Tacoma overheating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rozenmike, Dec 31, 2024.
  1. Dec 31, 2024 at 6:31 AM
    rozenmike
    rozenmike [OP] waterfowl junkie
    mike
    southwest virginia
    2006 tacoma sport 4x4
    none
    I have a 2006 Tacoma, 4.0. I'm not loosing any coolant. This thing is acting crazy. First of all it acts like I have no circulation at an idle. Regardless of how long it sits and idles it will not blow any heat until you raise the rpm's past an idle. I can drive it all day and it will not start to overheat until you stop for a short period of time and let it idle.(like at a slow drive through) Once it starts to overheat it will continuously clime almost the the read line and fall back to normal for the rest of the trip. While it is climbing it does not blow heat until it starts to fall back to normal. It has 312000 + miles on it. At 250000 I had to replace the head gaskets at which time I replaced all wearable parts that I had to remove to do the job. Timing chain, gears, guides and tensioners, water pump, thermostat, oil pump, idler pullies, belt tensioner and belt.
    The only code I'm getting is for catalytic deficiencies on bank 1.
    I have done a test for exhaust gases in my coolant system and it was negative. I am getting a few small bubbles coming into my recovery tank which leads me to expect a possible head gasket issue again. If this is the case is it possible the catalytic converter help cause the recurring issue as I had the same code at the 250000 mile mark. I used a camera then to determine I was getting a coolant leak into cylinder #6 which is on bank 1.
    The truck starts and runs great with absolutely no rust and has a new frame with accessories thanks to a Toyota recall. I plan on keeping it till it or me dies so any help would be greatly appreciated.
  2. Dec 31, 2024 at 9:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like an air pocket in the engine cooling jacket.
    Park it nose up on an incline and warm it up with the radiator cap off. Then massage the hoses while running. It may take some time.
    knottyrope likes this.
  3. Dec 31, 2024 at 11:45 AM
    rozenmike
    mike
    southwest virginia
    none
    Can that happen without opening the system? The truck did great for 60000 miles after the head gasket repair.
  4. Dec 31, 2024 at 11:47 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    if you are losing coolant, yes it can happen
    Jimmyh likes this.
  5. Dec 31, 2024 at 12:00 PM
    rozenmike
    mike
    southwest virginia
    none
    I'm not losing any coolant but I will give it a try. Any other suggestions?
  6. Dec 31, 2024 at 12:11 PM
    ieizxxnsaeomeostfd
    ieizxxnsaeomeostfd Well-Known Member
    2014 Tacoma Base
    ARB Bumper Warn winch Icon lift 35s
    Could be a bad thermostat I suppose.
  7. Dec 31, 2024 at 12:19 PM
    rozenmike
    mike
    southwest virginia
    none
    I have a new water pump and thermostat to install along with an idler that's got a squeak. I'll see how that goes. Just wasn't looking forward to possibly replacing head gasket again. That was an all-day job.
  8. Dec 31, 2024 at 12:50 PM
    ieizxxnsaeomeostfd
    2014 Tacoma Base
    Not sure how these head gaskets normally leak but if it's an internal leak you'll have coolant in the oil and vice versa. Could do an oil change and send a sample off to blackstone-labs.
    A compression test on all the cylinders would be good information too. If some are low that could indicate a blown headgasket.
  9. Dec 31, 2024 at 3:13 PM
    rozenmike
    mike
    southwest virginia
    none
    Did the oil change and lab check, negative. I will do a compression check to see whats going on. I,ll hollerback
  10. Feb 20, 2025 at 6:51 AM
    rozenmike
    mike
    southwest virginia
    none
    Well I finally gotterdone. After using a camera in each cylinder, I found that I had a small leak coming into Cylinder#6 after a hard run. I tore it down and took both cylinder heads to my local machine shop and had them straightened up and pressure tested. Only cost me $80 for the pair. Put everything back together. Now at 318000 she's running cool and normal, I have heat at an idle again, no temperature spikes and not losing any coolant. I don't even have the bubbles coming into my revisor anymore. I hope this may help someone else in the future. I kind of knew what the issue was but really wasn't looking forward to pulling it apart again. I guess sometimes you're better off to just getter done than to beat around the bush.
    ieizxxnsaeomeostfd and eherlihy like this.
  11. Feb 20, 2025 at 7:03 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Glad you got it figured out and running back the way it should be. Not glad it was the head gasket as it's the most expensive type of repair.
  12. Feb 21, 2025 at 7:55 AM
    rozenmike
    mike
    southwest virginia
    none
    Thanks, It wasn't too bad, spent about $400 and a couple of band aids from skind up knuckles. LOL
  13. Feb 21, 2025 at 8:27 AM
    fxntime
    I have FINALLY learned, after about 1000 scars on my hands [part of my job was HVAC type work] that thin cut resistant gloves are life [or blood] savers. EVERYTHING on HVAC stuff is sheet metal with a razor blade edge. My DNA is spread far and wide......:cool:
