Tacoma Lift Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Last Cast 69, May 6, 2013.
  1. May 6, 2013 at 7:53 PM
    Last Cast 69
    Last Cast 69 [OP] New Member
    Noah
    518 NY
    01 Pre Runner
    I have a 2003 double cab with the 3.4L V6. My shocks are near gone any my leafs sit flat. I am getting a brand new leaf kit from a local shop with an extra leaf added to the pack. This should give me 2" or so in the rear. I am getting Bilstein 5100's for the front and plan on setting them to 2.5". My question is should I get new coils for the front? And if I got new coils, would Bilstein 5125's make sense for the rear? I don't off-road heavily but would appreciate having the capability. Does this lift/replacement combination of parts make sense? Any input is much appreciated.
  2. May 6, 2013 at 7:57 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Eibach or OME coils.
  3. May 6, 2013 at 8:06 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    This. IMO 5100's will suffice for the rear too... Do a search for eibach/bilstein lifts and OME kits. All info you will need is here. :thumbsup:
  4. May 6, 2013 at 10:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No difference from 5100 and 5125s rear shocks other then 5125s come in more lengths. Wait till you get your new packs and measure them flexed out to get the right length shocks.
    If indeed your new packs are just 2". I'd go for OME 881 front coils. Make sure if you get any aftermarket lift coil to set the 5100s at 0" to not precompress them too much
  5. May 7, 2013 at 4:28 AM
    Last Cast 69
    Noah
    518 NY
    01 Pre Runner
    So if I go for just the aal and coils for the lift, should I bother with the 5100 adjustable or go for a cheaper shock altogether if I'm not going to use them for lift at all? Any negatives to the aal and billy lift with just using factory coils? Either way I'm looking at a 2-3" lift max. Is there anything else I need to buy for this other than shocks/coils/leafs? The new leafs include all mounting hardware/bolts/brackets.
  6. May 7, 2013 at 10:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Aren't you getting all new leafs?? I wouldn't go with just an AAL in the stock wore out leafs. Just a bandaid
    5100s are fine for shocks. I wouldn't go cheaper. they are already very affordable.
    Ride won't be as nice if you use the stock coils and set the billys at 2.5''
