Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Jan 24, 2014 at 10:37 AM
    #801
    rruhl48
    rruhl48 Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    Can any one send me a link.to nice black rims and beefy 32s adding bilstien 5100s and possibly Fox shocks in test with add a leef depending on the stance tow allot so might happen any way. Any advice on what else to change with those 5100s thanks
  2. Jan 24, 2014 at 2:39 PM
    #802
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    5100/887, Dakars, 285s, Built Right UCAs, Icon rears
    It settled to 3" total front and rear. I found the ride to be pretty stiff with my PSI up at 35 all around. Took it down to 32 all around and the ride is sweet, and I've broken them in with trail driving. Perfect blend of stiffness and softness to feel like a real truck! Before it felt like a boat/sedan (too soft and bouncy for me). The lift made it super nose high until I did the 1.5" HD AAL set on top of my 3 leaf OEM pack (stock off road bilsteins, not aftermarket). Now it's level. I chose the 887s under YotaDan's advice because of my weight up front (beefy BAMF sliders and Relentless IFS skid), he wanted me to get my full 3". And I am running stock UCAs, haven't noticed any wandering issues.
  3. Jan 24, 2014 at 4:16 PM
    #803
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Can't help you with wheels but Goodyear Duratracs are pretty nice, beefy tires. 265-70-17 or 265-75-16 are about a 32" tire.
  4. Jan 24, 2014 at 4:24 PM
    #804
    wuzzy121
    wuzzy121 Well-Known Member
    Colorado Springs
    05 AC 3" lift
    ARB front bumper w/ Warn M8000 winch and lights, 3" lift, Tire gate tire carrier, All-Pro Expedition leaf springs, weather tech floor mats.
    Look for rims on ebay. That's where I found some good ones for cheap.
  5. Jan 24, 2014 at 10:22 PM
    #805
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Just read through the OP and trying to confirm some things.
    A 3" coilover lift will reduce travel comppared to factory suspension? Is that a good or bad thing?
    The only way to increase ground clearance is with bigger tires?
    Also the OP said the 3" lift and 285s is mainly for aesthetics, is stock suspension and 265s considering good for most off-roading purposes?
  6. Jan 24, 2014 at 10:31 PM
    #806
    wuzzy121
    Colorado Springs
    05 AC 3" lift
    The 3" lift will only give you 1" more travel. Look around and don't be afraid to ask questions about stuff. Icon has extended travel coilovers for the front that are supposed to be really good, but they are expensive. There are a ton of options out there you can put together to make what ever you want. And again don't be afraid to ask questions.
  7. Jan 25, 2014 at 1:25 PM
    #807
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    There's a lot to consider in what product you'll use to get lift, and what benefits or negative effects that product may have. You need to have a budget in mind. What will the truck be used for.
  8. Jan 25, 2014 at 1:28 PM
    #808
    bjboucher
    Brad
    San Antonio, Texas
    The lift doesn't reduce travel, per se. It does reduce the amount of down travel though. There's only so far the front end can drop so if you lift it, you lose some of the down travel.
  9. Jan 25, 2014 at 7:11 PM
    #809
    TacoBrah
    Sean
    Yeah Im thinking for now I will stay stock suspension. Its mostly a daily driver with some beach driving, and off-roading a few times a year.
  10. Jan 25, 2014 at 7:13 PM
    #810
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    BUTTTTTTT the ride is waYYYYYYY better my friend
  11. Jan 25, 2014 at 8:53 PM
    #811
    TacoBrah
    Sean
    What do you mean?
    Can I do a 3" coilover lift and set it at factory height?
  12. Jan 25, 2014 at 8:56 PM
    #812
    wuzzy121
    Colorado Springs
    05 AC 3" lift
    As long as you get adjustable coilovers you can.
  13. Jan 25, 2014 at 9:18 PM
    #813
    TacoBrah
    Sean
  14. Jan 25, 2014 at 9:22 PM
    #814
    wuzzy121
    Colorado Springs
    05 AC 3" lift
    You will see on coilovers that they will say adjustable from 0 to whatever the max is. So you should be able to adjust them and level out your truck without doing to much more, I would recommend changing out your rear shocks to 5100s too. I got the 3" to 4" above stock 5100s and put them on today to go with my all pro expo leafsprings.
  15. Jan 25, 2014 at 9:29 PM
    #815
    TacoBrah
    Sean
    Nice, how hard was it to install? Did you need to drop your front diff?
    I cant seem to see the difference in the two I linked previously, they both say adjustable with 5100ss, but one is $300 less.
  16. Jan 25, 2014 at 9:48 PM
    #816
    wuzzy121
    Colorado Springs
    05 AC 3" lift
    I only did the rear so the front diff didn't come in to play at all.
    I picked them up at toytec and the guys there were really nice.
    If you aren't sure what you want just give them a call and talk to them.
    They will help you figure out exactly what you want or need then ship it to you.
    I have only gone about 2 1/2" in the front so I didn't do a diff drop yet. But since my back end is about 4" I'm going to have to go with longer coilovers in front and that will make me get a diff drop to keep the angles right so I'm not tearing CV boots.
    I'm dreading the diff drop cause then I need a different skid plate made for the diff drop and the skid plate I have on now is only a few months old.
    So take it from me and think way ahead to what you want it to be so you don't over spend in the long run.
  17. Jan 26, 2014 at 5:11 PM
    #817
    TacoBrah
    Sean
  18. Jan 26, 2014 at 5:31 PM
    #818
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
  19. Jan 26, 2014 at 5:34 PM
    #819
    wuzzy121
    Colorado Springs
    05 AC 3" lift
  20. Jan 26, 2014 at 5:56 PM
    #820
    TacoBrah
    Sean
    The Dakers? I was gonna just get the aal because for now I will be using this setup just to level, so I wasnt gonna do anything to the rear beyond replacing the shocks.
    Is it hard to adjust by yourself?
