Tacoma Part Out!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by License2Ill, Aug 6, 2016.
  1. Dec 11, 2017 at 10:14 PM
    #301
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Yeah, I'll need a pic.
  2. Dec 12, 2017 at 3:13 PM
    #302
    License2Ill
    Ian
  3. Dec 12, 2017 at 3:16 PM
    #303
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
    Do you have the front seatbelts
  4. Dec 12, 2017 at 3:23 PM
    #304
    License2Ill
    Ian
    Yep sure do. $140 shipped for both.
  5. Dec 12, 2017 at 3:51 PM
    #305
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Here is a couple pics of the connector that should plug into it.
    Let me know what you got.
    Thanks!
  6. Dec 12, 2017 at 8:01 PM
    #306
    License2Ill
    Ian
    Yep. That's it, asking $15 shipped.
  7. Dec 12, 2017 at 8:36 PM
    #307
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Any chance you also have the lampholder assembly (and lamp) for the ash tray, and the cigarette lighter too?
  8. Dec 12, 2017 at 8:42 PM
    #308
    License2Ill
    Ian
    Not sure exactly what you mean. I do have the ashtray backing, which is where the light is attached.
    I no longer have the center bezel which had the cig lighter attached...
  9. Dec 12, 2017 at 8:54 PM
    #309
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    yeah I'm looking for the metal bracket that the ash tray slides in as long as it includes the mount on top which holds the bulb. My truck has a flaoting socket that I think goes in this holder. Should be a circular hole with two square cuts for tabs on the holder.
  10. Dec 12, 2017 at 9:10 PM
    #310
    License2Ill
    Ian
    Yep, I have that. I can do +$10 on top of the GB bulb holder. Just pm if you're interested...
  11. Dec 15, 2017 at 11:32 AM
    #311
    AaKnight
    AaKnight New Member
    AaKnight
    Is your truck an extra or double cab? if so i would be interested in the rear shaft.
  12. Dec 15, 2017 at 11:35 AM
    #312
    License2Ill
    Ian
    Rear driveshaft?
  13. Dec 15, 2017 at 11:39 AM
    #313
    AaKnight
    AaKnight New Member
    AaKnight
    Yes, rear shaft, rear section. pm sent.
  14. Dec 15, 2017 at 11:45 AM
    #314
    The Bob
    The Bob Well-Known Member
    Bob
    Frontrange CO
    2015 AC SR5 4x4 6 speed, 2009 Lexus GX 470
    Do you have a rear bumper available?
  15. Dec 15, 2017 at 12:26 PM
    #315
    License2Ill
    Ian
    Sorry no longer available. FYI, rear 2 piece DS's are the same for Xtra & double cabs, the difference is between transmissions, auto is around 1" shorter than manual on the front section of the DS. The rear portion are all exchangeable on all models of 2 piece DS trucks.
    Nope, do not.
  16. Dec 26, 2017 at 7:03 AM
    #316
    bretts
    bretts Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    Do you have the little servo motor that controls the heater valve? it might be called an air mix servo. it's right under the glovebox to the left. :]
  17. Dec 26, 2017 at 9:29 AM
    #317
    robblacktpre03
    robblacktpre03 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    do you have any dash hardware, screws, bolts?
  18. Dec 27, 2017 at 1:35 PM
    #318
    License2Ill
    Ian
    Yep, possibly. Whatcha need?
  19. Jan 17, 2018 at 9:55 PM
    #319
    AMccasland
    AMccasland New Member
    Andrew
    1997 Green Tacoma Xtra cab
    bilstein 5100s, Rear springs from 92 pickup, Deckplate Mod
    Still have the front diff support brackets?
  20. Jan 18, 2018 at 11:34 AM
    #320
    License2Ill
    Ian
    No, don't believe I still have them.
