but I think the diff drop is beneficial on the 1st gens.
  18. Feb 9, 2013 at 9:21 AM
    #418
    phatso
    Eastern Washington
    2017 Cement Pro
    If I go to a 3" lift and run 285/75/16 on my stock TRD OR rims will I need to spend a couple hundred on spacers too?
    Is this the recommended spacer...1.25" spidertrax hub centric spacers?
    Is there no other option than to buy spacers?
  19. Feb 9, 2013 at 9:28 AM
    #419
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes
    Yes
    New wheels.
  20. Feb 9, 2013 at 9:31 AM
    #420
    phatso
    Eastern Washington
    2017 Cement Pro
    That's what I was afraid of...thanks
