Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Jun 30, 2011 at 6:13 AM
    #161
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    So I'm orderin my lift probably tomorrow. OME from DSM. Which top plate spacer do I get to make it as close to level as possible? 13mm or 10mm? Gonna order new wheels and 255/8516s also
  2. Jun 30, 2011 at 8:08 AM
    #162
    Carolina_Boy
    Carolina_Boy Carolina_Boy
    Brandon
    Columbia South Carolina
    2009 Tacoma TRD SR5
    6'' fab tech performance suspension lift, 35-1250-18 Nitto Mud Grappler Extream terrains, XD Monster 18'' matte black rims, Relentless Fabrication Front Bumper and Rear bumper with a Ramsey 9000 mounted in front bumper.
    Ok any help from yall would be appreciiated you can PM me the answers if you want also post on here for anyone else that might have the issue. ok I have a Fabtech 6 inch suspension lift, with that said on my 09 taco trd sport sr5 4x4. now since i put that on the tractions control now beeps when i turn in either direction hit a dip what ever and i get a little vibration into my gas peddle, also when i turn in a curb it goes off and sometimes tries to grab chopping my brakes and puts me into a skid on the highway and or when i go to stop and turn into a parking spot it will get hard brake peddle and wants to skid. i have been to dealer and the instal place no one knows how to begin to fix it has anyone had a prob like this with a 6 inch lift or more. any solution would be awsome. also i am running 3inch wheel spacers with factory 17 rims and 33/120/17 nitto mud grappler extream terrain. DID NOT have this issue when I was on a 3 inch lift again thanks for any info and helo yall
  3. Jun 30, 2011 at 1:30 PM
    #163
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    First check each front wheel to make sure nothing is loose, grab and shake, pull and push. Raise each wheel on a jack or lift and grab the top and bottom and see if you can move it in and out. With the front end raised and secure have someone turn the steering wheel full left to full right several times while you look for any binding or loosness. Then have them turn the steering in short quick movements left and right. This should tell if there are any mechanical issues.
    It really sounds more like a speed sensor problem, make sure the wiring is not pinched or damaged to each wheel. An OBDII tester may show something but I'm not familiar with what Toyota may have assigned to it for the OBDII tester. Also did you use 3 inch spacers on the 3 inch lift?
  4. Jul 1, 2011 at 10:34 AM
    #164
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  5. Jul 7, 2011 at 7:53 AM
    #165
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    you still have to get an alignment with the 5100's or the
    spacer(level lit) correct? I've read in other thread that there
    are issues with the UCA's or a differential drop needed. I know
    very little regarding suspensions, I'd just like to level the truck
    and put bigger tires on.
  6. Jul 8, 2011 at 8:27 AM
    #166
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Anytime you make changes to the suspension you should have the alignment checked. Exceptions would be if you replaced a shock that is separate from the spring, in other words it is not a coil over shock. If you use a spacer or have the 5100 set for it's highest lift you may want to consider dropping the front differential on a 4x4 to lessen the strain on the CV joint.
  7. Jul 8, 2011 at 11:23 AM
    #167
    BlkTaco47
    BlkTaco47 Unhinged
    the alignment is expected, it's the "dropping of the diff and the CV
    issues that worries me. No idea about the process of what or how
    to do it which is what's preventing me from doing any kind of lift.
  8. Jul 8, 2011 at 1:29 PM
    #168
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    I'm not familiar with a 2011 model but on my 2004 it was really simple. Put a jack under the diff. for support and remove the two torque arm bolts that attach it to the frame. Lower jack for room to install the one inch spacer between the frame and torque arm. Install the OE washer, supplied washer, and supplied bolts and nuts and torque to 78 ft/lbs. These are Ready Lift instructions which is what I used. This lowers the from diff. 1 inch. If you go to http://www.readylift.com and check for your truck you can preint out the instruction. They may not have a 2011 listed but 2005 and up should be the same.
  9. Jul 8, 2011 at 1:34 PM
    #169
    BlkTaco47
    BlkTaco47 Unhinged
    thanks man! I was starting to think I wasn't going to lift this thing.
    I had som many issue with the Titan I just sold I didn't want to get into
    it again on another new truck. Issue was the alignment shop BENT THE FRAME!! :(
  10. Aug 6, 2011 at 9:11 PM
    #170
    packfan88
    packfan88 Very Nice !
