Tacoma Owners with Manual Transmission: Any Clutch Problems, ie, Slave Cylinder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jolly Bill, Aug 13, 2020.
  1. Nov 8, 2020 at 2:45 AM
    hatesfreedom
    hatesfreedom Active Member
    Until this thread I didn't think the clutch could fail in a way that would prevent limping home. I don't know why I thought that.
    175k miles, no clutch problems. It squeeks sometimes in the winter. I've never cared enough to get it fixed.
    Jolly Bill[OP] likes this.
  2. Nov 8, 2020 at 8:54 AM
    jakezna
    jakezna Well-Known Member
    The squeak (in the winter oddly enough) was my first problem symptom. A short time after the squeak, the clutch started to soften. I'd kindly recommend you save yourself some trouble and have it looked at before you potentially become the first known Tacoma stranded on the side of the road. I'm very grateful my clutch lasted just long enough to make it to the dealership before if completely failed and could not be driven.
    Jolly Bill[OP] and doublethebass like this.
  3. Nov 9, 2020 at 2:22 PM
    Taco4XStock
    Taco4XStock Clutch Cargo
    South West Desert
    2003 Tacoma 3.4L 4X4 5 Speed Manual Trans TRD.
    My Horse's Tires are 1 in. bigger.
    On my way to parts unknown when my clutch went to the floor. I was a mile from home. So at the stop light I stop turn ignition off and put it in second gear and hit the starter with the ignition. Hard on the components but I Made it home slowly in second gear and down the hill after that to the shop. I could have been out in no mans land. It was a pin hole leak in the Clutch Flexible Hydraulic Line. Didn't see the leak until it fully blew. The air infected both cylinders. Had to replace them. Warning signs are fluid around the connections area between rubber and hard lines. Pedal will not engage until warmed up. Shifting noise between gears at random. Pedal engages close to the floor until warmed up. Advice: if it feels wrong IT IS! :violent:
  4. Nov 9, 2020 at 9:43 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    I should add to my earlier response that I replaced my clutch slave and master about about 40k cause I went to leave for work one day and the clutch pedal was on the floor.. don’t know why it failed so early, but it did and no problems, several years, but not a whole lot of miles later.
    Taco4XStock and Jolly Bill[OP] like this.
  5. Nov 10, 2020 at 11:12 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Had my 6MT replaced at 75,000.
    Get AAA. It's like $100 a year and give you nice peace of mind.
  6. Nov 10, 2020 at 11:18 AM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    I'm on 100k with no problems, I did take out the clutch accumulator at 60k.
