Tacoma overheating!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07 zoom zoom, Aug 4, 2019.
  1. Aug 4, 2019 at 9:21 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I have the Lisle funnel and it works fine. Saves a bit of mess. Prior to buying this funnel awhile back, I burped in the following manner:
    - Car parked on level surface - engine cool - remove radiator cap top up coolant close to top of radiator neck
    - Start engine - set heat control to max heat - turn fan on - low setting for fan is fine.
    - Take an old sock and fit it to the radiator neck - don't stuff it down inside the radiator - attach open end of sock around radiator neck like you were attaching a skull cap to your head.
    - Watch the temp gauge - when it gets about 1/2 way up - blip the throttle a couple of times wait a bit and do the blip again - repeat this a couple more times - you should feel heat coming out the heater
    - The purpose of the sock is to keep coolant from flying all over the place
    - If the temp gauge is still going beyond the 1/2 way mark after all of this - shut off engine and elevate the front of the truck - elevating the front of the truck can help bleed stubborn air pockets - with the truck elevated - you would go thru all of the above again - but you might need to top up the radiator again
    - If none of this works - your problem is not likely trapped air. I would be suspicious of the new engine and would then refer you to post #5 in this thread.
  2. Aug 5, 2019 at 7:03 PM
    07 zoom zoom
    07 zoom zoom [OP] Member
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    Thanks...
  3. Aug 5, 2019 at 7:07 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    Thank you for the info... I am trying to do what I can on my own, slow progress. I did text engine guy today though. Like everyone has mentioned its a lot of work that's been done and its still trying to creep up to H.
  4. Aug 5, 2019 at 7:09 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    I'm working on getting the truck in this week!
    PzTank[QUOTED] likes this.
  5. Aug 5, 2019 at 7:12 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    So couple of guys at my local automotive store had me turn the truck on while they tried stopping the fan while turning... The fan is strong. Is that what I was looking for?
  6. Aug 6, 2019 at 5:12 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    We tried this but not when it got hotter. It was only about half way. I will try it hotter
  7. Aug 6, 2019 at 5:35 PM
    Oldtac4w
    Oldtac4w Member
    2006 Tacoma TRD
    It must be good & hot to check fan slippage. If you have a good mix of antifreeze & it is topped off your leak should show up if you let it sit a day or two without starting. If you drive it every day the leak will just evaporate but antifreeze will usually leak & show up on a cold engine after a couple days sitting or it worked for me.
    07 zoom zoom[OP] likes this.
  8. Aug 6, 2019 at 6:55 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    Gotcha... Thanks
  9. Aug 6, 2019 at 7:05 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Heater hose, Water Bypass hose, Thermostat.
    I would inspect or replace those items.
    Especially the stuck thermostat
    whatstcp likes this.
  10. Aug 6, 2019 at 9:22 PM
    Blue Shark
    Blue Shark Stocky Taco
    Brendan
    Utah
    2013 MGM TRD Sport
    SCS brushed copper Ray10's 17x8.5
    I've heard of bad thermostats. Especially cheap ones from autozone or something. Timing Kit + water pump I suggest OEM only. I'd get the coolant tested for exhaust, shouldn't be super expensive. I could see the engine builder not machining the heads properly allowing for a slight leak when it's pressurized or even a crack in the heads.
    Nah i'd also highly suggest one of those spill free funnels.
    EDIT: Also radiator caps can go bad. Get your cap pressure tested and make sure it's not "leaking" under pressure.
    whatstcp and Skyway like this.
  11. Aug 19, 2019 at 4:22 PM
    07 zoom zoom
    Kiko
    Peoria , AZ
    07 Toyota Tacoma
    Leather, 20" wheels
    Update... We burped it a bunch of times and it seemed good, couldn't find the reason the reservoir was empty after driving it 25 mins. No leaks i could find. I ran another obd test and it pulled a code... Faulty thermostat! We are going to take the new one out and replace it with another new one. Ugh i saw a test for the thermostat to make sure it works.. Put it in a pot and let it boil to see if it opens. Should i do this?
  12. Aug 19, 2019 at 4:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you are in that far, just replace the Tstat with a new one.
  13. Aug 19, 2019 at 4:32 PM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    Sure replace the thermostat if it’s out, but doesn’t hurt to test the old one just to know.
  14. Aug 19, 2019 at 4:53 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Make sure it's facing the right direction too. Check some youtube videos first.
    whatstcp and 07 zoom zoom[OP] like this.
  15. Aug 19, 2019 at 5:11 PM
    #35
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Are the Auto part stores Thermostat, okay for a Tacoma? I have read they can be picky on brands of other replacement parts...
  16. Aug 20, 2019 at 6:46 PM
    #36
    winkel
    Corydon, IN
    You should be fine with one from the auto parts store. I would stick to Napa or OReilly though.
  17. Aug 20, 2019 at 7:54 PM
    #37
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The OBD II can't test a thermostat. I think you must have a different issue.
    What was the code?
    MolonLabeTaco likes this.
  18. Aug 21, 2019 at 10:42 AM
    #38
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Also the thermostat going bad would not account for the lose of coolant.
    Lester Lugnut likes this.
  19. Aug 21, 2019 at 11:01 AM
    #39
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    True. Absolutely no way for it to read a code on a t-stat.
    True again.
    Test the new t-stat before installing. Easy to do & take <10 minutes.
  20. Aug 21, 2019 at 11:48 AM
    #40
    $yoda$
    Tom
    2007 Tacoma 4.0
    Has to be head gaskets at this point right? I mean if she's loosing the amount of coolant she's describing with no visible leaks if anykind what else could it be?
