Tacoma Off-Road 4x4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by williamjamesfpv, Feb 12, 2022.
  1. Feb 14, 2022 at 1:26 PM
    #41
    18CHUÑO
    18CHUÑO Well-Known Member
    Antoine
    2016 Tacoma SR5 i4 AC 4x4 Super White
    You're over thinking it.
    Rental cars/trucks are beat to shit and never maintained. I doubt anyone had ever used that rental Taco's transfer case.
    If getting into and out of 4x4 is slow and clunky it usually means it's never been used and/or T case could use new fluids. On a brand new truck it will be stiff at first and eventually becoming real smooth going in/out of 4hi and 4lo (don't try 4lo unless you've read that card on driver's sun visor, btw).
    (1) He means don't forget you're in 4hi and drive 60 miles on it. It causes premature wear for no reason
    (2) Yes
    (3) Refer to first lines of this post
    (4) It will come out of 4x4, just rock the truck back and worth, or drive forward slowly, or put in N then D then turn to 2WD. On steep grades this will happen too.
    williamjamesfpv[OP] likes this.
  2. Feb 14, 2022 at 1:36 PM
    #42
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    It could have been something really simple. The contacts are known to be an issue. Simply soldering them like @ClassyTacos did in the below video did the trick. Anyone that drives a 4WD Taco and doesn't understand how 4WD engages should watch this vid IMO; plus duder is on this forum so support a brother.
  3. Feb 14, 2022 at 1:55 PM
    #43
    williamjamesfpv
    williamjamesfpv [OP] Member
    I greatly appreciate you. Many thanks!
    hiPSI[QUOTED] likes this.
  4. Feb 14, 2022 at 1:58 PM
    #44
    williamjamesfpv
    Thank you kindly!
  5. Feb 14, 2022 at 1:59 PM
    #45
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    4HI going straight will not hurt anything. Binding will turning will and you will know it when its happening.
  6. Feb 14, 2022 at 2:00 PM
    #46
    williamjamesfpv
    Thank you kindly. I appreciate it!
  7. Feb 14, 2022 at 2:00 PM
    #47
    williamjamesfpv
    Got it! Many thanks!
  8. Feb 14, 2022 at 2:00 PM
    #48
    18CHUÑO
    Antoine
    Don't sweat it and go enjoy your 4x4 Taco. They're well built and will serve you well for a long time.
  9. Feb 14, 2022 at 2:07 PM
    #49
    williamjamesfpv
    Just a couple more questions:
    (1) Does engaging 4x4 in a straight path, while raining, put less strain on the system compared to when it's dry pavement?
    (2) I read a thread where another gentleman asked if he can simply lift the Tacoma and engage 4x4, for the same purpose of maintenance. I understand this may not be needed, but I am interested to know as well. If I have the vehicle up before/after a oil change, and lets say the wheels are free... Would this be safe to do? Any advantages or drawbacks to engaging 4x4 while the vehicle is jacked up?
  10. Feb 14, 2022 at 2:11 PM
    #50
    18CHUÑO
    Antoine
    (1) Nope, same 'strain' on the system. Cornering is where strain becomes amplified. Cornering on dry pavement will put more strain then cornering on wet pavement. But it comes down to traction, ANY high traction surface is bad when cornering, even if it's raining. If you feel like your tires are really gripping nice, dont engage 4x4, rain or shine.
    (2) I have no idea.
  11. Feb 14, 2022 at 2:24 PM
    #51
    williamjamesfpv
    Okay, that makes sense. Maybe I'm over-complicating this, but at what point does it become a bind? Only when you start to feel it? Or does it start well before? I guess I'm asking because if I'm on a straight away with a very light curve, would that cause an issue? (obviously tight turns would)
  12. Feb 14, 2022 at 2:26 PM
    #52
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    You can engage 4WD on a straight stretch of road. I’ve got a one mile stretch on my way home and I’ll put on 4WD a couple of times a week.
    18CHUÑO likes this.
  13. Feb 14, 2022 at 2:27 PM
    #53
    18CHUÑO
    Antoine
    Wide turns shouldn't be a problem. If you're close to turning the steering wheel to the max in either direction is when you'll encounter problems.
    NASCAR style ovals are safe. 3 point turns are not.
    You'll feel the truck shutter and shake and not want to keep going.
  14. Feb 14, 2022 at 2:33 PM
    #54
    18CHUÑO
    Antoine
    Best analogy I can think of is a wood lathe.
    Imagine you have a stick of wood in your lathe but each end of the lathe is somehow rotating at different rates.
    It will cause the piece of wood to twist on itself until it finally gives and breaks.
    That's basically what happens when you're cornering in 4x4 on a grippy surface.
  15. Feb 14, 2022 at 4:19 PM
    #55
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    Honestly I typically just do it on a straight stretch of highway for 3-5 miles if I haven't needed it for snow recently. As long as it's a pretty straight stretch of road, and you're not exiting and doing 90 degree turns at intersections it's fine.
    18CHUÑO likes this.
  16. Feb 14, 2022 at 4:31 PM
    #56
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Absolutely yes.
    shakerhood and 18CHUÑO like this.
  17. Feb 14, 2022 at 6:15 PM
    #57
    williamjamesfpv
    Good to know, and thank you!
  18. Feb 14, 2022 at 6:16 PM
    #58
    williamjamesfpv
    I just needed to be told. LOL :)
    Lt. Dangle[QUOTED] likes this.
  19. Feb 14, 2022 at 6:29 PM
    #59
    Miketacomatrdpro
    Miketacomatrdpro Active Member
    Minnesota
    2021 White TRDPro
    Hell, I live in what feels like the north Pole (mn). After reading all this, I wonder when my truck destroys itself. I have had it in 4hi for months. Including driving around town, Highway, slow, fast around corners… it ‘binds’ backing and tight turns (parking lot) etc.
    I’m not too worried about it. The truck is designed for it. Maybe I’ll regret it, but I doubt it. It’s a truck!
  20. Feb 14, 2022 at 7:46 PM
    #60
    williamjamesfpv
    Seriously? Wouldn't the system just break?
    ORtoCOTaco and 18CHUÑO like this.
