Tacoma Moab Meet 2012!!!!
Discussion in 'Moab' started by NYCO, Oct 20, 2011.
What date works best?
Poll closed Nov 19, 2011.
  1. May 3-6
    23.5%
  2. May 10-13
    43.1%
  3. May 17-20
    66.7%
  1. Feb 19, 2012 at 11:14 PM
    #2241
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    gloat away my friend
  2. Feb 19, 2012 at 11:15 PM
    #2242
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i had my moment..
    but seriously..You could get some smaller ATs for winter tires and bigger MTs for summer..
    Jon did that till i bought these off him..well he still is gonna do that just with 35s now..
  3. Feb 19, 2012 at 11:21 PM
    #2243
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How wide is the wheel with 2.75" of BS? Are you stock ones 16x7s with 5.5" of BS?
    If it is a 8' wide wheel, won't that be like more than 2" further away from the ball joint compared to stock?
    I thought you were going with Camburg UCAs? More clearance with those compared to stock. I think you could clear those wide tires with 4" of BS on an 8" wheel with the campurgs.
  4. Feb 19, 2012 at 11:22 PM
    #2244
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm just going to do it all at once gears wheels tires and locker.
  5. Feb 19, 2012 at 11:23 PM
    #2245
    Blackdawg
    Monte
    Wyoming/St. Louis
    were the hell did that pay check come from :eek: ouch..my wallet hurts from that haha
    depending on how my supra sale goes..i could have an arb too :D Idk about gears tho..
  6. Feb 19, 2012 at 11:25 PM
    #2246
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    My cam burgs will be here tomorrow or tuesday, but I'm going to put 35's
    315/75-16 so 34.6"x12.5x16. as I sit now (265/75-16) I'm about an inch away from the balljoint.
  7. Feb 19, 2012 at 11:27 PM
    #2247
    Blackdawg
    Monte
    Wyoming/St. Louis
    315s/75s are 12.5'' wide??..sorry..i don't know metric sizing very well ha
    and couldn't you go 305s? split the difference haha
  8. Feb 19, 2012 at 11:30 PM
    #2248
    Digiratus
    Roaming the PNW
    The RedHead
    On stock wheels though...
  9. Feb 19, 2012 at 11:31 PM
    #2249
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    no such size.
    I can go 295/75 or 315/75 33.5 vs 34.6
  10. Feb 19, 2012 at 11:32 PM
    #2250
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    correct. my new tires will be 2" wider and stock wheels won't work
  11. Feb 19, 2012 at 11:33 PM
    #2251
    Blackdawg
    Monte
    Wyoming/St. Louis
    not really..it'll be an inch on each side..
    and really?...hmm..must just be car tires that are 305s then..
  12. Feb 19, 2012 at 11:36 PM
    #2252
    Digiratus
    Roaming the PNW
    The RedHead
    Understood. That does not mean that you require a wheel with 2.75" of BS. You never did clarify if those wheels are 8", 9" or 10" wide.
  13. Feb 19, 2012 at 11:38 PM
    #2253
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    they are 8" wide, I want 16x8 with somewhere between 3-4" of BS
  14. Feb 19, 2012 at 11:39 PM
    #2254
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm taking this over to the BS thread.
  15. Feb 19, 2012 at 11:40 PM
    #2255
    Blackdawg
    Monte
    Wyoming/St. Louis
    i think 3.5-3.75 will fit the best..
  16. Feb 19, 2012 at 11:43 PM
    #2256
    Digiratus
    Roaming the PNW
    The RedHead
    They certainly don't "need" to be 3"s of BS to clear the camburg uniball but that has nothing to do with wanting to have your tires stick out a country mile, for looks...sorta the way Monte's do. :rolleyes:
    :stirthepot:
  17. Feb 19, 2012 at 11:47 PM
    #2257
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    :gossip::stirthepot:
    for the love of god, we all know monte will get 0"BS just to one up me.;)
  18. Feb 19, 2012 at 11:52 PM
    #2258
    Blackdawg
    Monte
    Wyoming/St. Louis
    no ill get LT to one up you :D hahahahaha
    and Hey!..i like my 2.5'' BS..i looks sick! haha
  19. Feb 19, 2012 at 11:54 PM
    #2259
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    while you're going LT I'll go SAS
    :brianr:
  20. Feb 20, 2012 at 12:07 AM
    #2260
    Blackdawg
    Monte
    Wyoming/St. Louis
    Have at it bub. Im not a huge SAS fan anyways.
