Tacoma outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bridgetc, Jun 15, 2022.
  1. Jun 15, 2022 at 11:42 AM
    Bridgetc
    Bridgetc [OP] Member
    Bridget
    2010 Toyota Tacoma
    Okay so I’ve done this on 2 different occasions, electric goes out, I plug my coffee maker into my Tacoma outlet and it does not run the coffee maker. I then realize it does not provide enough amps. Now the funny thing is when I try taking the coffee maker back in the house and plug it into a regular outlet it no longer works??‍♀️
  2. Jun 15, 2022 at 11:46 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Have you tried multiple house outlets? Its possible that an underamped draw burned out your coffee maker. Its rare, but possible.
    6 gearT444E likes this.
  3. Jun 15, 2022 at 11:51 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    is the coffee maker digital? I think it would be rare, but your truck power is not only underpowered, but dirty. its a modified sine wave, as opposed to house power which is pure sine. People plug plenty into modified sine inverters without issue, but just a thought.
  4. Jun 15, 2022 at 7:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you buy a new coffee maker the first time it happened?
    Or did it start working on its own again?
    What kind of coffee maker is it?
  5. Jun 17, 2022 at 7:16 AM
    Bridgetc
    Bridget
    2010 Toyota Tacoma
    It’s a Black and Decker stainless steel cafe. Only 3 months old. I will try different outlets
  6. Jun 17, 2022 at 7:17 AM
    Bridgetc
    Bridget
    2010 Toyota Tacoma
    No it’s not digital
  7. Jun 17, 2022 at 7:17 AM
    Bridgetc
    Bridget
    2010 Toyota Tacoma
    Black & Decker stainless steel cafe. It’s only 3 months old
  8. Jun 17, 2022 at 7:19 AM
    Bridgetc
    Bridget
    2010 Toyota Tacoma
    Yes I replaced the first coffee maker because it never worked again. The second one is still not working, it’s only 3 months old. Nice coffee maker hate to throw it out
  9. Jun 17, 2022 at 7:36 AM
    j-utah
    j-utah Well-Known Member
    2024 Tundra SR5 Air Suspension
    It could be that the lack of amps caused something in the coffee maker to overheat, perhaps? It was struggling to run and that could cause heat and then burn out some functional component.
    What you’ve experienced is common with batteries and power outlets tied to them — which is making sure that there are enough amps.
    I’m with you on wanting an electric coffee maker for camping. Other methods can be a PITA. The most popular one I know of that is lower wattage is this model, but I don’t know if it will work with the tacoma outlet. It is 550 watts:
    Cuisinart DCC-450BK 4-Cup Coffeemaker with Stainless-Steel Carafe, Black
    Bridgetc[OP] likes this.
  10. Jun 17, 2022 at 8:43 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    The stock inverter in the Tacoma is only rated to 400 Watts.
    A typical 12 cup coffee maker requires in the neighborhood of 750-1200 Watts.
    If your coffee maker has anything beyond a basic on/off rocker switch for controls, it's digital. Using it on the 400w inverter probably damaged it.
    Key-Rei likes this.
  11. Jun 17, 2022 at 12:22 PM
    Bridgetc
    Bridget
    2010 Toyota Tacoma
    Thank I may check out this model of coffee maker
    j-utah[QUOTED] likes this.
