Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Dec 27, 2024 at 7:29 PM
    #1501
    Miniguy
    Miniguy Black Betty
    Norman
    Chiefland,Florida
    2002 Black Tacoma 4x2
    Intermittent wipers…so far
    I’m not sure if I want or should lift my 02 it’s 2wd I’m just trying to figure out a way to add some style without modifying it too much. I like lifted and lowered but I’ve been down the lowered road with a hardbody and it seems it was always messed up with a static drop. Honestly if my taco had torsions it would probably already be lowered a bit. I’m thinking maybe wider tires and rims and a body kit without lowering at all but I’m not sure if that will give me a good look
  2. Jan 20, 2025 at 3:18 PM
    #1502
    RonMx18
    RonMx18 Active Member
    Ron
    2012 Tacoma access cab 4x4 V6 6 spd man.
    Eibach pro coil overs set at 3", General Spring 3+1 rear leaf pack, Eibach extended rear shocks, Freedom Offroad Upper & lower Control arms.
    Wild peaks are a heavier than normal tire, make sure you stay away from "LT" tires Taco's do not need that stiff of sidewalls (D or E range) so look for P-metric sizes those will be a SL rated or maybe up to a "C" rated that keeps the weight down & the ride alittle smoother.
    Did you look into Mickey Thompson Baja Boss A/Ts ??
  3. May 29, 2025 at 11:05 AM
    #1503
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Anyone running the Icon RTX Leaf Pack + Bilstien 5125s? Was extending the brake line needed to avoid damage at full droop? Trying to decide between 5125s and b110s.
