Tacoma may get a 4cyl Turbo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoBella, Oct 12, 2019.
  1. Oct 30, 2019 at 7:16 AM
    #221
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Have fun with that. I had a hybrid highlander and hated it. Now you have two systems that can fail. I just dont understand Toyota. You have a platform whos main attraction is ruggedness offroad capabilities and reliability... then they put an anemic 3.5L thats so choked out oj high compression for emissions compliance and plan to put a fuckin turbo engine in it next.... bye bye reliability. Bye bye rugged offroad capability.
    I cant wait for electric tech to catch up and we can get back to having monster torque, low center of gravity, super reliability, and none of this bullshit emissions compliance crap nerfing the shit out of performance and driveability.
    Tacodaco89 and whitebread like this.
  2. Oct 30, 2019 at 7:26 AM
    #222
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    It is more likely we will get a variation of this motor here. https://en.wikipedia.org/wiki/Toyota_dynamic_force_engines#V35A
    GreyBaldTaco likes this.
  3. Oct 30, 2019 at 8:25 AM
    #223
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I thought those 2.7 V6 Ecoboost did pretty decent on MPGs?
  4. Oct 30, 2019 at 8:27 AM
    #224
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    when towing*
    shakerhood[QUOTED] likes this.
  5. Oct 30, 2019 at 9:45 AM
    #225
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Another good read. https://newatlas.com/toyota-tnga-engines/46830/
    I am anxious to see what engine toyota puts in the Tacoma, whether in the late Gen3 or Gen 4.
    With these new engines coming out I don't think Toyota has any plans for using turbo engines at all.
  6. Oct 30, 2019 at 10:11 AM
    #226
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    You are aware that diesel engines have had turbos for decades and do just fine off road, right? It's an extra component for sure but the existence of a turbo doesn't automatically make it an unreliable piece of shit if the rest of the engine and tune are done properly.
    Malvolio, Reh5108 and GreyBaldTaco like this.
  7. Oct 30, 2019 at 2:04 PM
    #227
    Garab
    Are you really trying to compare diesel to gasoline engines?
  8. Oct 30, 2019 at 2:51 PM
    #228
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    When the topic of discussion is related to the lifespan of the turbo itself (which much of this thread is about), the comparison is valid.
    Jeff
    velogeek, hiPSI and Reh5108 like this.
  9. Oct 30, 2019 at 2:58 PM
    #229
    SteelerJim
    SteelerJim Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    As I stated before in this thread. Toyota and all the other manufacturers have been putting normally aspirated engines in their trucks for decades. The Toyota's are at the top as far as longevity goes with these trucks/engines. So common sense would tell you that WHEN/IF Toyota decides to put smaller displacement, turbo-charged engines in to their trucks, that these too, will last and last like we've come to expect from most all Toyota products that have came before.
    TT005 likes this.
  10. Oct 30, 2019 at 3:35 PM
    #230
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I've been on this forum for decade, and each year I hear the same thing. Haven't seen them yet.
  11. Oct 30, 2019 at 7:24 PM
    #231
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    So is that a no?
  12. Oct 30, 2019 at 9:46 PM
    #232
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I think sound can be a huge part of the equation. It’s why I bought a used flat six vs a new turbo 4, even though they were the same price and the new turbo 4 would outperform mine slightly.
    Yep, the Maseratis sound wonderful.
  13. Oct 31, 2019 at 12:18 AM
    #233
    Garab
    The discussion was related to the lifespan of the entire motor, not just the turbo.
    Yes diesel engines have had turbos for a long time what is your point. A diesel engine is vastly different from a gasoline.
    Diesel engines are much simpler in design. They dont have spark plugs or any of the electrical ignition electronics. Diesel engines are designed around compression ignition (otherwise known as detonation or knock which can ruin gasoline engines). Because of the high compression needed to achieve this they are engineered much tougher and are able to be run much more reliably under forced induction, as opposed to gasoline engines which have to perfectly balance increased compression and heat with timing and detonation to keep the engine from destroying itself.
    Furthermore stuffing a smaller engine into an increasingly heavy truck will also put more strain and wear on an engine that has to work much harder. Smaller gasoline turbos also completely lack low end toque before they can spool up which again less than ideal in a heavy truck.
    Steadfast likes this.
  14. Oct 31, 2019 at 12:40 AM
    #234
    Jeff Lange
    Calgary, Canada
    Yes, maybe I shouldn't have directed my post as much at your comment. Much of this thread was discussing the specific reliability of the turbo itself and how often it needs to be replaced. A comparison between gas and diesel makes sense for such a conversation. In discussing the reliability of the entire powertrain, there is quite possibly more room for debate.
    Jeff
    BlkTaco47 likes this.
  15. Oct 31, 2019 at 5:00 AM
    #235
    Garab
    Thats not common sense thats blind consumerism brand fanboism. Putting a small engine in a big truck is recipe for unreliability as the smaller engine has to work much harder. Putting a turbo on a gas engine is an additional recipe for unreliability as youre increasing the compression and potential detonation. I'd never ever buy one, but go on and drink the kool-aid.
  16. Oct 31, 2019 at 6:17 AM
    #236
    SteelerJim
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    Wrong. The fact remains that Ford is having great success with their Ecoboost engines in their pickups. I know Techs at Ford garages that say they hardly ever see the 2.7 with internal issues, and frequently see them in for routine service with 300k miles or more. It’s not koolaid my friend, it’s just the future. Stop by a Ford dealer and test drive an f150 with the 2.7. Then report back....
  17. Oct 31, 2019 at 6:39 AM
    #237
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    So by your logic the current 4 cylinder is less reliable than the 6 in our trucks? Also a turbo doesn't increase an engines compression ratio. Detonation is kept in check by DI. No fuel in the cylinder it can't detonate and it cools the air charge.
  18. Oct 31, 2019 at 1:18 PM
    #238
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
  19. Oct 31, 2019 at 1:25 PM
    #239
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I'll never buy another 4cyl. I've had 2 non-turbo 4's FWD & AWD, and 2 turbo 4's AWD & RWD, and while they have their place, I don't want one. I want a turbo 6 in my Taco.
  20. Oct 31, 2019 at 3:05 PM
    #240
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    I have been happily drinking the Toyota Kool-aid in my '93 MR2 turbo for 19+ years and most of the 216k kms (134k miles). It still has original shocks and exhaust. Starter, alternator, broken seat bracket, broken trunk lock, radiator R&R, are the only non routine maintenance repairs in its 27 years. The cassette deck in the original stereo still works.
    I would like to see Toyota offer the next gen Tacoma with the BMW inline 6 that comes in the Supra. They could offer it both with turbo or na version. Inline configuration by its very design offers more torque than a V.
