Tacoma Oil Dip Stick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RRSC, Mar 16, 2023.
  1. Mar 16, 2023 at 3:48 PM
    RRSC
    RRSC [OP] New Member
    2023 Tacoma SR5 3.5 V6 4x4
    Just got tacoma. Question on the oil dip stick. There is a black O-Ring. Does the O ring indicate the level from the top of the tube opening? If the o-ring is at the top of the opening, then the oil level is correct. However if I push the yellow handle all the way down... Then it looks like the oil is overfilled. Curious what the standard is? Did the factory overfill the oil or is the dipstick suppose to be pushed in to where the oil ring indicates the stopping point?
    3JOH22A and HondaGM like this.
  2. Mar 16, 2023 at 3:50 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes o ring inserted.
    It will read high if you let it sit all night.
    Run it, let it sit for 10 mins, check fully inserted.
    HondaGM and Skydvrr like this.
  3. Mar 16, 2023 at 5:15 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    stick it all the way in.....:anonymous:
    Kolohe07, BRFab, RIX TUX and 6 others like this.
  4. Mar 16, 2023 at 5:33 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard.
    insert to the hilt.:yes:
    RIX TUX, HondaGM and Stevie17 like this.
  5. Mar 16, 2023 at 5:49 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Yep. Gotta go orings deep.
    :hattip:
    TSAVO, davidstacoma, MOC221_ and 3 others like this.
  6. Mar 16, 2023 at 5:58 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    LOL! :cookiemonster:
    davidstacoma and HondaGM like this.
  7. Mar 16, 2023 at 6:16 PM
    twtaco$
    twtaco$ Well-Known Member
    Sux. I finished the topic for you
    HondaGM likes this.
  8. Mar 16, 2023 at 6:23 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Can you elaborate on why?
    Seems with these newer Toyota’s, it always runs down the dipstick using this method.
    Been told by a few dealerships (albeit service writers, not techs) that you get the best reading when the vehicle is completely cold.
    kahanabob and HondaGM like this.
  9. Mar 16, 2023 at 6:24 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    All the way like mentioned. The o ring is to seal it from the elements. If it’s over filled by a margin of 1/4” I wouldn’t worry about it.
    TRDRed, kahanabob and HondaGM like this.
  10. Mar 16, 2023 at 6:27 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Because I believe this is what the dreaded vehicle hand book tells you how to do it. So believe Toyota or some guy at the dealership.
    HondaGM likes this.
  11. Mar 16, 2023 at 6:42 PM
    Just_A_Guy
    On the hunt
    A truck
    Quoting the book is fair.
    But just because Toyota indicates something is the “proper” method does not mean another method is invalid.
    So my question still stands. Is there a technical reason why checking the oil on a cold engine will provide an incorrect result?
    HondaGM likes this.
  12. Mar 16, 2023 at 6:47 PM
    Bishop84
    For one, it takes forever, and to get a consistent result most manufacturers say 5-15 mins.
    The overnight drain back can yield 200-500ml (1/2 qt?) and read wrong, but usually we see that after 30-60 mins. During servicing even at home, that's silly.
    I try to intentionally set my oil levels at work below full to compensate for drain down. So even after over night it only reads slightly over full.
    hiPSI, Just_A_Guy[QUOTED] and HondaGM like this.
  13. Mar 16, 2023 at 6:47 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You gotta warm it up before you stick it in….
  14. Mar 16, 2023 at 6:49 PM
    MadKatt
    :bowdown::bowdown::bowdown::bowdown:
    HondaGM[QUOTED] and Just_A_Guy like this.
  15. Mar 16, 2023 at 6:52 PM
    Just_A_Guy
    On the hunt
    A truck
    Interesting. Thanks for the info.
    Last time I checked my oil (after sitting overnight), it was sightly under the full line. Not dangerously low, but that indicates it could use some more at oil change time. Thanks.
    HondaGM[QUOTED] likes this.
  16. Mar 16, 2023 at 7:53 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Almost every car I've had the level is lower on a cold engine vs sitting 10 minutes hot.
    wood714, HondaGM and kahanabob like this.
  17. Mar 16, 2023 at 8:57 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    yep.oil expands when hot.
    HondaGM likes this.
  18. Mar 16, 2023 at 9:13 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    This is the first vehicle where it was recommended to check the oil 2 minutes after shutting down the engine as recommended by the Toyota guru CCN. Blasphemy!
    I was sceptical at first but was willing to give it a shot as I was doing a more traditional method of waiting overnight and not being able to read the bloody dipstick. Tried CCN’s method and voila. Readable dipstick and bang on full mark. I wonder if 0-W20’s thiner viscosity has something to do with this?
    HondaGM likes this.
  19. Mar 16, 2023 at 9:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yellow handle all the way down. This ain't a lawn mower :laugh:
    HondaGM likes this.
  20. Mar 16, 2023 at 9:28 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Always shove it all the way in.
    HondaGM and AM6217 like this.
