Tacoma Moab Meet 2012!!!!
Discussion in 'Moab' started by NYCO, Oct 20, 2011.
What date works best?
Poll closed Nov 19, 2011.
  1. May 3-6
    23.5%
  2. May 10-13
    43.1%
  3. May 17-20
    66.7%
  1. May 6, 2012 at 11:25 PM
    #3641
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Watts = Amps x volts If the inverter is designed for a steady 400 watt output, the welder cannot draw more than ~3.5 amps @ 115 VAC. :eek:
    edit: originally quoted the wrong person. :eek:
  2. May 6, 2012 at 11:27 PM
    #3642
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ahhh..yea..mine is gas..
    did have a setting hiccup once. Made it a bit harder till i dialed it back in.
    scarey..
  3. May 6, 2012 at 11:28 PM
    #3643
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    yeah that's not gonna work lol. We run around 70 amps at 220V on the .065" 4130 for our baja car. Thats with a TIG though.
  4. May 6, 2012 at 11:58 PM
    #3644
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    wait, silas wont have a diff when he arrives? AWESOME, still pre runner status. build that shit there, thats what moab is about:p
    that'll do it. I'm not an expert by any means, but at least I know what's going on lol.
  5. May 7, 2012 at 12:19 AM
    #3645
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    knowing in theory and knowing in application is different lol. i dont know what is up with arc, i just dont have the feel for it. it takes a while and a lot of flux sticks to get the groove going.
  6. May 7, 2012 at 12:21 AM
    #3646
    Blackdawg
    Monte
    Wyoming/St. Louis
    typical of an engineer :p hahaha
    i have never arc welded..sounds hard tho
  7. May 7, 2012 at 12:21 AM
    #3647
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    TIG is where it's at, I'd love to learn how to do that but just getting a decent set up costs well over a couple grand.
  8. May 7, 2012 at 12:46 AM
    #3648
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Oh no no, dont call me that. im an accountant/business man LOL! just with a very hands on personality :D arc isn't bad, i just dont have the knack. for some reason i can oxy weld like a champ (even though nobody even uses that ever) my buddy is pretty dam good at arc, i just cant keep the stupid arc going consistent.
    did you arc weld your sliders?? Eww, god. Mig can do alright without a super clean surface, same with arc, but any weld will be much better if you have a clean surface. I welded that light bar on my last truck to the pull tabs on the frame without cleaning them one bit and after over kill on the welds i could lift up the front of the truck with the bar.
    tig is where it is hard! tig's niche as you probably know is aluminum, which is such an odd metal it takes a lot of skill to master. Its weird at first setting everything right and keeping a puddle (like you would with oxy) that makes a clean weld. In his 20s my dad was a welder on a nuclear plant project and could lay perfect super long tig welds as good as a robot could today...lots of practice haha.
  9. May 7, 2012 at 12:53 AM
    #3649
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    a bit of bubbling isn't as big a deal as the penetration is. A weld can look fine on the front but unless you get the heat penetration on the back side it is severely compromised. going up or upside down aint easy. pretty easy to get pockets. they have done good so far so i guess you did a decent job. I could have welded mine, but i had a shop do it because it's such a crucial piece i wasn't taking any chances. i wanted clean, pretty experience welds on the sliders.
    LOL, still thought this was the ID bs thread...whoops. taking my bs back home!
  10. May 7, 2012 at 12:56 AM
    #3650
    Blackdawg
    Monte
    Wyoming/St. Louis
    that was a stab at Ben not you lol
  11. May 7, 2012 at 12:57 AM
    #3651
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    pheeew!
  12. May 7, 2012 at 2:17 AM
    #3652
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    We should have time but we will see.
    No Silas should have it in by then. We will see if he gets to use it before then though.
    I lay down super shitty looking welds and it have the penetration that it needs to be strong. The cleaner the material sure helps with the penetration. But with flux core they don't need to be perfect either.
  13. May 7, 2012 at 6:53 AM
    #3653
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    -camping in the lower lot at area bfe
    -pick your own spots...jace and i need two large spots either next to the entrance or within easy viewing of the entrance with some trees next to the site. we will have banners that need to be setup and trees would be nice. we also need space for a sunshade and 6 foot table that will have free shit on it (we will be arriving wednesday late morning)
    -"You should have plenty of room to place your group down there. Please let them know when they arrive that there is absolutely no camping beyond the tree lines and we prefer no parking on vegetation. They must stay in the open areas outside of the trees. During Jeep Safari, I had several people not understand what I told them and I hated asking them to move."-from Olaf
    -no camping fees
    -donations are highly recommended to area bfe and to moab friends for wheeling to help make this happen
    -donations for area bfe can be deposited in their donation box or given to me to be remitted to them
    -olaf, area bfe manager, should be stopping by at some point during the event also, so donations can also be directly given to him if so desired
  14. May 7, 2012 at 7:29 AM
    #3654
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    F
    Bob I have some temp fence stakes for banners if you want me to bring them. Just let me know.
  15. May 7, 2012 at 9:05 AM
    #3655
    NYCO
    bOb
    Colorado
    dents & scratches
    not a bad idea....if they don't take up much space, that would be good to have
  16. May 7, 2012 at 9:28 AM
    #3656
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Most trucks on CB or HAM?
  17. May 7, 2012 at 9:29 AM
    #3657
    NYCO
    bOb
    Colorado
    dents & scratches
    CB for the colorado guys i know
  18. May 7, 2012 at 10:13 AM
    #3658
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    cb, not many have ham, so we pretty much made having a cb a requirement (at least for the NW crew) so everyone is in communication on the trail.
  19. May 7, 2012 at 10:33 AM
    #3659
    NYCO
    bOb
    Colorado
    dents & scratches
    makes the convoy more interesting as well
  20. May 7, 2012 at 10:43 AM
    #3660
    Slodgetto
    Slodgetto Über Posre
    Silas
    lol we'll see...
