Tacoma new brake lights now hyperflash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oldylr, Sep 27, 2021.
  1. Sep 27, 2021 at 9:51 AM
    Oldylr
    Oldylr [OP] Active Member
    I assume since they are led it's causing the turn signal issue, does anyone have the part number for the flasher I need or will that work for the tail lights? I have an '08
  2. Sep 27, 2021 at 9:56 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  3. Sep 27, 2021 at 9:57 AM
    Oldylr
    I do not, thanks for the link!
  4. Sep 27, 2021 at 10:01 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hint, the resistors get hot! So be careful around plastic and fingers.
  5. Sep 27, 2021 at 10:06 AM
    Oldylr
    Dang, $80 for just a relay.
  6. Sep 27, 2021 at 10:19 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends which flasher you have, if you have the DRL (12 pin) flasher I don't believe anyone makes a LED flasher. If you have an 8 pin flasher Diode Dynamics makes an LED flasher
    TnShooter and Speedytech7 like this.
  7. Sep 27, 2021 at 10:22 AM
    Oldylr
    I do not have that on my stalk so I assume I do not have them.
  8. Sep 27, 2021 at 12:19 PM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    So, did you buy new taillights that are not plug-n-play or are you just putting LED bulbs in OEM housings? Just trying to clarify
  9. Sep 27, 2021 at 12:21 PM
    Oldylr
    Aftermarket tail lights. Just got the truck, they were already in it but are led
  10. Sep 27, 2021 at 12:39 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I just bought the relay and installed it last week .DD had a labor day special.It’s very cool what it can do.
  11. Sep 27, 2021 at 12:41 PM
    SliMbo4.0
    Rick
    I don't know your wiring skills but it may be easier to just get a plug-n-play set. I've been running this style with no issues... https://www.ebay.com/itm/133542337178?fits=Model%3ATacoma
  12. Sep 27, 2021 at 12:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My advice is buy the flasher. - If you don’t have DTRL.
    Yes, resistor work. But I don’t like the idea of adding more components and more connections. More stuff= More to go wrong.
    Or you could go back to OEM?
    At this point, you might as well spend a little more and make it work.
    I know the feeling all too well.
    You buy something, only to have to buy something else to make it work.
  13. Sep 28, 2021 at 5:45 AM
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    I ditched my aftermarket lights for this reason. I went from the ugly OEM LED to aftermarket, back to OEM Pink tails. Best aesthetic mod to date.
