Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Feb 9, 2013 at 9:58 AM
    #421
    DR RosenBomb
    DR RosenBomb Member
    Dylan
    Topanga Canyon, Ca.
    07 TRD Offroad 4x4
    hey guys... so just got a 07 trd, the guy has 265/75/16 on it. like them, but the rub just a little bit (mud flaps are off) plan on doing some off-roading, so this may be a problem?
    My question is with leveling kit, (putting 5100's in the front) fix this for me? ... Think i read somewhere to set them at 1.75, is that right? .. Any input appreciated, new here, just learning bout my truck. thanks
  2. Feb 10, 2013 at 10:56 AM
    #422
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    I was gonna go with this^^^
    but after reading through some threads, I think I'm ready to pull the trigger on this...
    Complete Old Man Emu suspension for 2005 & UP Tacoma
    Includes:
    - (2) Front OME 90000 sport shocks (Replaces the OME N140S front shocks)
    - (2) Front coils-885 coils for D-Cab and additional front weight
    Add top plate spacers in drop down below for a full 3" front lift with 884 and 885 coils
    Rear
    - ToyTec standard 2" add-a-leafs. Comes with (2) new center bolts
    - (2) Rear 60091 Nitrocharger Sport Shocks (Replaces N182 shocks)
    - (1) OME trim packer to be installed on the driver side to help level your Tacoma side to side.
    In addition, I've been to some tire shops and one said they did NOT recommend putting 285/75/16 on my stock TRD OR rim, because the tire will crown. Are they correct and is it a big deal? Could I lower the air pressure to prevent wearing out the tire too quickly?
  3. Feb 10, 2013 at 3:51 PM
    #423
    phatso
    Eastern Washington
    2017 Cement Pro
    If I buy the FJ trail team replicas...will that eliminate the crowning issue AND will I still need to buy wheel spacers?
    I apologize for flooding this thread with so many questions...I just want to make sure I have everything I need
  4. Feb 10, 2013 at 5:30 PM
    #424
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Trail teams do not have the same offset as trd sport wheels. Trd sport wheels are +38 or thereabouts.
    The trail teams wheels have the idea specs for fitting 285s. Will still need to trim though.
  5. Feb 15, 2013 at 7:37 PM
    #425
    phatso
    Eastern Washington
    2017 Cement Pro
    I should get my OME lift with aal tomorrow...gonna install myself...does it matter if I do the front or rear first?
    I don't have much help available tomorrow and the rear seems easier, so I figured I'd start with the rear and save the front for Sunday when I have some help available.
  6. Feb 16, 2013 at 5:00 AM
    #426
    T1no33
    T1no33 Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    Where did you get the lift and what did you pay please?
  7. Feb 16, 2013 at 5:17 AM
    #427
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    With no suspension experience and just two people watching/handing tools/making sure I didn't kill myself I did my lift in about 5 hours one day. However, I started with the rear too as, like you, it seemed easier to me leaving more time to fuck around with the front if I had trouble (and I did).
    ^what he said. I would have a spare jack (mine broke doing my lift), extra jack stands (at least 4 anyway), a center punch (used to line up the eyelet on the front struts with the LCA), air tools, full socket set, lots of WD-40/PB Blaster or a custom mix of 50/50 ATF/Acetone.
    What? ATF/Acetone you say? :D A buddy sent me this, and I need to make up a batch. lol
  8. Feb 16, 2013 at 5:48 AM
    #428
    phatso
    Eastern Washington
    2017 Cement Pro
    After shipping and the discount code from the vender forum I paid around 850.
  9. Feb 16, 2013 at 5:52 AM
    #429
    phatso
    Eastern Washington
    2017 Cement Pro
    Thank you for all of that info.
  10. Feb 16, 2013 at 11:11 AM
    #430
    T1no33
    Spring Hill, Fl
    Thanks for info. Shopping around myself.
