Tacoma Lift
Discussion in 'Suspension' started by reeder62281, Jan 10, 2013.
  1. Jan 10, 2013 at 10:40 AM
    reeder62281
    reeder62281 [OP] Member
    chris
    Yulee Florida
    2011 tacoma
    I am new to this forum and had a question that i hoped someone could help me with. I bought a 2011 Tacoma Double Cab 4x4 and i wanna lift it and put 285/70r17 on it what lift is best for me to use in your opinion to keep a smooth ride. I do not do much off road other than hunting. Just bwant to make sure it is done right.Thanks in advance for any help.
  2. Jan 10, 2013 at 10:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    With 285's, get ready to trim!
    What's your budget for the lift and how tall do you want to go?
  3. Jan 10, 2013 at 10:56 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    Dont really have a budget. My original intention was to do whatever lift would clear a 33-12.50 18 or 20 Toyo MT but was told by the lift guy ive been talking to that the only way i could do that was with a 6" lift . He sold me a set of 17''x9'' rockstars and now i cant use Toyos because the smallest size i can get in those is a 295/70r 17 so im lost dont really know what to do or where to start
  4. Jan 10, 2013 at 10:58 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    im sure offsets of the rims and things like that make a difference but i have no clue what im doing. First time lifting a vehicle other than a 92 regular cab toyota and it was a body lift
  5. Jan 10, 2013 at 11:02 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    so basically what he has now is a pro comp 3'' lift spacers in front and blocks in rear with the 17x 9 rockstars and a 285/70r17 nitto trail grappler says it will work fine
  6. Jan 10, 2013 at 11:13 AM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    sounds like you need an OME lift :thumbsup:
  7. Jan 10, 2013 at 11:18 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    ok so an OME lift with 885 front coil springs and the AAL rear and what size wheel and tire would that clear?
  8. Jan 10, 2013 at 11:19 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    If you don't have a budget don't get a spacer and blocks lift.
  9. Jan 10, 2013 at 11:20 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    and do i need to get the top plate spacer option for the full 3'' in the front?
  10. Jan 10, 2013 at 11:28 AM
    xgalvanxgx
    Gerardo
    i believe not with the 885's only with 884's. not sure though. can anyone jump in on this?
  11. Jan 10, 2013 at 11:28 AM
    jtav2002
    Josh
    Reading, PA
    I believe you need the top plate spacer for the full 3" with the OME. 265/70/17 will clear fine. You will need to likely at least do some trimming for 285s.
    EDIT: wait for clarification on the spacer I may be wrong.
  12. Jan 10, 2013 at 11:30 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    yea the website says for double cab use 885 i think
  13. Jan 10, 2013 at 11:36 AM
    Pugga
    Massachusetts
    Double cab 4x4, you will need the top plate spacer to get to 3" of lift. You should also invest in new upper control arms with a 3" lift.
  14. Jan 10, 2013 at 11:38 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    ok now what has to be trimmed for the 285 ?
  15. Jan 10, 2013 at 11:38 AM
    xgalvanxgx
    Gerardo
    hope this helps..
    886 COILS 18MM BAR DIAMETER
    402MM FREE HEIGHT
    11.4 WRAPS
    660 LBF/IN SPRING RATE
    885 COILS 17MM BAR DIAMETER
    395MM FREE HEIGHT
    10.6 WRAPS
    590 LBF/IN SPRING RATE
    884COILS 17MM BAR DIAMETER
    385 FREE HEIGHT
    10.6 WRAPS
    590LBF/IN SPRING RATE
  16. Jan 10, 2013 at 11:40 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    what is a good UCA to use?
  17. Jan 10, 2013 at 11:42 AM
    xgalvanxgx
    Gerardo
    you can try and find some used ones for cheaper on the buy/sell/trade section
  18. Jan 10, 2013 at 11:45 AM
    Pugga
    Massachusetts
    Light Racing but try Fat Bob's Garage or Metaltech4x4. Both will be cheaper than Toytec for that part. Sometimes they do come up for sale used and there are group buys every so often where a particular vendor drops the price to clear off the shelves.
  19. Jan 10, 2013 at 11:50 AM
    reeder62281
    chris
    Yulee Florida
    2011 tacoma
    ok thank you guys for the help !
  20. Jan 10, 2013 at 11:55 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Wow all these questions and no one told the OP to search? Looks like everyone is having a good day haha +1 for all you guys! Good luck reeder!
