Tacoma Moab Meet 2012!!!!
Discussion in 'Moab' started by NYCO, Oct 20, 2011.
What date works best?
Poll closed Nov 19, 2011.
  1. May 3-6
    23.5%
  2. May 10-13
    43.1%
  3. May 17-20
    66.7%
  1. Feb 8, 2012 at 8:01 PM
    #2001
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    any preference on antenna? steel, fiberglass, whatever the fire stick is. i read in another thread the whip needed 36 square inches of ground metal
  2. Feb 8, 2012 at 8:08 PM
    #2002
    big dog
    big dog Hug balls bitch
    Las Vegas
    03 SR5 TRD 4X4
    OME 3" k&n cai magnaflow muffler all pro front bumper 4x innovations rock sliders moto metal wheels with 33" Bridgestone dueler revo 2 AT tires
    Check Amazon they have great prices on everything I already have my CB I'm getting my antenna, coax, mounting bracket from Amazon tomorrow I'm going with the firestik 2 4' black for 18. Dollars everything I'm getting will run about 35 + tax
  3. Feb 8, 2012 at 8:31 PM
    #2003
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    i still need to get an antenna whip and mount
  4. Feb 8, 2012 at 9:05 PM
    #2004
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    send me the link for that crap! thats what i want haha
  5. Feb 8, 2012 at 9:13 PM
    #2005
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm going to wait till i get my rack to order an antenna and mounts I'm thinking dual 4' firestiks
  6. Feb 8, 2012 at 9:18 PM
    #2006
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Made by Eric of Relentless fab! Def a custom job!
  7. Feb 8, 2012 at 9:33 PM
    #2007
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    Just go to Amazon and type in firestik and everything CB will show up
  8. Feb 8, 2012 at 9:35 PM
    #2008
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  9. Feb 8, 2012 at 9:41 PM
    #2009
    big dog
    Las Vegas
    03 SR5 TRD 4X4
  10. Feb 8, 2012 at 10:08 PM
    #2010
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    so besides the cb what do i actually need?
    4' black firestik
    18'coax cable
    plated heavy duty side mount
    missing anything?
  11. Feb 8, 2012 at 10:16 PM
    #2011
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    Spring, gos in between the antenna and the mount
  12. Feb 8, 2012 at 10:23 PM
    #2012
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Make sure that antenna you choose has an adjustable tip so you can tune the setup easily.
  13. Feb 8, 2012 at 10:30 PM
    #2013
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ive seen many pics without the spring. also does the antenna come with the mounting washers and nuts that go on the side mount?
    and mike, the firestik has the tuneable tip, so im good.
  14. Feb 8, 2012 at 10:34 PM
    #2014
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    You can do without the spring but then you're more succeptible to breaking you antenna if you hit a tree or something
  15. Feb 8, 2012 at 10:34 PM
    #2015
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hey look at wilson antennas too. They are flexible so you don't need a spring.
  16. Feb 8, 2012 at 10:38 PM
    #2016
    big dog
    Las Vegas
    03 SR5 TRD 4X4
    The firestik has some flex having the spring just helps it more
  17. Feb 9, 2012 at 12:20 AM
    #2017
    w3tw0rks
    w3tw0rks Well-Known Member
    Alvin
    San Jose, CA
    04 Xtracab 4x4
    Count me in! Last year was awesome. We had like 9 trucks...this year almost 100!!!!
  18. Feb 9, 2012 at 5:17 AM
    #2018
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  19. Feb 9, 2012 at 5:58 AM
    #2019
    drz400smoto
    drz400smoto Member
    Drew
    FoCo, CO
    87 SAS Runner & 06 Runner
    Taking both rigs out, my parents and some other family will be there so we need all the seats. I'll trailer the 87' with the powerstroke and my dad will drive the 06 out.
    13-20th for me!! :yay:
  20. Feb 9, 2012 at 10:59 AM
    #2020
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    Speaking of CBs, I was looking at getting an export radio. Does anyone have suggestions on them? There are so many and so little time to research.
    Thanks
