Tacoma Overheating Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jesse_G2ndGenYota, Sep 29, 2023.
  1. Sep 29, 2023 at 10:18 AM
    Jesse_G2ndGenYota
    Jesse_G2ndGenYota [OP] New Member
    Jesse
    2008 Toyota Tacoma 4x4
    Hello all, long story short my 2008 Tacoma 4x4 is having overheating problems. The temp gauge inside the Tacoma never really moves but the coolant inside the expansion tank (area where you fill up coolant) boils up and starts to spray out of the cap. I can tell it gets hot because I can smell coolant through my vents when I am on the road, usually pull over immediately and let it cool down and top off any lost coolant due to it boiling out. I have replaced the thermostat and completely cleaned radiator and flushed it. No leaks observed in radiator. Water pump is good. After themostat was replaced it seemed like the problem was temporarily fixed, now it’s doing it again. Usually happens on the freeway or going up hills. Any suggestions would help immensely.
  2. Sep 29, 2023 at 10:26 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Test/replace your rad cap
    winkel, Woofer2609 and Dm93 like this.
  3. Sep 29, 2023 at 10:27 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is your radiator cap good? They are bad about the little plastic check valve falling off, when that happens they wint hold pressure.
    joba27n likes this.
  4. Sep 29, 2023 at 10:32 AM
    Jesse_G2ndGenYota
    Jesse
    I have not tested the radiator cap, could be a simple fix thank you. I will replace that and see what she does.
    Dm93 likes this.
  5. Sep 29, 2023 at 10:34 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If radiator cap doesn't fix the issue, check for a head gasket leak. While the engine is cold, open the radiator cap and rev the engine a little. Watch for air bubbles coming out.
  6. Sep 29, 2023 at 10:37 AM
    joba27n
    Nolan
    Alberta
    If there are places that rent tools near by, then I would rent a cooling system pressure tester and test the cap and also the cooling system while you have it so you don't end up spending money you don't have to. If it is a cap i'd recommend an oem cap.
  7. Sep 29, 2023 at 10:53 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If everything else checks out then check your fan clutch. Spin it by hand with engine off. It should stop almost immediately.
  8. Sep 29, 2023 at 11:15 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Fan engaging? -> pressure test for faulty Rad cap -> test thermostat for sticking (which you already did). Then move onto bigger issues (head gasket, etc.)
    First 3 cheap to replace or free to test.
    Can the thermostat be put in backwards?
    Jesse_G2ndGenYota[OP] likes this.
  9. Nov 25, 2024 at 4:02 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    My truck is smelling like it’s running hotter than it should so, I’m going to looking into the tests in this thread to hopefully get some answers.
