Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Dec 15, 2018 at 5:53 PM
    #1321
    Seth_Lu.
    Seth_Lu. Member
    Seth
    Montgomery, Al.
    98 taco trd and 16 tundra trd off road
    6 in. Lift and tires on tacoma/ tires and brush gaurd on tundra
    I'm in search of a 5 or 6 inch lift for my 1st gen 4x4 tacoma and the only one I'm seeing in my price range is the rough country but I don't trust the spindle extenders for the kit. Do y'all have any good recomendations for a reliable 5-6 inch lift? Doesn't have to be top of the line, just reliable and cost efficient.
    StinkyTroll likes this.
  2. Jan 14, 2019 at 4:39 PM
    #1322
    Mikefen1985
    Mikefen1985 Well-Known Member
    Western Mass
    2023 Toyota Tacoma Sport DCSB
    If I just want to level the front out would I just go with 5100s ?
  3. Jan 19, 2019 at 5:46 PM
    #1323
    cmoffatt
    cmoffatt Member
    Cameron
    2015 DC LB TRD SPORT
    Did you ever get this figured out? I’m experiencing the same clank.
    optysite likes this.
  4. Feb 3, 2019 at 10:48 PM
    #1324
    jesusjones142
    jesusjones142 Well-Known Member
    none
    Hey guys. I'm looking to armor up and level out my DCSB. I want to get a plate bumper up front (about 130 lbs), no winch for now. Would OME 885s with 90021 be enough? I dont want a bro lift, just a small lift and keep the front relatively close to rear height. Dont plan on tossing on huge tires either.. 265/75r16 max.
    Also, I plan to also add sliders, rear plate bumper and camper shell later... can I get away with the stock TRD sport rear for now? Should I just upgrade the shocks to match the front? Do I need to lift the rear to compensate for the front lift? Itll be a while before I load up the back of the truck but it's already fairly jumpy with the stock setup as is.
  5. Feb 6, 2019 at 9:00 PM
    #1325
    airjammer
    airjammer Well-Known Member
    Paonia Colorado
    '17 Silver Sky TRDOR DC MT
    F:OME Nitrocharger Sport 90021 w/888 Coils R:OME Nitrocharger Sport 60091 w/CSO47R Dakar Spring Pack
    Go 886 for your coils front w ome front shocks.
    Medium Dakar rear with ome rear nitro sports
    You’ll increase suspension travel and 265 75 16 will look great. Even 255 85 16
    886 will handle the extra weight w no sag. And you can add a winch later.
    I went 888 because not adding winch or bumper. Perfect.
    You will have a little rake when empty and your bed will level out at ~ 500# payload.
  6. Feb 7, 2019 at 3:15 PM
    #1326
    jesusjones142
    none
    I reached out to HS and one thing they pointed out that I hadn’t even thought of is my truck is 2wd so I’m about 200lb lighter around the front. They think it’ll get about 2-2.25 inches out of 885s with a plate bumper.
  7. Feb 8, 2019 at 6:46 AM
    #1327
    airjammer
    Paonia Colorado
    With a good deal of weight. 885 will begin to sag. 886 won’t.
  8. Feb 14, 2019 at 7:57 PM
    #1328
    LukeD
    LukeD Well-Known Member
    Luke
    Warner Robins, GA
    2015 Double Cab Prerunner
    So if you go for the cheaper option and put Bilstein 5100's on the front, what else would you need up front, and then what would be the best option to level out the rear? Or would you even need to do anything to the rear? Currently I'm running a Rough Country spacer leveling kit up front.
    71tattooguy likes this.
  9. Feb 17, 2019 at 6:37 PM
    #1329
    saviorself
    saviorself Member
    Joey
    2015 Tacoma TRD Sport 4x4
    Stock right now :(
    Need a little advice...
    Been reading this suspension thread for a few weeks now, trying to figure out which option to get. I'm looking to do a 3" lift thats pretty much a swap out.
    From everything I've read, I've decided on 5100s for the front and ToyTech Boss for the rear. I don't have a heavy bumper atm so I was going to use a 600lb coil instead of the 650 - or will the 650 give me a higher front? Don't want that... Here is the kit I'm looking at. Also looking to add the 1" body lift.
    https://www.bilsteinlifts.com/shop/toyota-tacoma/2005-2015/ultimate-lift-kit-for-2005-up-tacoma/
    Does anybody have any experience with this lift?
    I do some light off roading so not wanting to use spacers. I don't mall crawl and I don't want to install junk. I need to make a decision quick because the stock tires I have on now are about to eat shiz...
    Thanks in advance!
  10. Feb 17, 2019 at 9:05 PM
    #1330
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I would go with 700# coils. There isn’t enough difference not to.
