Tacoma Lifts 1st Generation
Discussion in '1st Gen. Tacomas (1995-2004)' started by gerardo1a, Jun 5, 2011.
  1. Jun 5, 2011 at 1:54 PM
    gerardo1a
    gerardo1a [OP] Member
    I have a question about lifts. When people say they have a 2" lift, for example, do they mean the front or rear is lifted 2". Is leveling a tacoma with stock rear considered a lift? The way I see it, when someone says lifted 2", it means that it's first leveled with stock rear, then lifted 2" front and back. I am considering a lift, but I need to know what they mean so I can view pics and understand. Thanks.
  2. Jun 5, 2011 at 2:34 PM
    SoftShellTaco
    SoftShellTaco Well-Known Member
    Justin
    Goldsberry, NC
    SR5
    My truck has a 2" lift in the rear and is up about half an inch in the front. in order to do this I had to do a 2" shackle lift in the rear and a 3" spindle lift with a 1.5" daystar spacer in the front. This was on a 2002 2WD 5 lug, the six lugs have different mounting points and the rear axle is under the leafs instead of mounted on top like mine.
    after the lift
  3. Jan 19, 2012 at 8:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Also some ppl will say i have a 3'' lift..like me. But in the back its actually 4.5'', but is simpler to just say the lowest. If someone asks for details i tell em.
  4. Jan 19, 2012 at 8:30 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    If someone asks me I say I'm lifted about 3" because the front is up about 3", but the rear is actually only 2.25"ish over stock.
    So probably depends on who is talking.
