Tacoma Prerunner 4cyl - How do I change transmission fluid
Discussion in '4 Cylinder' started by prerunnerSD, May 21, 2010.
  1. May 21, 2010 at 6:15 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Have an 01 Prerunner, 2.7L with 190,000 miles on it.. running pretty good with no issues but think I should do some preventive maintaince on the tranny.
    Could anyone guide me to how I change the transmission fluid. Should I buy a new filter and gasget, or what exactly does he need in addition to the fluid. I have gotten conflicting answers on other forums, PEP boys and Autozone.
    Thanks
    PS. Does my truck really have 3 belts?
  2. May 21, 2010 at 11:35 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    Loosen the bolt on the transmission pan, let it drain. After it drains, fill it back up in the same hole. There's no filter, only a metal magnetic screen. You can also do a transmission flush but I believe that requires a professional vacuum.