  11. Feb 17, 2019 at 9:24 PM
    #1331
    saviorself
    saviorself Member
    Joey
    Stock right now :(
    Kept reading and now I'm torn again...
    Looking at this. https://www.bilsteinlifts.com/shop/toyota-tacoma/2005-2015/3-lift-kit-with-bilstein-5100-coilovers/
    Was also considering 6112s with 5160s but those kits are expensive...
    https://www.bilsteinlifts.com/shop/...15-5160-lift-kit-for-2005-2015-toyota-tacoma/
    https://www.bilsteinlifts.com/shop/...-mini-leaf-add-a-leaf-for-2005-toyota-tacoma/
    https://www.bilsteinlifts.com/shop/toyota-fj-cruiser/u-bolts-with-hardware/
    Am I missing anything? Id like to achieve 3". I just recently read on here that Bilstein recommends 5100's to be paired with stock springs but they don't want you to max out the clips - so how can you achieve 3" while using stock springs?
  12. Feb 17, 2019 at 9:29 PM
    #1332
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Side note, everyone with fox rears w/ resi's remembering to check their hose fitting orientation periodically?
    :thumbsup: :cool:
  13. Feb 18, 2019 at 10:21 AM
    #1333
    pontoon
    pontoon Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    I've got a 1st gen 4x4 3.4L V6 TRD. Right now the front coils are Moog and the shocks are Billstein 4600s (OEM). The General Spring HD leafs in the rear are way too heavy duty for my needs and they aren't left right specific so it has a horrible lean. How should I change my setup to give the best ride quality and an ability to haul up to 300-400 lbs in the bed when hauling a dirt bike? I do have air helper springs.
    I was thinking of getting Deaver J59 with one leaf added, but even with 0 leafs added, the J59 is 1.5" taller than stock. This implies my stock down travel of ~4" would be reduced to perhaps 2" of down travel with J59+1 leaf. Losing half my down travel seems really bad. Is my understanding correct? I also don't want to lift the rear higher without also addressing the front, as I don't want rear high/front low.
    What should I do?
  14. Apr 5, 2019 at 7:36 PM
    #1334
    TL4x4Taco
    TL4x4Taco Member
    02 2.7 4x4
    Lift, lights, stereo
    So, I'm confused. OME 882 and 883 coils provide 2.75" of lift. The 882 is longer but not as strong. The 883 is shorter but stronger. I've read many threads here and on other forums, and been on different sites that sell the coils. Some say the 882 is meant for heavy loads like a winch and bumper, others say that is wrong, the 883 is for heavy loads. Which is it?
  15. Apr 11, 2019 at 9:12 AM
    #1335
    heel_touge
    heel_touge mark@eibach
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    Eibach Pro-Truck-Lift system Icon RXT Leaf Pack Dirtking UCA’s Magnuson Supercharger Nitto Ridge Grappler Warn 9.5 Hella Rally 4000 ARB goodies everywhere
    5100's or Eibach Pro-Truck Shocks are sufficient to level the front with the OE spring, but my suggestion would be to get the matching rears to of whichever you choose in order to benefit from the improved ride quality and functionality.
    additionally, if you add a front spring to it, you'll get back some bump travel improving the ride and capability even further.
  16. Apr 11, 2019 at 9:45 AM
    #1336
    Eleftherakis
    Eleftherakis Member
    Kameron
    San Diego, CA
    2011 DCSB TRD4x4 OFF ROAD toyota tacoma
    Hey how much lift can I get away with before needing UCA's and/or diff drop kit?
  17. Apr 11, 2019 at 10:05 AM
    #1337
    heel_touge
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    If the spring is clocked correctly, My second gen was getting a full 3" out of our pro-truck-lift spring and shock on the second clip with OE upper control arms before armor. There was no axle bind, and I've been punishing my axles with no issues thus-far. The biggest issue is caster/camber adjustment. You'll want an arm that allows/compensates for it.
  18. Apr 11, 2019 at 10:41 AM
    #1338
    la0d0g
    running for the hills
    For crawling not hauling
    :gossip: you guys dont have the same truck.
  19. Apr 11, 2019 at 10:51 AM
    #1339
    heel_touge
    Mark
    Corona, CA
    14’ TRD-OR DCSB 4x4
    Yeah, I was stupid and didn't reference his info- BUT. I did mention it's on my second gen soooooo
  20. Apr 11, 2019 at 1:55 PM
    #1340
    Taco_Hero
    Taco_Hero Well-Known Member
    Daniel G
    San Antonio, TX
    2019 TRD Off Road DCLB
    Lots of good info on this thread, thanks to all that contribute.
