Tacoma making rubbing noise after using 4WD
Discussion in 'Technical Chat' started by BellBoy, Dec 19, 2016.
  1. Dec 19, 2016 at 6:14 AM
    BellBoy
    BellBoy [OP] New Member
    Tyler
    2011 Toyota Tacoma
    I have a 2011 Toyota Tacoma 70K miles, recently I used the 4wd in snow and after turning OFF the 4wd there has been an intermittent rubbing noise coming from the front wheels. The noise stops when 4WD is engaged and then continues as soon as I turn off the 4WD. Any suggestions as to what it could be?
  2. Dec 19, 2016 at 6:21 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you have a mattress wound up on the front prop shaft
  3. Dec 19, 2016 at 6:28 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Time for an ECGS bushing replacement on the front driver's side diff. Same for 2nd and 3rd Gens.
    https://www.tacomaworld.com/threads/front-diff-vibes-ecgs-bushing-fix.464941/
    https://www.tacomaworld.com/threads/ecgs-bushing-cv-axle-question.461363/
    A quick search will tell you what you need.
