tacoma no power, misfiring, hesitating
Discussion in '1st Gen. Tacomas (1995-2004)' started by devinzz1, Mar 28, 2017.
  1. Mar 28, 2017 at 2:07 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    5vz doesn't use a TPS. Video says 3.4, but it also says "tocome" so i'm not taking anything seriously at this point LOL
    cruiserguy likes this.
  2. Mar 28, 2017 at 2:14 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Most fuel pumps are suspended in about the middle of the tank with the pickup tube extending toward the bottom. Therefore the fuel pump would be "overheating" if anything lower than half a tank. This needs to die. It's not a thing.
    He's not simply out of gas, I run mine below E more than that Seinfeld episode, and I'm willing to be 75% of everybody here does too. Fuel pumps fail, it happens.
    end threadjack
    wilcam47 likes this.
  3. Mar 28, 2017 at 2:18 PM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    okie dokey
  4. Mar 28, 2017 at 2:27 PM
    devinzz1
    devinzz1 [OP] Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    It does have a tps.
  5. Mar 28, 2017 at 2:28 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Know the specific size adapter so i dont have to buy full kit and can borrow a tester?
  6. Mar 28, 2017 at 2:34 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Already gave it a once over looking for a vacuum leak?
  7. Mar 28, 2017 at 2:34 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    You can just rent the kit. You don't have to buy it.
    And yeah, it does have a tps idk what I was thinking.
  8. Mar 28, 2017 at 2:43 PM
    devinzz1
    devin
    2023 aclb trd or mt
    i dont have a place like autozone or napa around here.
  9. Mar 28, 2017 at 2:45 PM
    devinzz1
    devin
    2023 aclb trd or mt
    im certain it isnt a vacuum leak. for it to cause these level of symptoms it would affect the idle forsure and it doesn't.
    TacomaJunkie8691 and Jon G like this.
  10. Mar 28, 2017 at 2:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  11. Mar 28, 2017 at 3:13 PM
    cruiserguy
    Elijah
    SEKS
    Gotcha, didn't realize it was only under load. And if I did, I forgot.
  12. Mar 28, 2017 at 3:27 PM
    devinzz1
    devin
    2023 aclb trd or mt
  13. Mar 28, 2017 at 3:37 PM
    Katchaser00
    Katchaser00 Well-Known Member
    Luke
    10,000 lakes
    Willing to bet money it's a coil pack. My truck did the EXACT same thing as your truck is doing. Can't remember the exact code that came up with the scanner, but it was the coil pack.
    mechanicjon likes this.
  14. Mar 30, 2017 at 10:25 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Code scanned. code for tps and Insufficient Coolant Temperature For Close Loop Fuel Control (Probably from me unplugging o2 sensor) On the scanner the tps shows 10% for no throttle and 70% at full throttle.
    After this truck ran decent and i did a nice long wot run which basically confirms that fuel pump is fine.
  15. Mar 30, 2017 at 10:29 AM
    #35
    cruiserguy
    Elijah
    SEKS
    Sounds like you were on the right track from the beginning.
  16. Mar 30, 2017 at 10:53 AM
    #36
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Simple logic: which last longer a electrical motor running hot or cool?
    The fuel pump is cooled by the gas. Keep it 1/4 or above will extend life of pump.
    never seen a pump suspend in the middle of a tank. they sit standing up with a filter sock on the bottom.
  17. Mar 30, 2017 at 12:21 PM
    #37
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    simple logic ?
    How hot does the fuel pump get,
    and what is the operating temperature range of a fuel pump at X degrees F,
    and how long MTBR failure rate for X temp on Y time ?
    No, you don't know any of that. Stop making scary stories of a fuel pump running hot and...what, failing
    on an empty tank ?
    I've run my 18 year old 4runner to fumes a thousand times (reserve light is 40 miles to
    empty, and anywhere from 41 miles to 60 after reserve pops, it will start to suck air and want to stall,
    starting on hills or cornering) absolute max is 60 miles from reserve light on my 4runner if I am flatland and not cornering much
    my 4runner fuel pump is frikin fine. stop making stuff up. old wives tale. you are NOT going to burn out the
    fuel pump. you will stall before it can run that long on 'air'
    you don't want to run on empty because it triggers a bunch of OBD codes when the motor
    stalls and it takes a full drive pattern cycle to get the thing running and shifting like it used to...a minor annoyance
  18. Mar 30, 2017 at 1:22 PM
    #38
    mechanicjon
    Jon
    Scottsdale Arizona
    I digress..
    15+ years as an ASE master tech auto mechanic. But what do I know. :frusty:
  19. Mar 30, 2017 at 1:35 PM
    #39
    devinzz1
    devin
    2023 aclb trd or mt
    pumps are designed to be internally cooled. the extra cooling may help but thats arguable. think most of the problem is the possibility of sucking air while doing a sharp turn or sucking up some floating sediment.
    TacomaJunkie8691 likes this.
  20. Mar 30, 2017 at 1:41 PM
    #40
    cruiserguy
    Elijah
    SEKS
    I don't think it's the cooling of the fuel pump motor by pumping gas through it, I think it's the gasoline that surrounds body of the pump that cools it more, hence keeping gas fuller can theoretically keep it from heating up as quickly. My bad if you were already seeing that side of it. Not trying to be capt obvious.
    I've always heard the same as Jon states from the old timers. I've only changed out two failed fuel pumps. One was a Tundra first gen and the other was a Geo Metro. But both of the owners said they did regularly run the tank low. Not out, just low. Like until the dash light would come on. But I am not positive correlation equals causation in every case or even most cases.
