Tacoma on ice... I'll take the car instead.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Demoncleaner, Jan 7, 2009.
  1. Jan 7, 2009 at 10:30 AM
    Demoncleaner
    Demoncleaner [OP] Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Hate to say it, but after a trip w/ the 4wd truck then our Mazda 3s Fwd car this morning on heavy sleet and freezing rain road surface, car wins.
    Both have full snow/ice tires, which helps both alot, but the ABS is so freakin sensitive in the Taco that braking distance which is usually 20% more than the car felt like double that today.
    Of course couldnt make all the way up my 10% grade driveway with the car, and when the snow returns the car eats the truck's snowdust.;)
  2. Jan 7, 2009 at 10:31 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    you could always bypass the ABS if that is the only thing stopping you from taking the truck.
  3. Jan 7, 2009 at 10:32 AM
    lsocoee
    Hotdog
    Wet Okole Underwear
  4. Jan 7, 2009 at 10:46 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Now I am wondering if my ABS has issues, but I don't seem to have that issue with my 05. If I push hard on the breaks, then I can feel/hear it.
    The last 2 ice storms we had here, I did need 4 wheel drive, but the only thing I had issues with was the sloppy/light rear end. This was the first winter with the lift, so took awhile to get use to. But slowing down for me (since I do drive fast) has helped the most.
  5. Jan 7, 2009 at 10:49 AM
    slooowr6
    slooowr6 Member
    Do you have weight on the back of the truck?
  6. Jan 7, 2009 at 10:54 AM
    longbow
    Bill
    Indiana
    well................no I don't, but hear me out....it has been almost a month since I had it out, no mistaken, I drove it once on a nice day.
    But I am planning on getting weight in the back, I will be adding a full size spare, and a bed tire carrier, plus a couple black burlap tubes full of sand.
  7. Jan 7, 2009 at 10:55 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Abs is very sensitive, I agree. Try pumping the brakes for faster stopping
  8. Jan 7, 2009 at 10:56 AM
    slo2sixty
    slo2sixty Well-Known Member
    Syracuse, NY
    10 Acesscab TRD Sport
    885s 10mm spacer lite racing UCA Dakars Nitrocharger sports
    yea the ice in syracuse was rediculous!!! at took forever to get to work today.... Where abouts do u live?
  9. Jan 7, 2009 at 10:57 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    That confuses the ABS. Not advised. Best thing to do is take your foot off the brake and attempt another threshold braking. The point where the wheels are at maximum braking but not locking up and engaging ABS.
  10. Jan 7, 2009 at 11:01 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    x2... don't pump ABS brakes...
  11. Jan 7, 2009 at 11:06 AM
    longbow
    Bill
    Indiana
    Indiana here, had 3 ice storms so far, nothing much. Here in the AM gone by noon.
    It has been the most un-eventful winter in years. If it wasn't below freezing at night you would think it's spring.
  12. Jan 7, 2009 at 11:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X3
    If the ABS brakes seem sensitive, you should have the dealer look at them.
    I've never felt my ABS come on. The only way I know they exist on my truck, is if I slam on the brakes with all my weight behind it.
    Either that - or you're using your brakes too hard for the conditions.
    In snow/ice - LOTS of distance (slow down EARLY) and just barely use the brakes. If you can downshift and use engine braking, that's even better.
  13. Jan 7, 2009 at 11:18 AM
    Demoncleaner
    Upstate NY
    Yea, I've seen that, but thats only for those w/ the Off-road which has the locker, which defeats ABS.
    I complain about the ABS, but really today is some of the worse ice I've driven on w/ the truck in 5 winters, so just an obs from today. Normal driving on snow (w/ winter tires) it takes a hammering on the brakes to get it to cycle the ABS.
  14. Jan 7, 2009 at 11:36 AM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    While I was impressed overall with how my truck has handled in the snow, I do agree that the ABS is too sensitive. I also found that the Vehicle Stability Control is WAY too sensitive on snow/ice. It was often kicking in at low speeds with the slightest hint of a tire slipping... turning into/out of parking lots, or even pulling into my parents driveway at Christmas.
  15. Jan 7, 2009 at 5:19 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Ice picks bro!!:p
    Just messin, your help and input was invaluable to me in my thread:)
  16. Jan 7, 2009 at 6:02 PM
    Demoncleaner
    Upstate NY
    Yea, used to run picks, new they were sick, but after a couple seasons pounding pavement they rounded and didnt penetrate as well. Plus and minuses with both types. Glad days this bad are rare. Gotta say the studless Blizzaks even on season 5 are still pretty good and its amazing that even on this I could still accelerate, turn, and eventually brake... albeit slowly.
  17. Jan 7, 2009 at 6:04 PM
    Okkine
    Vancouver, BC
    Forget the Blizzaks, bring a pair of skates :eek:
  18. Jan 7, 2009 at 6:07 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I don't think I'd venture out in that!
  19. Jan 7, 2009 at 6:11 PM
    hoosiertaco
    Hey, don't know how long its been since then, I know you said Blizzaks for 5 years, but you might find that the studs are a little better now. Just a thought.
    Kinda wonder about the ones you had, cause even the studded ones I got my wife 9 years ago were still cutting ice well after 5 years.
    That is an awesome picture dude. Some serious ice for sure!! The Blizzaks paid ya back on that road!
  20. Jan 7, 2009 at 7:17 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    What do you guys mean the ABS is too sensitive :confused: If the wheels start to skid while braking the ABS kicks on, if they're not skidding the ABS doesn't kick on.