  11. Feb 18, 2013 at 11:03 AM
    #431
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    I have a rear leaf question, that may be stupid but I'm gonna ask it anyway. Can I replace my weak-ass rear 3 pack on my 2012 OR with the 4 pack off of a sport or SR5. If so would it be worth it?
  12. Feb 18, 2013 at 11:26 AM
    #432
    BDJ
    Brandon
    West Monroe
    Thanks, I'm just sick of not being able to hawl anything, and the dealership isn't helping. I plan on getting a lift when I need new tires and will change everything but until then I need a fix. It's a shame, I pay $32,000 for a truck that can't even hawl my 14 foot boat without bottoming out on bumps.
  13. Feb 22, 2013 at 3:14 PM
    #433
    banditstpk
    banditstpk Pabst knows best
    patrick
    buckeye arizona
    00 3.4L PreRunner TRD SR5 Xtracab
    deck plate, led lights interior, center hubs painted black,
    ok quick question.. when reinstalling the new front struts/coils back onto the truck i keep reading that it takes some weight and some prying to get the lower strut mount back into mounting location... would you be able to use a spring compressor to loosen the tension on the spring and get the lower mount to align easier? or is that not possible?
  14. Feb 22, 2013 at 5:51 PM
    #434
    TexasTacoma37
    You won't be able to fit the coilover assembly back in with spring compressors on it.
  15. Feb 22, 2013 at 5:57 PM
    #435
    scocar
    scocar Patron of the Farts
    Use an inverted bottle jack under the fender to push down on the top of the UCA. I managed to do mine without that, but I swore A LOT and called it many names.
  16. Feb 22, 2013 at 6:39 PM
    #436
    banditstpk
    patrick
    buckeye arizona
    that makes sense now that i think of it that way
    thanks for the heads up that seems a lot easier than pushing and prying
  17. Feb 25, 2013 at 6:40 PM
    #437
    tacobrumz
    tacobrumz Active Member
    Tacoma
    Total Chaos Dual Shock with spindle gussets
    FYI TC includes stainless steel uniballs for their UCA's and Long Travel
    "Total Chaos includes uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and longevity. The uniball also features a woven fabric Teflon liner that helps prevent noise"
  18. Feb 26, 2013 at 11:49 PM
    #438
    01kingtaco
    01kingtaco Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    im puting in my 3 inch ome lift this weekend with 883 coils and dakar leaf packs with light racing upper control arms. i was wondering with the new ucas there fully adjustable. and i want to move the wheel center forward to not have to trim as much on the cab. what should i set my new upper control arms too to acheavie this mind u that with the new arms setting the arms at 0 will actually acheave +2.0 degrees of caster.
  19. Mar 12, 2013 at 10:06 PM
    #439
    Ulysiss
    Ulysiss Well-Known Member
    Ulysiss
    La Puente, SGV
    2013 Long Bed, PreRunner, TRD Sport
    IM LOOKING TO GET A 3'' LIFT ON BOTH FRONT AND BACK ON MY 2013 DC/LB/TRD
    I WANT THE BEST MONEY CAN BUY CAN SOME ONE HELP ME?
  20. Mar 12, 2013 at 10:22 PM
    #440
    Sport2012
    Sport2012 Thin Blue Line
    NJ
    12 TRD Sport DCSB 4x4
    Tint, EGR In Channel visors, Access-Lorado tonneau, Tacoma bed mat, Plasti Dip Badges, Tailgate mod, Fog light anytime mod, Toytec (TTHA-CK) 3" lift kit w/height adjustable coilovers, 5100's w/Eibach coils, TSB AAL, LR UCA's, CB drop kit, Diff drop kit, XD spy's on 285/70/17 Duratrac's
    Check out Toytec at Toyteclifts.com You can choose from many lift kits, such as Toytec, OME, Icon, etc. As well as UCA's. One stop shop. Discount given to TW members. If you call ask for Jeff at ext. 107.
