Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Sep 9, 2015 at 5:31 PM
    #1021
    Gply
    Gply Well-Known Member
    Bay Area, CA (east bay)
    2015 Tacoma DC TRD off-road
    More shit then I ever planned on doing
    Does anyone know if Icon UCA's will help correct alignment issues like the Total Chaos UCA's?
  2. Sep 14, 2015 at 5:30 PM
    #1022
    Cwheeler3365
    Cwheeler3365 New Member
    Corey
    2015 Black Tacoma SR
    What's the biggest lift you can put on your truck before you have to change anything, or extend anything. Like is a 1.5 inch or a 2 inch lift/leveling kit
  3. Sep 14, 2015 at 6:45 PM
    #1023
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I think it's actually 3
  4. Sep 21, 2015 at 1:21 PM
    #1024
    mtnbiker310
    mtnbiker310 Well-Known Member
    Parker, CO
    '12 Offroad Tacoma
    TRD Cat Back Exhaust, Jumpers LED's interior, Hella 5000 behind grill, Custom grille
    If I plan on putting on some cooper at3 285/70/17's with the procomp 7032 17" wheel, on my truck (prerunner edition 2wd) What is my best option for getting those 3"? I have been looking at the ome 885, or 887's and the bilstein 5100 adjustable struts, and rear 5100 shocks, with the wheelers 1.5" AAL...
    1) Is there a more cost efficient route?
    2) Is shipping from wheelers to southern california going to break my wallet?
    3) Can I get away without some of the parts? such as the coils? or the AAl?
    4) Better rim option that is more cost efficient?
    I am getting a deal on the tires which is why I am throwing them in there.
    Anything helps!
    Thanks in advance
  5. Sep 21, 2015 at 3:42 PM
    #1025
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
  6. Sep 22, 2015 at 8:50 AM
    #1026
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    Thank you @TucTaco520 I appreciate the help! I would be getting the wheels for $130 a wheel, there are a few options for bolt patterns and I am not sure to which I would use, this is my first time changing the wheels on a vehicle, usually just kept the stock wheel.
    But in this case I have heard that a 16" wheel would look silly, kind of like the dues that skip leg day at the gym, with this lift...
  7. Sep 23, 2015 at 8:21 AM
    #1027
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    hey man I went with 5100s with 887 coils and headstrong light racing uca. Pretty cheap all shipped to san diego and the ucas were on sale I paid like 275$ total for all that and an aal was like $900 gave 3 inch in the front and 2 in back so my back is about .75 inch higher but will settle I imagine
  8. Sep 23, 2015 at 9:40 AM
    #1028
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    did you go through wheelers? $275 was the shipping cost? what is the benefit doing 887 vs 885? do you have a heavy bumper or wench? trying to avoid the all expensive uca right away...
  9. Sep 23, 2015 at 9:46 AM
    #1029
    Pirhett
    Rhett
    San Diego
    Stock...
    275$ for uca is cheap man, 887 gives you full 3inch lift plus will help when I get skids and all. I did everything through headstrong
  10. Sep 23, 2015 at 10:38 AM
    #1030
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    okay i got you, i was confused prior thought you meant 275 for shipping, yes 275 is a hell of a deal! what size tires were you able to put on with that kit
  11. Sep 23, 2015 at 10:39 AM
    #1031
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    do you have a picture of your set up?
  12. Sep 24, 2015 at 8:39 AM
    #1032
    mtnbiker310
    Parker, CO
    '12 Offroad Tacoma
    Do you think there would be a way to keep my stock wheel? instead of replacing the wheels for 17" wheels, maybe a 285/75/r16, or 305/70/r16... I am not a tire pro, so I am not sure what would be best or what would the difference be...
  13. Sep 24, 2015 at 9:08 AM
    #1033
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    You might get away with it with some wheel spacers but you run the risk of rubbing your UCA due to improper backspacing. If you have 285/75/16s with stock UCAs, 99% sure you're going to rub pretty bad on the cab mount/fender/pinch weld because you cant get enough caster w/o aftermarket UCAs.
  14. Oct 3, 2015 at 8:32 PM
    #1034
    Jgerm
    Jgerm New Member
    2013 White Texas edition Tacoma
    3" RC Lift 33" Nitto Trail Grapplers 17" XD Monster II wheels
    Anybody know about putting a 6" lift on a 2wd 2013 prerrunner?
  15. Oct 11, 2015 at 2:45 PM
    #1035
    whirlydude
    whirlydude Member
    Arizona
    07 4Door SHORTBED
    I read that once you get over 3" of lift you can run into problems with the CV boots wearing and tearing.
    What can be done to avoid this
  16. Oct 11, 2015 at 3:03 PM
    #1036
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Just did a Spindle lift with Fox COs
    Dakars W/ex leaf & 1/12"Blocks for the rear sits right at 6
    If you have prerunner spindle lift is the way to go
  17. Oct 11, 2015 at 7:35 PM
    #1037
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Boot slide mod or weld a new diff on
  18. Oct 12, 2015 at 4:08 PM
    #1038
    backwoodsbob
    backwoodsbob Member
    Bobby
    Suffolk,VA
    2011 tacoma 4x4 trd
    Well after multiple days have reading all the 3inch lift threads I finally pulled the trigger and ordered the OME/ToyTec 3" lift kit, with the dakar leaf packs. Cant wait to get it and install it.
    fletch97 and TucTaco520 like this.
  19. Oct 20, 2015 at 6:26 PM
    #1039
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
    good info
  20. Nov 4, 2015 at 5:14 PM
    #1040
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Have a question, is the stock offroad bilsteins shocks give any lift compared to the SR5 shocks?
