Tacoma Manual 6 Speed Stuck in 6th Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by G587, May 12, 2019.
  1. May 12, 2019 at 5:26 PM
    G587
    G587 [OP] Member
    Tyler
    Georgia
    2005 Toyota Tacoma V6 4.0 TRD Offroad SR5
    I Was Driving My Tacoma Down the Highway in 6th, Coming up to the Red Light, Push Clutch in, Gear Shifter Doesn't Move To Come Out Of Gear, Shifter is Stuck in 6th, Clutch Engages and Disengages, Shifter Wiggles Side To Side In 6th, But Doesn't Move Up To Neutral, Any Ideas/Suggestions??? All Responses Are Greatly Appreciated!
    2005 Toyota Tacoma V6 6 Speed TRD Offroad
    230,000 Miles
  2. May 12, 2019 at 5:41 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    sounds like a broken shift fork.
  3. May 12, 2019 at 5:47 PM
    G587
    G587 [OP] Member
    Tyler
    Georgia
    Thats What i Was thinking , I've Been Googling For A Little while Now, And Found This, Unfortunately idk what the problem is until it gets looked at, but it would happen to be either of these it sure would save me a lot of money
    The cable runs from the clutch pedal to the clutch assembly itself, and allows you to engage the clutch and change gears. If you have a hydraulic clutch, the problem is likely with the master or slave cylinder. ... If the fluid is low, or the master or slave cylinder has failed, you won't be able to change gears.
  4. May 12, 2019 at 5:51 PM
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    Do you have an aftermarket short-throw shifter?
  5. May 12, 2019 at 5:54 PM
    G587
    G587 [OP] Member
    Tyler
    Georgia
    No aftermarket Short Throw Shifter, Stock Shifter
  6. May 12, 2019 at 6:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Easy way to tell if it's the clutch. Does the truck run in 6th gear while you are at a stop with the clutch pedal pushed in? If so, it's probably not the master/slave cylinder. If the truck stalls out even with the clutch pushed in (while in gear), likely the clutch is not engaging. even without using the clutch you should be able to get the transmission out of gear if the truck is moving.
    If you can eliminate the clutch then it's likely internal to the transmission. It's not uncommon to have a bad slave cylinder or broken clutch fork that would cause what you are describing.
    k5driver likes this.
  7. May 12, 2019 at 9:04 PM
    682bear
    682bear Well-Known Member
    West GA
    2006 SR5 DC and 2015 TRD OR DC
    I had the same problem with 5th gear in a Jeep Wrangler several years ago... the 5th gear slider hub cracked, locking the slider to the hub. I actually broke the shift bushing trying to jerk it out of gear.
    I had to replace the 5th gear slider assembly and the shift bushing to fix it. I did all the work myself, so it wasn't an expensive repair... if you have to pay someone to do it, it may be fairly expensive.
    -Bear
  8. May 12, 2019 at 9:12 PM
    Muddinfun
    Muddinfun Well-Known Member
  9. May 13, 2019 at 2:07 PM
    G587
    G587 [OP] Member
    Tyler
    Georgia
    ^ Exactly, I was thinking of going to a pull a part yard and maybe dropping a 5 speed trans into her, 6 gear is pretty useless anyway, it's a risk but a trans is only $137 at the yard instead of $1200 for a brand new one, worth a shot
  10. May 13, 2019 at 3:34 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    Not sure if a 5 speed trans will work with the V6. I think they were only in the 4 cyl
  11. May 14, 2019 at 4:14 PM
    G587
    G587 [OP] Member
    Tyler
    Georgia
    your correct a 5 speed was only in the 4 cyl, they also dont make the 4 cyl any longer, but the 5 speed is the most reliable toyota transmission, the truck will have a higher rpm in 5th gear with no 6, but with a couple changes will function perfectly fine
    Transmission Model: A750E RWD
    A750F 4WD
    2005 Toyota Tacoma 4.0L V6 Trans Only...^^^^
    reg0928 likes this.
  12. May 14, 2019 at 8:48 PM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    The A750 (auto) has a lower rev than the RA60 by about 400 revs at 80. That’s not a plug and play swap either. I’m not sure if he was referring to the R155f (more likely imo) but I have no idea if the bellhousings mate or not. R series tranny’s have a good reputation for being stout tho so wouldn’t worry about durability.
  13. May 15, 2019 at 7:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    A 5spd manual out of a 4cyl wont drop in as a replacement. The 1GR doesnt have a place for a pilot bearing that the R155/R155F utilizes
    If you are wanting to swap a 5spd auto in, its gonna be a lot of work