    Acworth, GA
    Billy Lift, Cooper STT Pro, Westin Step bars, tinted, rain gaurds, EBC rotors hawk pads
    Bilstien 5100's This is a great affordable lift kit. These replacement shocks are great to add a few inches to the front of your Tacoma, it is adjustable and have a slightly better valving system than the stock shocks that come with the Tacoma's. (But please take note NO One recommends it to be used in conjunction with after market coils) This may result in damage of your suspension components.
    so buying the Old Man Emu coils was a bad idea?
  11. Aug 6, 2011 at 9:42 PM
    #171
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    IMO, no. Several of us are quite happy with our Bilstein 5100s / OME 881 combo. While some find the ride a little "harsher" than they prefer, I don't recall any reports of suspension "damage" because of it.
  12. Aug 6, 2011 at 10:05 PM
    #172
    packfan88
    Acworth, GA
    was it worded wrong or something?
    hmm.....side note, why did you go with 881?
  13. Aug 6, 2011 at 10:41 PM
    #173
    Norton
    Not sure I follow. I understood your question to be "buying the Old Man Emu coils was a bad idea?" My response was "no." (As in, I think buying OME coils is a GOOD idea.)
    I wanted the lift the coils provide (~2") without having to pre-load them. I went with 5100s because I wanted the valving they provide. (I prefer the firmer ride.)
    My only disagreement was with the claim that suspension damage may result from the combo - I have yet to hear of such an occurance.
  14. Aug 22, 2011 at 6:26 PM
    #174
    shanetaco
    shanetaco New Member
    shane
    georgia
    00 tacoma sr5 4x4 v6 trd
    too many to list
    i was wondering if i put a 1.5" leveling kit on the front of my 2000 tacoma will it lift it 1.5" or 2". may be stupid question but i have heard different things.
  15. Aug 24, 2011 at 8:17 AM
    #175
    1badasstaco
    1badasstaco Y>O>L>O so BUY a TACOMA
    Brody
    victoria texas
    2006 taco 4x4 4.0
    17 inch black rhino sidewinders with 265/70/17 KM2. straight pipe exhaust and K&N cold air intake.Toytec coilovers
    What is a good 3 inch lift for around 1800?? I need suggestions
  16. Aug 26, 2011 at 7:58 PM
    #176
    mfields007
    mfields007 Active Member
    Sumter, SC
    97 Tacoma
    3in front lift with an add a leaf in the rear...new paint job, 17in tires
    Ok, looking for some advice. I have the 3in spindle lift on my 97 5 lug tacoma and I want to go higher. any suggestions?
  17. Sep 4, 2011 at 1:02 PM
    #177
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I have a SR5 DC SB 08 Taco, and I had a question about bilsteins.
    The stock rear and front bilsteins that come with TRD sport tacomas. Do those provide a level clearance throughout the truck or is the front still lower than the back? Thanks
  18. Sep 4, 2011 at 2:26 PM
    #178
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    Your truck will sit lower in the front stock. I put the 5100s on my truck on all 4 corners with an aal. My truck sits just a tad bit higher in the back but not much. I tow and haul dirt bikes in the back. It made it noticeably stiffer. It handles great and I love to drive it but on rough roads it can be a little annoying sometimes. You will feel everything in the road through the wheel and your seat. Depends on the tire as well. I have some bfg at on mine and they are a stiff tire imo.
  19. Sep 7, 2011 at 7:19 PM
    #179
    TRDBen
    TRDBen Mall Crawler of the Year
    Ben
    San Luis Obispo, CA
    02 Prerunner 4 Door TRD V6
    Front Window Tint KYB Monomax Shocks Blue Dome Light Valentine 1 Radar Detector
    So if I want around 2-3 inches of lift I should just get a set of 5100s? I wont need new UCAs? Just the 5100s? Or Should I get a set of 881 springs as well? I just want an easy way to get 2-3 inches of lift without spending a grand or so and having to get new UCAs. Thanks guys.
  20. Sep 7, 2011 at 8:09 PM
    #180
    DirtJumper14
    SoCal
    2005 TRD OR
    5100s don't require new ucas. You will only get about 2.5" of lift with that shock depending on the model you have. I have an 05 dbl cab trd offroad. I put those on with 33" BFG AT's and got about 4.5" of total lift measured at the bottom of my front fender. It looked funny with the stock wheels and tires, definitely asks for bigger tires. Can post a pic later if you would like.
