Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Mar 24, 2017 at 10:57 AM
    #1161
    CountryDan
    CountryDan Well-Known Member
    Daniel
    Calhoun GA
    15 TRD PRO DCSB 6 spd
    a lot of bad ass stuff
    No problem joe.
  2. Mar 24, 2017 at 2:11 PM
    #1162
    CountryDan
    Daniel
    Calhoun GA
    I went with dakars to replace my factory leaf set. Originally wanted the all pro expos but got tired of waiting on them to get back in stock. No complaints on the dakars, (from me yet)and I do carry a constant load with a shell, HC bumper, bed platform, etc.......
    I have read good things about Deavers though.
  3. Mar 24, 2017 at 5:26 PM
    #1163
    MonoJoe
    MonoJoe Well-Known Member
    Joe
    Easy Bay (aka the 510)
    2017 Tacoma SR5
    Bilstein 6112 kit with 5160 in back. Goodyear Duratrac LT265 75 r16's
    I am going with Deavers.
    CountryDan[QUOTED] likes this.
  4. Mar 29, 2017 at 5:28 AM
    #1164
    AUTaco
    AUTaco Well-Known Member
    Todd
    Baton Rouge, LA
    2016 White Toyota Tacoma SR5 4x4 DCSB TSS Sport Package with 17" rims
    Raptor Style Grill , tonneau cover. 1 1/2 inch lift with Bilsteins all around.
    Probably been answered already but installing tomorrow need some advice. Putting adjustable 5100's on front set at 2" & 5100's in rear with 1" lift block. Will this level the truck out & would I need to use diff drop.
  5. Mar 29, 2017 at 5:44 AM
    #1165
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    You will more than likely be 1"high in the rear. Diff drop is a waste of money.
  6. Mar 29, 2017 at 5:49 AM
    #1166
    AUTaco
    Todd
    Baton Rouge, LA
    Took pre install measurements and the front is 1" lower than the rear. So you are saying 2" in front lift and 1" in back lift would make it still 1" high in back. Just trying to be sure.
  7. Mar 29, 2017 at 6:36 AM
    #1167
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    If you use the quote function or tag someone like @AUTaco it works a little faster. I think most trucks are more like 1.5-1.75 rake. The trd pros come lifted 2" ish I think. That's front only. Most leveling kits are 1.75-2" front lift. Not all Tacomas are the same for sure. I'm pretty sure it depends on which drunk put it together so they are all a little different. Did you measure both sides?
  8. Mar 29, 2017 at 6:46 AM
    #1168
    AUTaco
    Todd
    Baton Rouge, LA
    Yes the drunk that worked on mine got real close. 1" shorter in front than back.
  9. Mar 29, 2017 at 6:48 AM
    #1169
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Sounds like you have a winner then.
  10. Mar 31, 2017 at 7:02 PM
    #1170
    J011YGR33N
    J011YGR33N Active Member
    2016 Sport Double cab long bed
    I've been running that size tire in KO2s on stock suspension for a little over a year now and have never had rubbing
  11. Mar 31, 2017 at 7:12 PM
    #1171
    J011YGR33N
    I have had the FabFours premium front bumper and Expedition one rear on mine for about a year now on stock suspension. Both bumpers are 3/16" steel and I have had no suspension issues. Do your self a favor and get what ever you buy sprayed with linex premium, the powder coat started getting surface rust along the welds after only being on for about 6 months.
  12. Apr 8, 2017 at 9:48 AM
    #1172
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Any links to install bigger coils on my icons?
  13. Apr 9, 2017 at 8:35 AM
    #1173
    phreddyfoo
    phreddyfoo Well-Known Member
    Indiana
    Hey Folks, I want to do a modest 2" lift, I plan on pulling a bass boat and I don't off road much. Can I do this with 5100's or spacers and AAL's? I have a 12 TRD double cab.
  14. Apr 9, 2017 at 9:57 AM
    #1174
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    5100 with 884x or headstrong offroad coils (if you're a dcsb 4x4), single AAL and/+ sumosprings rear bumpstop or airbags to supplement the rear for towing. Depending on budget you may want to replace the current leaf pack with a good aftermarket ones like Dakar's. I say PM Marie @HeadStrong Off-Road
    HeadStrong Off-Road likes this.
  15. Apr 10, 2017 at 7:06 AM
    #1175
    Blze001
    Blze001 Breaks things.
    Virginia
    2013 TRD Sport DCSB
    Question guys: my 2013 DCSB has rear leaf springs that are pretty much dead flat and starting to bottom out (thanks Toyota), so I'm looking for suspension options and I'm getting a little confused. I know add-a-leaf kits just bandage the problem for a year or two, so I'm looking at proper rear replacements. My truck has a cap on it at all times, usually about 50lbs worth of junk, and tows a camping trailer a few times a year.
    Plan #1: Wheelers 5-leaf, OME-884 front, Bilstien 5100 shocks. I really don't care about lifting, just want more hauling ability and springs that are actually, y'know, truck springs. Then I started finding complaints about the 5-leaf packs wearing out/breaking after a year or so.
    This lead to
    Plan #2: Lift kit. OME or All-Pro, I hear great things about these lifts and their carrying ability. 2-2.5" isn't much, I can probably still squeeze into 90% of the parking garages around here. But apparently doing that means you also have to deal with front diff drops, driveshaft shims, ucas, etc?
    My question is: is there a reliable way to replace the rear leafs with proper, stiff truck springs and generally upgrade the quality of the suspension that doesn't involve mass replacements of other parts?
  16. Apr 10, 2017 at 7:10 AM
    #1176
    J011YGR33N
    Have you checked into the OME leaf packs? you can lower the height adjustment by removing one of the leafs according to the site.
  17. Apr 10, 2017 at 8:18 AM
    #1177
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Easy lift would be 885's on 5100's or OME shocks. That will get you around 2" up front. You won't need uca's for that. Dakar leaf pack with the long overload leaf removed. Will get you around 2" lift with all the capacity of the Dakars still intact. You will probably need to shim carrier bearing and or rear diff.
    J011YGR33N likes this.
  18. Apr 10, 2017 at 10:48 AM
    #1178
    Blze001
    Virginia
    2013 TRD Sport DCSB
    So would the OME kit from ToyTec be a good choice? 885 coils, 90021 shocks, CS047R leafs. I'd get the OME carrier bearing shim too, it's $12 so might as well. Would I need the front diff drop, or is that only needed with the top spacers and full 3" lift?
  19. Apr 10, 2017 at 11:14 AM
    #1179
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    2nd gens don't need the diff drop. I used washers for carrier bearing drop. I'm a fan of 5100's over OME shocks. But yes that kit works. @HeadStrong Off-Road is a great place to buy from. You don't have to ask for deals. Marie gives the best price and free shipping up front.
  20. Apr 10, 2017 at 12:24 PM
    #1180
    TRlPPlN
    I think this would suit your needs - Coil/Bilstein 5100 Kit w/ Dakars
    Not sure what DCSB you have but here's a guide for you depending on how much lift you want for the front.
    http://www.headstrongoffroad.com/uploads/1/1/8/4/11846658/lift_guide_shock_and_coil_selection.pdf
