Tacoma lift to factory cause of vibration?
Discussion in 'Suspension' started by Prose104, Jan 1, 2013.
  1. Jan 1, 2013 at 3:40 PM
    Prose104
    Prose104 [OP] Member
    Once you install a 6" lift is there any way to go back stock I hate the lift it drives shitty had has vibrations so I wanna go back stock any way I can weld that piece of frame back in? I have posted 4 differet topics and no body has helped me somebody please help me I have a 2011 that I loved now I hate can some body please help me?
  2. Jan 1, 2013 at 3:49 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    IIRC if you get a 6" lift you had to cut the front crossmember. So I would say no, you can't really go back to stock.
  3. Jan 1, 2013 at 4:10 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    You can if you can get another cross member and weld it back in.... It will be close to stock, but not exactly stock. Some members on here have first hand experience with it...but I forget who.
  4. Jan 1, 2013 at 4:19 PM
    Prose104
    I have the peice I cut out of the truck it is perfectly straight can I not get a professional to weld it back it?
  5. Jan 1, 2013 at 4:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If it's just a matter of vibrations, there are ways of dealing with it. (One-piece driveshaft, 6" leaf pack instead of blocks, etc.)
  6. Jan 1, 2013 at 5:22 PM
    Prose104
    Can anyone tell me why I'm getting them I had a 3" pro comp no problems I loved it got a 6" zone lift and I get bad vibration at 20-30 and slight ones after 53mph if I can get rid of the vibrations I will be happy
  7. Jan 1, 2013 at 5:26 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Have you tried to take it to a driveline/lift specialist? A real wheel alignment garage maybe? They can probably help you better in person.
  8. Jan 1, 2013 at 5:35 PM
    KenLyns
    Belly of the Beast
  9. Jan 7, 2013 at 9:17 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I have no vibrations with my zone 4" lift. Seeing you have a 6" lift yours came with a 4" block in rear. I would reccomend adding a 3leaf progressive pack and a small tapered block or a new leaf pack. Also your kit should have come with some thick silver spacers. Look under your truck and see if they installed these to lower your carrier bearing. If they did then try removing them and see if helps or worsens. I never installed mine and don't have any vibrations. Also make sure whoever installed your lift on the lift blocks they installed them going the right direction. They should taper towards the front of the truck
