Tacoma misfire
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Squatchytaco, Jun 9, 2025.
  1. Jun 9, 2025 at 6:00 PM
    Squatchytaco
    Squatchytaco [OP] Member
    Wade
    2019 TRD off road
    I have a 2019 trd OR and im having an issue with a misfire. I changed plugs and coils and the pcv valve. Its helped a little but I can still feel a bit of a miss. Any help would be greatly appreciated.
  2. Jun 9, 2025 at 6:06 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Obvious first question, is it throwing any codes?
    Chew and Squatchytaco[OP] like this.
  3. Jun 9, 2025 at 6:12 PM
    Squatchytaco
    Wade
    2019 TRD off road
    No codes
  4. Jun 9, 2025 at 7:02 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Do a compression test and a leak-down test.
  5. Jun 9, 2025 at 8:24 PM
    PandaPandaPanda
    PandaPandaPanda Well-Known Member
    Alejandro
    2020 TRD OR DCSB
    Any codes? If not, try cleaning the MAF, replacing the engine air filter, and cleaning the engine bay to keep it cooler. Not sure if you've tried any of those but cheap and quick if not. Good luck.
    Squatchytaco[OP] likes this.
  6. Jun 9, 2025 at 8:45 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    stop driving it till you figure it out or you will be back here asking about p0420 p0430 codes......
  7. Jun 9, 2025 at 9:24 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    It wouldn’t hurt to try one tank of higher octane gas if you are not already using premium.
  8. Jun 9, 2025 at 11:24 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Most likely you are dealing with the torque converter behavior. Any serious misfires would illuminate CEL.
    To be sure you have a misfire, get a cheap obdII phone app.
  9. Jun 10, 2025 at 4:28 AM
    Squatchytaco
    Wade
    2019 TRD off road
    I put higher octane gas and Lucas fuel treatment. It seems to have solved the issue. I noticed that #3 spark plug seems to like to come loose as well.
  10. Jun 10, 2025 at 7:30 PM
    Squatchytaco
    Wade
    2019 TRD off road
    Its goes away the faster I drive.
  11. Jun 11, 2025 at 9:18 AM
    Vlady
    Issy, WA
    Do you feel misfire consistently at the idle?
    Then have before mentioned leakdown/compression tests. Misfire at idle is the one of the symptoms of burnt exhaust valve(s) (P11 codes)
  12. Jun 11, 2025 at 1:54 PM
    Squatchytaco
    Wade
    2019 TRD off road
    No misfire during idle
  13. Jun 12, 2025 at 8:10 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    My truck ('16) has always had a slight stumble under light acceleration when using the lowest octane gas. Very common.
    t0p_d0g likes this.
  14. Jun 12, 2025 at 8:30 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Pull your airbox off, tube and all and check for any oil in it in case the PCV valve was allowing oil in it. Happened to mine. I deleted my aftermarket intake as well and it ran better.
  15. Jun 12, 2025 at 3:34 PM
    Squatchytaco
    Wade
    2019 TRD off road
    This is a pretty violent miss/ shake.feels underpowered and sluggish.
