Tacoma or Ridgeline?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trail boss, Aug 7, 2016.
  1. Aug 7, 2016 at 3:47 PM
    #41
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    ^. This. We just loves our tacos here. Let us know what you decide. :cheers:
  2. Aug 7, 2016 at 3:48 PM
    #42
    mike2810
    mike2810 Well-Known Member
    Arizona - Rim Country
    had 06 Sport 4x4 , now 2016 Nissan Pro 4x
    OP, reading your post, unless you have a need for a bed. why not consider a SUV. They are more than capable of towing a trailer with two bikes.
    That said. If you look the Honda RL has the largest turning circle of the mid sizes 44.4' vs Tacoma's 42'. Nissan is at 43' and the GMC twins have the smallest of the group. Reason I bring that up is you said this would be your daily driver.
    The RL is also coming with a V6 with a cylinder management system , where at times it will make it a 3 cylinder vehicle. Past experience, Honda had some oil consumption issues with this system.
    The bed of the RL is unique. However, the new gen you cannot get a full size spare in the compartment. With Toyota it comes with a full size spare.
    Test drive each and decide. They both are approximately the same. Except the top of the line RL is around $42K+
    wachuko likes this.
  3. Aug 7, 2016 at 3:50 PM
    #43
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Small penis checking in. Get a Tacoma if you want a truck. The Ridgeline is not a truck.
    transworldmoto and Ch78 like this.
  4. Aug 7, 2016 at 3:53 PM
    #44
    Trail boss
    Trail boss [OP] Member
    Richard
    It appears that is the significant different between the two. At least, no one yet has pointed out where the Tacoma is superior on pavement. I fully agree that the Tacoma is a much better looking truck than the Ridgeline but looks are not at the top of my priority list.
    Thank you for the advice. I suspected as much but thought I would ask the pro-Tacoma crowd just to ensure I wasn't overlooking any of its pluses.
  5. Aug 7, 2016 at 3:55 PM
    #45
    lwszabo
    lwszabo Well-Known Member
    Concord NC
    2018 SR double cab
    toyota dark satin alloy wheel Tint OEM bed mat
    Go to the 3rd gen section and read all the complaints on the Tacoma. Seems there are trans issues that are the hot item now. I know on previous gens they had awful rear suspension and frames that love to rust. Don't seem Toyota has addressed them out the door more of a TSB. Again I have a Tacoma but I'm not a Tacoma only person. Be open minded, weed through the total crap you will get here, and drive both!
  6. Aug 7, 2016 at 3:59 PM
    #46
    2016_dbag
    2016 POSTURD
    Every time I see a dude driving a ridgeline:
  7. Aug 7, 2016 at 4:00 PM
    #47
    Trail boss
    Richard
    I have a SUV now and am able to tow the bikes with it. The motorcycle thing is my logical justification for buying a truck but really, I don't need a truck. I just one.
    I have driven both and liked both. The Tacoma looks better and handled like a truck, the Ridgeline drove like a luxury sedan (which is okay with me).
  8. Aug 7, 2016 at 4:00 PM
    #48
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    You're not going to win many points for owning a ridgeline if a truck is what you're after. Honda makes good, reliable vehicles there's no doubt about that. I agree even, for your uses, a Honda Ridgeline should suit you better. It will do the light hauling, have the capacity to move and store items in the bed, and transport your clients comfortably.
    The issue of placing the Ridgeline in the truck category is it's ability to do all those truck functions well. Sure it has a bed and AWD, but in application of things like bed payload, towing, off-roading (ground clearance), 4WD, and things that most trucks are engineered with in mind, I feel the Ridgeline comes up short.
    Independent suspension front and rear for example. While great for handling, you won't have the bed payload capacity to transport heavier items on coil springs. No overload spring means that exceeding what the coil spring can handle can cause the coils to bind and land you right on your bumpstops (rear suspension compromise). Independent suspension also isn't optimal for high torque output because a thicker solid axle has been sacrificed for two smaller, flexible axles. Thirdly, independent suspension doesn't flex as much as a solid leaf sprung axle, which makes it bad for clearance and traction. Lastly, I don't know what method Honda is using for torque vectoring from front to rear or in their limited slips, but I am not confident in their ability to have reliable 4WD.
