tacoma no power, misfiring, hesitating
Discussion in '1st Gen. Tacomas (1995-2004)' started by devinzz1, Mar 28, 2017.
  1. Mar 28, 2017 at 10:00 AM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    truck always ran great. one day started up and drove off as usual and the problem was immediately present. i checked the timing and cleaned the maf and it made no difference. fast forward to today and i started truck and drove off. up until i got up to speed and drove a little the truck drove as it should but it started acting up again. 5 minutes later and i had to bring truck home it ran so bad.
    in this video at the start you can hear a loud backfire. i keep the gas steady up until i put my signal on but the rpms fluctuate the whole time. going up the street im at about 3/4 throttle. not shown but idling, reving at idle, and wot dont show these symptoms. got any ideas before i get my hands on a scanner?
    https://youtu.be/Abfv9txTgs0
  2. Mar 28, 2017 at 12:12 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I'd say check the Air filter just in case it's contributing factor.The air filter by itself won't do this. Next the MAP/MAF sensor, Check resistance of Plug wires (arcing) coil pack or fuel filter plugged. Sounds like weak spark or not enough fuel. Possibly bad injectors or cracked vacuum line.
  3. Mar 28, 2017 at 12:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  4. Mar 28, 2017 at 12:24 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    the gas guage looks like your out of gas:confused:
  5. Mar 28, 2017 at 12:28 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Sounds like a coil went out.
  6. Mar 28, 2017 at 12:48 PM
    devinzz1
    devin
    2023 aclb trd or mt
    cel was on previously because im not running a cat. i haven't scanned it since symptoms
  7. Mar 28, 2017 at 12:49 PM
    wilcam47
    Will
    Bourbon state
    You might have some "New" codes for your current problem.
  8. Mar 28, 2017 at 12:49 PM
    devinzz1
    devin
    2023 aclb trd or mt
    low but not out.
  9. Mar 28, 2017 at 12:51 PM
    devinzz1
    devin
    2023 aclb trd or mt
    hope so. the scanner i ordered isnt compatible with the truck. cant buy one in town so i have to order another. that could take some time though
  10. Mar 28, 2017 at 12:53 PM
    TheCookieMonster
    North East
    running the gas tank that low on E(under 1/4 of a tank)can greatly effect the fuel pump causing it to over heat and fail
  11. Mar 28, 2017 at 12:56 PM
    wilcam47
    Will
    Bourbon state
    I didnt realize there was a compatibility issue?
  12. Mar 28, 2017 at 12:58 PM
    devinzz1
    devin
    2023 aclb trd or mt
    needs a scanner compatible with J1850 VPW OBD protocol.
  13. Mar 28, 2017 at 1:01 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    how old is the TPS
    if original, get OEM and replace it asap
    bad tps does all sorts of fuckery
    however....that thing sounds like ARSE!
    no cat...can't be clogged then
  14. Mar 28, 2017 at 1:03 PM
    wilcam47
    Will
    Bourbon state
    o_O oh this is for the prior to 96 OBD?
  15. Mar 28, 2017 at 1:03 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    anything you buy today will be VPW compatible. even 20 dollar ebay cheapies
  16. Mar 28, 2017 at 1:05 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    would scan as misfire p030[x] right ?
  17. Mar 28, 2017 at 1:58 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Not true, just a wives tale.
    I'm not even sure what engine we're dealing with, you never said. Sounds like a v6 though.
    wilcam47 likes this.
  18. Mar 28, 2017 at 2:00 PM
    wilcam47
    Will
    Bourbon state
    I used to run my 98 Tacoma to the low light all the time...never had a problem
  19. Mar 28, 2017 at 2:05 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Get a fuel pressure gauge on there asap. Sounds like a failing fuel pump to me. Also a failing MAF would account for the strange behavior, but you really need to make sure you've got appropriate fuel pressure 43.5psig. Autozone kit comes with a banjo bolt adapter and then tape the gauge to the windshield. And yes it sucks to put the banjo adapter on.
  20. Mar 28, 2017 at 2:07 PM
    TheCookieMonster
    North East
    the fuel pump is located inside the gas tank and uses the gas in the tank to cool the pump, when you run your car/truck constantly under 1\4 tank or worse on E the pump can over heat and fail, how do I know this:( it happened to my truck in my Signature picture I was running it on E all the time and the pump failed it was a costly mistake had to remove the gas tank and replace the pump when it kicked out and died.Also in the OPs case having such a low level of gas can starve the engine when going around turns or uphill can cut off the gas supply to the fuel pickup tube causing such behavior as he stated, possibly
    mechanicjon likes this.
