Tacoma misfire/surging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexey Degtyarev, Aug 1, 2021.
  1. Aug 2, 2021 at 8:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is going to be one of those problems that’s hard to diagnose on the internet.
    With out riding in the truck, I don’t really have any more ideas?
    Dm93 likes this.
  2. Aug 2, 2021 at 9:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This
    Unfortunately things like this sometimes can even be difficult to diagnose even in person unless you find someone that has good knowledge in reading and interpreting scan data and at least a basic knowledge of how to use a scope. It's unfortunate there's so many shops that use the parts cannon approach to fixing things, there's many good shops too but the trick is finding a good one.
    All we can do is give you things to check into based on symptoms, ultimately you have to decide to try to diagnose it yourself, pay someone to diagnose it, or fire parts at it (not recommended).
    Jimmyh and TnShooter[QUOTED] like this.
  3. Aug 2, 2021 at 9:43 PM
    Alexey Degtyarev
    Alexey Degtyarev [OP] Member
    Daniel
    2009 Toyota Tacoma Four point ohhh
    LED Dome light
    I would get closer to 17....but-I was living down in town on flat ground now I drive up and down a mountain 3 times a day....didn't think of that part.
  4. Aug 3, 2021 at 6:01 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Mine are original with 350k on them.
    Have you considered a cracked spark plug insulator?
  5. Aug 3, 2021 at 6:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    An easy test, since you have an auto. With foot on the brake pedal, trans in drive, give it a little gas pedal to load the engine. See if it starts misfiring.
    Next, what grade gas did you use, and did you get it from a top tier, or something else?
  6. Aug 3, 2021 at 10:04 AM
    Alexey Degtyarev
    Daniel
    LED Dome light
    It's not that since I replaced with brand new denso plugs.
    I am unable to get a misfire with the vehicle stationary and brake pedal applied as well as gas pedal.
    It needs to be in motion. I haven't checked carrier bearing or driveline.
    I use 87 octane standard. I read about this being related to weak spark so I increased volatility of the fuel Im burning by using 93 on a full tank, still the problem persists.
    Torspd likes this.
  7. Aug 3, 2021 at 10:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am going to go with Fuel pump/filter related.
    Also check all vacuum hose ends in the engine bay. Looking for splits and cracks.
    Pyts likes this.
  8. Aug 3, 2021 at 6:00 PM
    Larzzzz
    Larry
    MA
    7
    Just because they're brand new plugs means nothing. Oops that box was dropped a week before you bought it.
  9. Aug 3, 2021 at 6:08 PM
    Alexey Degtyarev
    Daniel
    LED Dome light
    Same symptoms with two sets of plugs. I know it's super hard to figure out online. I don't like playing parts mechanic either.
  10. Aug 3, 2021 at 6:19 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Timing chain?
  11. Dec 27, 2023 at 7:47 AM
    meteorproof
    meteorproof New Member
    Pat
    2005 taco sport
    any conclusion on this? fighting the same issue. 2005 with 255,000. replaced all coil packs, spark plugs, cleaned throttle body and maf sensor..... still does it.
  12. Dec 27, 2023 at 3:39 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    One dude on here had that issue with a VVTI solenoid. Everyone thought transmission but it ended up being that. Idk possibly check those
  13. Jan 3, 2024 at 1:16 PM
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    Mine currently is doing what yours is at the 35-40mph zone. Only up inclines when i have to stay in it behind someone at part throttle to keep speed. I seen that post about the vvt solenoids. I want to try that for myself. Mine only does it at that speed. You would think a shutter would be at multiple speeds. I could be wrong though. Honestly, makes me really wonder to if part of it is just toyotas shift points. Ive seen mine in full lockup today as low as 30.
