Tacoma passenger side lean and pull!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mpg89460, Aug 11, 2014.
  1. Aug 11, 2014 at 10:05 PM
    Mpg89460
    Mpg89460 [OP] New Member
    Northern nevada
    04 tacoma xtra cab
    Bilstein 5100 adjustable shocks. Added leaf in rear. Custom grill wheels tires sub box.
    Here's my story:
    I bought my 2004 tacoma and not even a week after the driver side tire flew off while going down the highway. Luckily I had full coverage so I was able to replace the front fender, brake caliper, wheel studs, and lower ball joint nut.
    I was experiencing a slight pull to the passenger side while driving so I went in for an allignment (tires plus). They told me that were able to adjust it slightly but not completely, the camber is maxed out. When I took It for a drive I noticed it still pulled to the right and was a bumpy ride. Possibly worse than before. I thought maybe my procomp mud tires were out of balance so my next step was to have those balanced. After the balance my symptoms did not change at all!! My last idea was maybe a radial pull from the tires so I again went to tires plus and they swamped the two front tires around. That changed nothing. I am running out of options.
    I also recently noticed a pretty good lean on the front end towards the passenger side. Not sure if the lean appeared after the allignment but it was definitley after the accident. Is this maybe caused by my bilstein 5100 adjustable shocks?
    I have no idea what is causing these problems. Any ideas??
  2. Aug 12, 2014 at 1:54 AM
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    front brake calliper not releasing completely? lift the truck with a jack and see if tire is spinning freely..?maybe...
  3. Aug 12, 2014 at 6:01 PM
    surfer7333
    surfer7333 Active Member
    Dave
    Minneapolis
    95 Taco
    6" suspension lift, header, cold air intake, racing brake proportioning system, 33' tires, 1.25 wheel spacers.
    Calipers nee replacing!! only the front right is working, replace both as pairs as well as the pads. tires may have scallops and if so may need replacing, rotate big tires every 6 months.
