Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Apr 26, 2011 at 11:57 AM
    #141
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    From what I understand by reading here and there, I will need bigger shocks because it will lift the rear end up. I currently have Non TSB leafs
  2. Apr 26, 2011 at 12:04 PM
    #142
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can use the stock rear shocks with the TSB leaf pack , all the Canadian trucks do .
  3. May 10, 2011 at 9:57 AM
    #143
    beefsteak
    beefsteak Active Member
    TRD 4x4
    Grey Wire mod, Eibach and bilstein 5100s all around, Alcan leafsprings, tundra brake swap with steel lines, loose steering column weld mod, keyless/alarm mod
    I've read this whole thread and some of the other forums but I'm still not clear on some stuff. My shocks are shot and I need to replace them, and I'm not looking to lift my vehicle much more than stock (1-2 inches max) because I don't want to have to deal with UCAs and diff drops etc. I realize that I can get billies all around with the option of adjusting them to raise them that 1-2 inches (for the front) But in case my coils on my TRD are bad, are there any replacement quality coils that don't increase lift too much or just 1-2 inches? Everything I see is 3in replacement coils
    And what's the main difference with the adjustable coilovers and a set up where you buy the coils and shocks and put them together yourself? Are the only benefits of the adjustable coilovers the ability to adjust them from stock to 3inches, and that they are all put together already? (cause they are significantly more expensive) And would that be the only option for me if I want to replace my coils and not lift my truck more than 1-2 inches? Because the coils sold as separates show that they are 3inchs above stock right off the bat, which would be more than what I need. I figure that if I'm gonna replace my suspension, I want to upgrade in performance and quality over stock, just not sure how yet...
    Any information on this would be great. Thanks in advance guys.
  4. May 10, 2011 at 12:11 PM
    #144
    Sgtfluffy16
    Sgtfluffy16 Well-Known Member
    Corey
    PA
    07 Tacoma Double Cab TRD Sport
    20% tint, HID headlights/ yellow fog light bulbs and LED lights interior/exterior lights. 4.5 Inch RCD lift, 1 Piece custom driveshaft, AEM intake, Dynomax Exhaust, Amp research Moto-bed extender, Extang Express tonno.
    any replacement coil will work.. Order toyota ones or maybe moog has replacement coils. then use the 5100's.. problem solved
  5. May 10, 2011 at 7:47 PM
    #145
    bowhunter11199
    bowhunter11199 Well-Known Member
    awsome job man. big thumbs up! i just have 1 question
    in the article it says this: "But please take note NO One recommends 5100's to be used in conjunction with after market coils) This may result in damage of your suspension components."
    is it unsafe/harmful to your truck if you put 5100's with ebaich or 5100's with OME coils?(on a 1st gen)
  6. May 10, 2011 at 8:25 PM
    #146
    Sgtfluffy16
    Corey
    PA
    my take on this is an " aftermarket coil " that is lifted (taller) or stronger (beefier for more weight) and OEM replacement should be fine
  7. May 17, 2011 at 7:32 AM
    #147
    SpicyTaco
    SpicyTaco Beast Mode
    SC
    09 PreRunner SR5
    3in Toytec lift, TRD Cat-back exhaust, AEM cold air intake, 265/70/R17 Nitto Terra Grapplers
    So after reading all of this I'm still a little unsure. I recently put on the 3in toytec lift and the AALs in the rear. My front struts are fine, I still need an alignment which will happen this week...but my rear shocks jolt every time I hit a larger bump in the road since they are fully extending. Bilstein 5100s seem to be the shock of choice but I'm not trying to lift my truck any higher, I just wanna smooth out my ride a bit and stop the jolt. Any suggestions?
  8. Jun 7, 2011 at 8:13 PM
    #148
    morrison14
    morrison14 Active Member
    Charleston, SC
    11 DC PreRunner SR5
    starting soon......
    Welcome from Charleston,SC. The Bilstien 5100 rears will not add any height, just give you a better ride. Hope this helps.