    To me the Ridgeline is a vehicle that is trying to do a lot of things, lot of good things, but you know what they say about tools that try to do a variety tasks, they wind up not doing all of them very well.
    cblow5 likes this.
  9. Aug 7, 2016 at 4:08 PM
    #49
    Trail boss
    Richard
    Thanks Supra4x4. All of that makes sense. If I understand correctly, the Tacoma is the better choice for hauling heavy loads and off-pavement work. I guess I need to decide if I will ever want to go off-pavement. If so, then the Tacoma is the more logical choice due to the way it is designed and built.
    cblow5 and Arailt like this.
  10. Aug 7, 2016 at 4:09 PM
    #50
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    Ridgeline is good if you don't need a 'truck' but like the convenience of a bed, in that case stay with the FWD, the 'AWD' is a reactive system.
    GM Twins are good if need a truck but don't wheel, they have better road manners than the taco, plus the diesel option if you like.
    Tacoma if you need a truck and 4 wheel or otherwise spend time off-road. It will be better stock vs the GM's and the aftermarket will be orders of magnitude larger.
    cblow5 likes this.
  11. Aug 7, 2016 at 4:12 PM
    #51
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Do large-penised folks like Tacomas or ridgelines? I'm getting confused. I think they're both ok, can I consider my penis average?
    Yeah, that's probably a little optimistic...
  12. Aug 7, 2016 at 4:14 PM
    #52
    Rojoe123
    Rojoe123 Bored when I'm not driving her!
    Roger
    N/E Ohio
    2016 Tacoma ordcsb 4x4 mgm
    Plasti-Dip lettering and grill, nerf side-steps, blue interior led
    Well if the soccer mom comes free with it:rofl:
    JimboAnz[QUOTED] likes this.
  13. Aug 7, 2016 at 4:14 PM
    #53
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    :thumbsup:
  14. Aug 7, 2016 at 4:16 PM
    #54
    DrVonEvilSatan
    Toyota Truck
    Neither, smart cars.
  15. Aug 7, 2016 at 4:18 PM
    #55
    ajm
    Anthony
    AZ
    1996 4x4
    Damn it. Back to sub-average status.
  16. Aug 7, 2016 at 4:22 PM
    #56
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Oh boy, here we go again, but OK...
    They say chit rolls down from the top, so I ask you, would you rather be the top dog at the top of the hill or the dung catcher at the bottom?
    Take a look at the chart and see who is at the top of the food chain for the small truck segment, and who is at the bottom.
    To put it another way, are you a bottom feeder or are you at the top of the food chain?
    Your vehicle says a lot about you, and is perceived as a reflection of you, choose wisely
    Hope that helps
    Cheers!
  17. Aug 7, 2016 at 4:23 PM
    #57
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    The Ridgeline should be called a Hondamino !
  18. Aug 7, 2016 at 4:28 PM
    #58
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If you are commuting daily, the Ridgeline will give a better ride.
    It is tiring driving a stiff bouncy truck everyday.
    Blueboy and Lord Helmet like this.
  19. Aug 7, 2016 at 4:58 PM
    #59
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    No problem, my advice as an auto enthusiast is free! And yes, the Tacoma is a better choice for those applications. But that isn't to say a Ridgeline couldn't handle a dirt road, it certainly could.
  20. Aug 7, 2016 at 4:59 PM
    #60
    cbreze
    cbreze Well-Known Member
    Jim
    Bend, Oregon
    '12 T4R, '74 LC, '88,'98 04' pickups.
    But the people seeing you don't know it's free. Ha,Ha. here comes a soccer mom.
    I'd opt for the 4x2 Tacoma over a ridgeline anyway even if the ridgeline was free Lol.
