Tacoma lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Emannn24, Jan 1, 2020.
  1. Jan 1, 2020 at 5:16 AM
    Emannn24
    Emannn24 [OP] Well-Known Member
    2017 trd off road 4x4 quicksand
    Hey guys , I have a 2017 Tacoma and I’m going to lift it with Eibach suspension or bilstein 5100 with 887 coils , want around 2” of lift . Any suggestions? Also I’m going 285/75/16 any advice on tires ?
  2. Jan 1, 2020 at 5:20 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Conventional wisdom says 285’s probably going to rub. CMC necessary. YMMV
    whatstcp and GreyBaldTaco like this.
  3. Jan 1, 2020 at 5:27 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    There's probably a lift thread out there, somewhere.
    Maybe no tire thread yet, but I'm betting there's something out there on a 2" lift.
    Yann, whatstcp, Hobbs and 1 other person like this.
  4. Jan 1, 2020 at 5:32 AM
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    Hey there OP,
    from what I’ve read.. Bilsteins is a great way to go ! You might have some rubbing with the tire size, but some chopping would do the trick.
    Nitto Ridge Grapplers would be my recommendation.
    Happy New Year
    :cool:
    Emannn24[OP] likes this.
  5. Jan 1, 2020 at 6:35 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  6. Jan 1, 2020 at 6:51 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    I am running Bilstein 5100s, OME 885s, 1.5” rear blocks (with angle taper) and Falken Wildpeaks AT3W in 265-75r16. It needed the ECGS bushing upgrade. It rides great and looks super.
    Jasonstacoma likes this.
  7. Jan 1, 2020 at 7:51 AM
    Emannn24
    Does it vibrate?
  8. Jan 1, 2020 at 8:14 AM
    SDRider858
    SDRider858 Well-Known Member
    San D Aygo
    2019 DCSB OR 4x4 cement
    Just do it.
  9. Jan 1, 2020 at 8:47 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    285s = likely need CMC
    5100 + ome coils = YES
    ECGS bushing = likely need
  10. Jan 1, 2020 at 8:55 AM
    Emannn24
    Why is the ecgs bushing required ?
  11. Jan 1, 2020 at 8:58 AM
    Mr-Paul
    Paul
    It had the cyclic vibration with the factory needle bearing... The ECGS Front diff driver side output bushing upgrade fixed the vibration.
  12. Jan 1, 2020 at 9:02 AM
    SpeySquatch
    2016 TRD OR DCSB
    Is your truck stock height in your avatar pic?
    You’d be fine with the Eibach or Bilstein lift. Personally I would go Eibach because it has REALLY good reviews whereas the 5100’s get a mix of reviews depending on the ride quality desired. Why 285’s (what’s your goal? Look or function)
  13. Jan 1, 2020 at 9:09 AM
    Emannn24
    Yes I’m stocked w 265/75/16 and I want more look than anything , but I want a nice ride in the road like highway ,
  14. Jan 1, 2020 at 9:11 AM
    Superdave1.0
    SoCal
    Lifting the front suspension changes the angle of front axle shafts. Where the driver side axle sits in the diff, there is a needle bearing (weak). That bearing becomes stressed after lift. Ecgs bushing is stronger and can handle the increased angle.
  15. Jan 1, 2020 at 9:16 AM
    SpeySquatch
    2016 TRD OR DCSB
    265/75/16 is a nice size for just about anything.
    If you go with a wider tire your truck will wander more on the highway. You could go 255/85/16 for a skinnier 33”, but they only come in E-rated. If all you are looking for is looks just understand that a wider tire will wear on components like your steering pump and what not because it’s harder to turn a wider tire than a skinnier one. Some people don’t care and can replace parts themselves. Just something to consider...
  16. Jan 1, 2020 at 9:16 AM
    Mr-Paul
    Paul
    285/75r16 tires are really going to bog you down on acceleration and braking. You better have a V6. Gas mileage is will take a hit. I feel the load from my 265/75r16 ATs. With that being said, my next tires will be 255/85r16 Cooper ST Maxx. To Hell with MPG !!!
    71tattooguy likes this.
