Tacoma OR brake booster convert to vaccum
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Msalinas227, Dec 13, 2024.
  1. Dec 13, 2024 at 12:14 AM
    Msalinas227
    Msalinas227 [OP] New Member
    Hello guys, i recently got a new Tacoma Trd OR and i love it but i absolutely hate how the brakes feel. I know that the OF has an electronic brake booster but I just wanna swap it out to a trd sport vaccum booster. I just can’t get used to the electric brakes. Is there any way i can do this, if so what can i do?
  2. Dec 13, 2024 at 12:29 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    No, not easily and without an insane amount of work. It’s going to be a long and expensive process to swap systems and keep any dash lights off.
    Chew likes this.
  3. Dec 13, 2024 at 1:43 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    The electric brake booster has the abs built in and is the reason you have the crawl(or something) mode to get unstuck.
    Off the top of my head you would need to install a trd sport - brake booster, master cylinder, abs module, wiring harness for sport abs module, brake lines from master cylinder to abs module, brake lines from abs module to wheels/disconnects, correct trd sport abs module computer programming. Frankly I will be surprised if there isn't something I am not thinking of.
    Considering you just bought the vehicle I would recommend driving it for a month at least and see if you get use to it, I know when I drive a new to me vehicle it takes a little bit for me to get use to how well the gas and brakes respond.
    What is it you hate about how the brake pedal feels? Is the vehicle stock or what modifications have been made? Maybe something is wrong.
  4. Dec 13, 2024 at 3:07 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Different engine with electric brake booster. Engines with the electric brake booster are not set up for vacuum.
    Barsoom, eurowner, Jakerou and 2 others like this.
  5. Dec 13, 2024 at 3:59 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    It would be much more practical to just buy a different truck if you can't get used to it.
  6. Dec 13, 2024 at 5:04 AM
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    What is it about them do you don't like? Mine feels like every other car / truck I've owned, except at start-up obviously.
    Chew likes this.
  7. Dec 13, 2024 at 5:09 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Or try giving it a bleed? Make sure the system is in working order before ripping it out cause you dont like it. Bleeding with the electric booster is really easy. Shove a 2x4 in between the seat and the brake petal and it will pump itself(gotta crack the bleeder and have a catch ready).
    Chew likes this.
  8. Dec 13, 2024 at 5:11 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t like the hydraulic booster either, and I’m more willing to do projects like this than most. However, in my opinion, it would be too much work and would be worth trading for a sport and changing the Sport stuff to match the OR features to your liking. I’d keep driving the OR and see if you can get used to it.
  9. Dec 13, 2024 at 5:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    So no pre purchase test drive huh?
    BillF1564 and 3JOH22A like this.
  10. Dec 13, 2024 at 5:38 AM
    BLtheP
    Plano, TX
    The engine does not have vacuum for it. Have to take off the block off plate for the vacuum pump location and install the vacuum pump in its place. Can’t do that unless you replace the bank 1 intake cam because the OR/Pro models have a sealing ball in the back of the cam where the vacuum pump nozzle would go. And that’s just to get vacuum. Then you’d need to actually swap the boosters and masters, rework the lines, get an ABS module and run the lines to it, and rewire the harness to go to the abs module instead of the hydraulic booster.
    It’s simply not worth it for brakes.
  11. Dec 13, 2024 at 5:59 AM
    BLtheP
    Plano, TX
    You need to learn more about the third gen. There is no vacuum source on the 2GR-FKS. TRD OR/Pro don’t need vacuum because they have the electronically powered hydraulic booster. Sport and all other V6 trims need a vacuum pump because the engine offers no vacuum.
    Look up what a vacuum pump does. They exist because not all engine designs provide usable vacuum sources, so they need a pump to do that…which applies to all the non OR/Pro 3G Tacomas.
    Barsoom, musicisevil and Chew like this.
  12. Dec 13, 2024 at 6:01 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Theres different cams and stuff.
    https://www.tacomaworld.com/threads/fs-complete-2gr-v6-engine-pnw.810636/
  13. Dec 13, 2024 at 6:25 AM
    545 Well-Known Member
    2015 Access Cab
    Well that’s oddly complicated
    Maybe Atkinson cycle related problem not having enough vacuum?
    ahh well, clearly I’m wrong, I’ll delete my post to avoid confusion
  14. Dec 13, 2024 at 6:29 AM
    BLtheP
    Plano, TX
    I believe it is related to the Atkinson. Vacuum pumps are common on turbo engines as well. So, the 2024 no longer uses the hydraulic brake booster at all, they use vacuum boosters with the ABS module on all trim levels, and due to it being a turbo engine they had to use a vacuum pump on it as well. So now all 2024 Tacomas will have vacuum pumps.
    I like the vacuum boosters but not the vacuum pumps. Wish we could just go back to the days of normal engines with ample vacuum and an appropriately sized booster for the brakes.
    BillF1564 likes this.
  15. Dec 13, 2024 at 6:32 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Swapping the brake booster would disable one of the primary features of the OR, namely ATRAC/MTS/CC (aka off-road traction control). You might as well buy a different truck.
    BTW, I’ve owned a 2016 SR5 for 4 years and now a 2020 OR for 4 years and I didn’t notice anything significantly different about the brakes. Are you sure it isn’t in your head?
  16. Dec 13, 2024 at 6:41 AM
    BLtheP
    Plano, TX
    There should be a pretty noticeable difference between the two. The hydraulic brake booster produces in my opinion, quite an unnatural braking feel where it's initially responsive but as you start to lay into the pedal, it's not so responsive anymore.
    The SR5 should have had a normal feeling pedal like any other vehicle. I don't know how the two would have felt the same, a lot of people test driving the different models have spoken about how different they felt.
  17. Dec 13, 2024 at 6:45 AM
    gudujarlson
    Minnesota
    I noticed nothing out of the ordinary when I switched from the SR5 to the OR. The brakes work just fine on the OR.
    weefek likes this.
  18. Dec 13, 2024 at 6:46 AM
    BLtheP
    Plano, TX
    Not saying they don't work fine...but they have an odd feel (in my opinion and the opinions of many others) that isn't similar to any other vehicle I've ever driven. I don't like it, but it's not a big enough deal to trade trucks over.
  19. Dec 13, 2024 at 6:49 AM
    gudujarlson
    Minnesota
    What I did notice is the difference in the sound of the ABS brakes. The OR tends to be much louder. ATRAC is also a big upgrade over TRAC.
  20. Dec 13, 2024 at 6:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    And replace the vacuum pump every 100k according to the maintenance booklet. The instructions say to tilt the engine forward for access.
