Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Mar 7, 2017 at 6:04 PM
    #1121
    MasterYODA2017
    MasterYODA2017 Active Member
    Charles
    2017 TRD Sport
    I recommend getting the new bilstein 6112's and 5160s. It'll ride like butter plus you can adjust to compensate for the "taco lean". Just my 2 cents
    07tacomatoy likes this.
  2. Mar 7, 2017 at 6:05 PM
    #1122
    MasterYODA2017
    Charles
    2017 TRD Sport
    ***ICON AAL, and you can fit 265's stock btw..aim for some 285 70 r17s!
    lynyrd3 likes this.
  3. Mar 14, 2017 at 8:36 PM
    #1123
    NorthGeorgiaTaco
    NorthGeorgiaTaco Well-Known Member
    Joshua
    Chatsworth, Ga
    2015 Tacoma SR5 Prerunner MGM
    I'm not sure if this is the place to ask this but here goes. So sometime down the road I'm planning on getting a plate bumper. I currently have 3" spacers in the front. My question is what coilovers are strong enough to maintain that amount of lift? What would you guys recommend?
  4. Mar 14, 2017 at 8:53 PM
    #1124
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    Are you looking at doing away with the spacers and doing a coil over lift? Just trying to make sure I understand your question completely.
    Also are you planning on going with a steel or aluminum bumper? Skids, sliders, or winch?
    All these will play into your decision of the weight rate of the coils?
  5. Mar 14, 2017 at 9:08 PM
    #1125
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    If I can still keep the height I'd like to do away with the spacers. I'm looking at the pelfreybilt steel bumper, a winch, and sliders.
  6. Mar 14, 2017 at 9:29 PM
    #1126
    CountryDan
    Daniel
    Calhoun GA
    It's doable. Sounds like you will want to go with700lb coils(imho). As far as what brand of shocks, that depends on your budget. It appears a lot of the guys go with old man emu (ome) or you can go more higher end and go icon or kings. You will also need new upper control arms.
  7. Mar 14, 2017 at 9:53 PM
    #1127
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    What I should have asked first is if I mess with the suspension is that going to void my warranty?
    Also if I get new UCAs do I have to get new lowers too?
  8. Mar 14, 2017 at 10:00 PM
    #1128
    CountryDan
    Daniel
    Calhoun GA
    Mods should only void the warranty of the parts and/systems modded.
    you won't have to do the lowers. One of the biggest reason for doing the uca's is for alignment purposes.
    NorthGeorgiaTaco likes this.
  9. Mar 14, 2017 at 10:01 PM
    #1129
    MasterYODA2017
    Charles
    2017 TRD Sport
    1.) I personally am against front spacers and\or any type of block in the rear... axle wrap and blah blah. For a few hundred dollars more you could do billy 5100s front and rear for like $300 get 2.5 or so inches and clear 285s...or get the newer 6112 and 5160 billys and maybe an aal. Better ride then blocks and spacers
    2.) don't need new UCAs imo unless you go over 4 inches (then new gear come into play)
    3.) this is all just my opinion. Not a fan of cheap lifts , I've ever looked into icons and ect but the new Billy's are butter.
  10. Mar 14, 2017 at 10:18 PM
    #1130
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    Well see, this is my first Tacoma and no one else I know has one so it's all new ground for me. That's why I ask so many stupid questions on here.lol As I've learned more about all things Taco I'm wanting to switch them out for something that's beneficial to my truck. That's why I posted here cause I need input on what will help me keep my ride height/run 285/75s. My problem now is that I have ZERO knowledge about when/why I'll need UCAs
  11. Mar 14, 2017 at 10:23 PM
    #1131
    NorthGeorgiaTaco
    Joshua
    Chatsworth, Ga
    Thank you sir! I'll ask Toyota a bunch of questions the next time I get my oil changed. I'm the mean time I'll be looking into Billisten, OME, Total Chaos etc. I don't plan on going any bigger than 285s and from the best that I can tell I should be able to run those with minimal scrubbing. As long as I can clear those and keep ride height I'll be a happy camper.
  12. Mar 15, 2017 at 10:30 AM
    #1132
    MasterYODA2017
    Charles
    2017 TRD Sport
    Usually new UCAS are due to wheel spacing or rubbing when turning ect
  13. Mar 16, 2017 at 7:26 PM
    #1133
    tacollie
    tacollie Member
    Colorado Springs
    09 TRD Off-road, auto
    Flippac, wheelers HD springs with OME d29xl, Bilstien 5100 all around.
    I may have missed it but is there a difference the progressive aal? Is there any reason to buy one over the other? I can think of 6 different options right now. I don't need u-bolts. Are any of them better for loads or flex? I had the Icons on my last truck but i have no clue if they are worth the extra ~$60 over the wheelers.
  14. Mar 16, 2017 at 10:27 PM
    #1134
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Someone has posted before that icon, wheelers and the headstrong progressive aal's were all made by the same manufacturer .
  15. Mar 17, 2017 at 6:05 PM
    #1135
    tacollie
    tacollie Member
    Colorado Springs
    I have heard that but being made in the same facility doesn't mean they are made to the same specs. I was just curious if there was a difference between any of them since there are so many of the same thing.
  16. Mar 18, 2017 at 8:48 AM
    #1136
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    Any idea why a carrier bearing drop isnt a good idea (driveline drop not front diff drop) as sais in the OP?
  17. Mar 19, 2017 at 3:17 PM
    #1137
    Criley530
    Criley530 Active Member
    06 Tacoma
    Who knows?
    I have 33s 06 double cab. Want a better ride . its all over the road leans to driver side front and back. Front suspension is really what i want what do you have? send pics and what it cost to do it and hows the ride after? thank you guys
  18. Mar 20, 2017 at 3:26 PM
    #1138
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Asking here since I dont know where to ask. I am wondering for the couple days my icon rear shocks are being rebuilt can I run stock 2017 trd sport shocks? A buddy of mine is letting me barrow his and Im curious if I will be topping or bottoming out with my dakars and shackle flip (3-4 inch of lift)
    @GHOST SHIP @goblue82 @Acerwin @nfs257
    :notsure:
    @chris4x4 @Tretiak30
    goblue82 likes this.
  19. Mar 20, 2017 at 3:29 PM
    #1139
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    I already told you, brother. You don't need shocks on pavement for a couple days. Your leafs will do just fine.
    nfs257 likes this.
  20. Mar 20, 2017 at 3:29 PM
    #1140
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Honestly, you'll be fine for street driving. The shock will be your limit strap and your bump stop for the time being so no off-roading or unnecessary flexing unlkess you don't give a fuck about the stock shock. I did the same thing when I had mine serviced. Icon had them back to me in less than a week.
    Worst case scenario, you can run shockless, but your rear end will be bouncing all over the place. Not ideal, but possible if you change your driving style for the time being.
    Pirhett[QUOTED] likes this.
