Tacoma Off Road Mountains Winter/Snow Recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DuckNorris, Dec 14, 2019.
  1. Dec 14, 2019 at 9:43 PM
    DuckNorris
    DuckNorris [OP] Member
    2020 White Toyota OR
    Hey Guys,
    Going up to Colorado, got new tires in my 2020 off road 4v4 (the default ones). Question is, is this good enough for the resorts/winter roads up there or do you guys suggest chains or anything else? Thanks!
  2. Dec 14, 2019 at 9:47 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The stock Goodyears are pretty good on winter roads for an all-season M+S tire. Chains as a backup plan is always a good idea. A couple hundred pounds of something in the bed helps too.
  3. Dec 14, 2019 at 11:22 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    What Stocklocker said. First day I had my Taco I drove over Mt Hood in a snowstorm and the Goodyear’s preformed very well. One point where nobody was around I stomped the brakes and she stopped on a dime, then I floored her and away she went. I’d buy them again.
    =JSG= and DuckNorris[OP] like this.
  4. Dec 15, 2019 at 3:57 AM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
  5. Dec 15, 2019 at 6:31 AM
    ArmoredSoul
    ArmoredSoul Active Member
    Northern MN
    2019 Silver DCLB TRD Off-Road
    I will echo the above advice, especially the shovel and blankets, but would add a bucket of non-clumping kitty litter for traction and/or a snatch strap with a couple soft shackles for recovery, if worst comes to worst.
    Edited for spelling
    DuckNorris[OP] and Big tall dave like this.
  6. Dec 15, 2019 at 6:45 AM
    Nw_nomad
    Nw_nomad Well-Known Member
    2019 Tacoma Trd offroad 6MT
    Not to hijack the thread but ive experienced pretty bad wheel hop or leafspring wrap on the rear axle in deep snow. Is there any thing that can be done to reduce this or is it just the nature of the beast?
    Also ive been very happy with winter driving performance of the factory goodyear tires.
    =JSG=, RyanDCLB and DuckNorris[OP] like this.
  7. Dec 15, 2019 at 7:35 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    In addition to the above, I carry a case of bottled water and a case of MRE's in the winter - back country or highway.
    Because you never know....
    DuckNorris[OP] likes this.
  8. Dec 15, 2019 at 7:44 AM
    eurowner
    eurowner Duke Sky
    Scoty
    @DuckNorris if you live where you have winter weather from Nov-April, do yourself, family, friends, and other drivers on the road and get a set of four dedicated winter tires. Yes, expensive upfront, but you are more prepared than a lot of the drivers on the roads.
    Read up on Colorado Traction Laws and watch ctrip.org for road conditions, snow plow updates, and weather stations on a lot of our roads.
  9. Dec 15, 2019 at 7:49 AM
    su.b.rat
    su.b.rat broken truck
    this website is indispensable for winter tripping around CO. real time updates and live cams over most of the passes. can't ask for more.
  10. Dec 15, 2019 at 7:51 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Yep!
    I do ask the people I care about to run dedicated winter tires.
    su.b.rat[QUOTED] likes this.
  11. Dec 15, 2019 at 11:30 AM
    DuckNorris
    Thank you all for your replies and such! Gives me more confidence to take this trip up there, bought this truck for nature trips and snowboarding!
    Side Note...in topic if mountains. Anyone ever fit snowboarding in the backseats? I am planning to bring the down and cover them with something to protect them. Just curious.. otherwise just stick them in back of truck and move them inside house overnight haha
  12. Dec 15, 2019 at 12:45 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Put it in and see if it fits. If it does, strap it with the seat belts, covering the edges with old towels. This will keep it flying around if something bad happens.
  13. Dec 15, 2019 at 2:29 PM
    DuckNorris
    Thank you! Also...4v4 is on lo or hi in mountains( i see 2 options)? I am new to this truck so still yet to use the 4v4 haha
  14. Dec 15, 2019 at 4:27 PM
    eurowner
    eurowner Duke Sky
    Scoty
    More or less roughly:
    4h don't use on dry pavement or over 55mph. Once you are sliding, 4wd doesn't matter.
    4l is for off roading steep technical stuff, getting unstuck, etc. Much lower hearing not intended for driving on pavement.
    Your owners manual will tell you a lot.
  15. Dec 15, 2019 at 7:42 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    In my experience, the axle wrap got worse after installing tires with better winter traction than the stock Goodyear. :/
  16. Dec 17, 2019 at 2:39 PM
    pdxtaco02
    pdxtaco02 Well-Known Member
    Luke
    Portland, Oregon
    2016 TRD Sport QS MT
    Dedicated winter snow tires are the only way to go if you're driving a lot in winter conditions.
    If you're just going to hit snow you should be fine with your stock setup. If you have any reason to believe you'll be driving on steep, icy grades then get chains.
    The stock setup is good in snow but nothing is good on ice unless you have winters.
  17. Dec 17, 2019 at 2:59 PM
    Teegs
    Teegs Well-Known Member
    Done a few snow wheeling trips.
    Carry an air compressor (doesn't need to be uber ARB stuff, but if you can afford it, do it) so that you can air down if things are getting too deep and squirrely. I did circles around a jeep grand Cherokee with chains on all tires in my stockies when aired down to around 15psi.
    Carry a shovel, blankets, headlamp, food, water, and depending on how rugged you plan to get, maybe some extra fuel.
    Also maybe pack things like extra socks, shoes, and snow gators too.
    Edit: Almost forgot, pack a bubba rope, or tow rope and snatch straps too. A trailer hitch recovery point is also useful.
    pdxtaco02 and Chris15x like this.