  9. Jun 8, 2011 at 9:01 AM
    #149
    Carolina_Boy
    Carolina_Boy Carolina_Boy
    Brandon
    Columbia South Carolina
    2009 Tacoma TRD SR5
    6'' fab tech performance suspension lift, 35-1250-18 Nitto Mud Grappler Extream terrains, XD Monster 18'' matte black rims, Relentless Fabrication Front Bumper and Rear bumper with a Ramsey 9000 mounted in front bumper.
    Would anyone on this forum know a solution to my prob. I went with a fabtech 6. Ever since then my limited slip beeps at me when I turn. Also it has had a tendancy to lock front up cause me to go to a bit of skid I have 3 inch wheel spacers and running the same nitto 33/1250/17 I had for almost 2 years when I had a 3 inch lift no probs. Any help would be appreciayed
  10. Jun 8, 2011 at 9:34 AM
    #150
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^Sounds like a wheel speed sensor problem. You mean it lock up when you hit the brakes right? Both of those problems could be related to the computer not getting correct wheel speed input. I dont know too much about wheel spacers but 3" !!! That might be your problem. You have to post some pics of that
  11. Jun 8, 2011 at 9:49 AM
    #151
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    hey i got probably a stupid question that i really dont think needs its own thread lol
    i got a 3" lift with AP leaf pack and billys and ebaich coilovers.
    now could i just get some 3" blocks and a drop bracket and make it a 6"?
    i know i would need extended brake lines and possibly extended steering column?
    but would that be it? would it work?
  12. Jun 8, 2011 at 1:44 PM
    #152
    Cr250jumper
    The moon
    50 shades of tan©
    ^I dont know maybe you should make a thread for that question. It will be much more fun that way
  13. Jun 9, 2011 at 4:37 AM
    #153
    Carolina_Boy
    Brandon
    2009 Tacoma TRD SR5
    No that aint the prob it been doing it even when I had 1 1/2 inch spacers I did 3 to try and stop it
  14. Jun 9, 2011 at 5:50 PM
    #154
    Cr250jumper
    The moon
    50 shades of tan©
    True now that I think of it the sensor is on the disc brake not the rim so the wheel spacer wouldnt matter. Its a wheel sensing problem. Could be dirty or a bad sensor
  15. Jun 10, 2011 at 8:19 AM
    #155
    Carolina_Boy
    Brandon
    2009 Tacoma TRD SR5
    Ok col so I can have it checked when I go for new brakes this afternoon
  16. Jun 10, 2011 at 8:44 AM
    #156
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    so even just adding the 5100's to gain a couple inches up front will result
    in issues???
  17. Jun 14, 2011 at 6:55 PM
    #157
    Carolina_Boy
    Brandon
    2009 Tacoma TRD SR5
    So I still have a prob if anyone can help goodyear told me that the beeping and hardning issue is due to the traction control when tje wheel is turned the light flashes and it beeps eitjer direction. Any suggestions to this issue anyome with a lift or who has had this issie could help I would appreciate it
  18. Jun 25, 2011 at 8:10 AM
    #158
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Could you be more specfic on the failure. I recently installed a set of Bilstein 5100 shocks in a set of OME 881 springs with the clip at mid range. Everything seemed to fit together OK. I have not done any hard off road driving yet. I have emailed OME to get their opinion and I'm looking for a contact at Bilstein.
  19. Jun 25, 2011 at 8:49 AM
    #159
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Something to do with the VSC maybe. ???
  20. Jun 29, 2011 at 9:34 AM
    #160
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Reguarding OME 881 springs and Bilstein 5100 shocks.
    This from Joel Ward at Bilstein:
    Tom, I haven't heard anything about that particular combination breaking but I dont generally keep up with the street legal applications (I work with the race product). I do know that your shocks shouldn't be bottomed out or yanked (full droop) repeatedly and that the snap ring 5100 should not be combined with a spacer kit. ​
    Joel Ward
    Off Road/Motorsports Technical Supervisor
    ThyssenKrupp Bilstein of America, Inc.
    14102 Stowe Drive
    Poway, CA 92064
    From Dan at Wheeler Off-Road where I purchased the springs.
    I wouldn't worry about it. As long as the coil seat is installed correctly, the snap ring is captured and can't go anywhere. We sell tons of those shocks, and lots of them with OME coils, and have never had anyone have an issue.
    Benzdriver81 likes this.
